OH3: OH complains with endless errors after removing unused grafana/influxdb
  • openHABian 3.3.0 on rPi4 4GB
I installed grafana/influx via the openhab-config tool for future use, but now decided not to run it.
There is no uninstall function, so I stopped both services, disabled these via systemctl, and then apt removed them, also deleting their /etc/ directories and deleting the services/influxdb.cfg file.
However, even after a reboot, the openhab.log shows the following error in very quick succession:
2022-12-08 08:28:22.674 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@1bd38e': java.net.ConnectException: Failed to connect to localhost/0:0:0:0:0:0:0:1:8086
org.influxdb.InfluxDBIOException: java.net.ConnectException: Failed to connect to localhost/0:0:0:0:0:0:0:1:8086
Caused by: java.net.ConnectException: Failed to connect to localhost/0:0:0:0:0:0:0:1:8086
Caused by: java.net.ConnectException: Connection refused (Connection refused)
2022-12-08 08:28:22.706 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': java.net.ConnectException: Failed to connect to localhost/0:0:0:0:0:0:0:1:8086
influx is not used a persistence service in OH, but is still listed there as an option.
How do I get rid of it?
I have stopped the openhab.service due to the incessant errors being logged. (One every 30ms.)
A more detailed error version:
2022-12-08 08:28:45.382 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
	at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:831) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
	at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
	at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
	at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
	at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:265) ~[bundleFile:?]
	at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:183) ~[bundleFile:?]
	at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.java:224) ~[bundleFile:?]
	at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.java:108) ~[bundleFile:?]
	at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.java:88) ~[bundleFile:?]
	at okhttp3.internal.connection.Transmitter.newExchange(Transmitter.java:169) ~[bundleFile:?]
	at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:41) ~[bundleFile:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
	at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
	at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
	at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
	at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
	at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
	at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
	at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
	at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:819) ~[bundleFile:?]
	... 10 more
	at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:412) ~[?:?]
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:255) ~[?:?]
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:237) ~[?:?]
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
	at java.net.Socket.connect(Socket.java:609) ~[?:?]
	at okhttp3.internal.platform.Platform.connectSocket(Platform.java:130) ~[bundleFile:?]
	at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:263) ~[bundleFile:?]
	... 10 more
Did a search for ‘influx’
# [2022-12-08 10:45] openhabian@openhabian /etc/openhab/services $
sudo find / influx | grep influx
/var/lib/apt/lists/repos.influxdata.com_debian_dists_bullseye_stable_binary-armhf_Packages
/var/lib/apt/lists/repos.influxdata.com_debian_dists_bullseye_InRelease
/var/lib/openhab/config/org/openhab/influxdb.config
/var/lib/openhab/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/features/karaf/org.openhab.addons.features.karaf.openhab-addons-external/3.3.0/org.openhab.addons.features.karaf.openhab-addons-external-3.3.0-influxdb.cfg
/var/lib/openhab/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/bundles/org.openhab.persistence.influxdb
/var/lib/openhab/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/bundles/org.openhab.persistence.influxdb/3.3.0
/var/lib/openhab/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/bundles/org.openhab.persistence.influxdb/3.3.0/org.openhab.persistence.influxdb-3.3.0.jar
/var/lib/influxdb
/var/cache/apt/archives/influxdb_1.8.10-1_armhf.deb
/usr/lib/systemd/system/influxdb.service
/usr/share/bash-completion/completions/influx
/usr/share/keyrings/influxdb.gpg
/opt/openhabian/functions/influxdb+grafana.bash
/opt/openhabian/functions/influxdb+grafana.bats
/srv/openhab-userdata/config/org/openhab/influxdb.config
/srv/openhab-userdata/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/features/karaf/org.openhab.addons.features.karaf.openhab-addons-external/3.3.0/org.openhab.addons.features.karaf.openhab-addons-external-3.3.0-influxdb.cfg
/srv/openhab-userdata/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/bundles/org.openhab.persistence.influxdb
/srv/openhab-userdata/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/bundles/org.openhab.persistence.influxdb/3.3.0
/srv/openhab-userdata/tmp/kar/openhab-addons-3.3.0/org/openhab/addons/bundles/org.openhab.persistence.influxdb/3.3.0/org.openhab.persistence.influxdb-3.3.0.jar
/etc/apt/sources.list.d/influxdb.list
/etc/default/influxdb
find: ‘influx’: No such file or directory
list in karaf did not return anything influx, but it seems there is still something that needs removing.
Did you deinstall the influxdb binding via http://pi:8080/settings/addons ?
Thanks… most trivial… isn’t it?
I am new to the OH3 UI.
Now that you pointed it out, I could vaguely remember that I had used it once, added all the stuff I needed and forgot about it.
In any case: the error messages are gone now.
