Mark_VG
(Mark)
June 11, 2021, 9:07am
1
Platform information:
Hardware: _amd64
OS: Windows 10/10.0
Java Runtime Environment: 11.0.9.1 (Zulu11.43+55-CA)
openHAB version: openHAB 3.1.0.M5
Hi All
Is it possible to set the color of an oh-cell while also using the trendline features?
I have:
component: oh-cell
color: red
on: true
action: popover
actionModal: widget:widget_with_chart
actionModalConfig:
mainsPower: ShellyEM_MAINS_Watt
upsPower: ShellyEM_UPS_Watt
title: Power Usage
trendItem: ShellyEM_MAINS_Watt
slots: null
However the color does not work unless I remove trendItem: ShellyEM_MAINS_Watt
So without the trendItem the color is applied correctly?
Any ideas?
Mark
JustinG
(JustinG)
June 11, 2021, 7:07pm
2
At the moment, the cell color and trendlines are mutually exclusive.
lamer
(Johannes Müllers)
January 29, 2022, 8:25pm
3
Has there been a solution or workaround in the mean time?
JustinG
(JustinG)
January 30, 2022, 4:34pm
4
In the case of the oh-cell the workaround is not trivial. The format of the cells is very precisely defined and the only way to override that is to directly modify the css. However, the cells also are difficult to ID individually if you have more than one cell on a page and want different background colors. You need to wrap each cell in a container that you can give a unique identifier to so that you have distinct selectors.
To get:
This is the widget code
uid: demo:cell-color
props:
parameterGroups: []
parameters: []
tags: []
component: f7-page
stylesheet: >
.red-cell > .oh-cell {
background: #ffcccc;
.blue-cell > .oh-cell {
background: #ccccff;
slots:
default:
- component: f7-block
class: red-cell
style:
margin: 0
padding: 0
slots:
default:
- component: oh-cell
trendItem: Outside_Temperature
class: blue-cell
style:
margin: 0
padding: 0
slots:
default:
