I am trying to setup a dimmer using a mqtt generic thing. Basicly it works, changing the duty cycle (values between 0…100) are logged in the log files. When inspecting the mqtt traffic the value is divided by 100, so 50% results in a mqtt command to 0.5.
My thing code looks like:
UID: mqtt:topic:abcd
label: MQTT Bench
thingTypeUID: mqtt:topic
configuration:
payloadNotAvailable: Offline
availabilityTopic: tele/bench/LWT
payloadAvailable: Online
bridgeUID: mqtt:broker:ad84a2b039
channels:
- id: Switch
channelTypeUID: mqtt:switch
label: Bechn Switch
description: ""
configuration:
commandTopic: cmnd/bench/POWER
stateTopic: stat/bench/POWER
off: OFF
on: ON
- id: Dimmer
channelTypeUID: mqtt:dimmer
label: BenchDimmer
description: ""
configuration:
commandTopic: cmnd/bench/Dimmer
min: 0
stateTopic: stat/bench/RESULT
transformationPattern: JSONPATH:$.Dimmer
max: 100
on: "100"
mosquitto_sub:
cmnd/bench/Dimmer 0.55
events.log:
2021-09-29 20:55:27.364 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'MQTTBechn_BenchDimmer' received command 55
2021-09-29 20:55:27.376 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'MQTTBechn_BenchDimmer' predicted to become 55
2021-09-29 20:55:27.389 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTBechn_BenchDimmer' changed from 0 to 55
2021-09-29 20:55:27.522 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MQTTBechn_BenchDimmer' changed from 55 to 0
So min and max in the yaml code should be used to scale the input(?!) but it doesn’t.
