I am running OH3 on Windows 10 and everything is doing fine so far.
I have a screensaver that starts after some time, to show a nice slide show of my photos. And there is a rule that detects when someone passes by for the first time at morning. Then a welcome message is generated by TTS, and some music plays. That’s fine so far.
What I now want to have is that in this situation the screensaver is terminated, to enable a view on OH content (weather, time etc.). If tried to simulate a key strike using NirCmd, but this does not work - probably because OH is running as service.
Is there any other way to stop the screensaver from a rule (in this configuration)?
Thanks for this interesting approach. But the task ID changes every time the screensaver or system is (re)started. So this does not work out from an OH3 rule…but I will check using the name.
In general it is possible to kill a task by it’s name as well as by it’s number.
As only one screensaver can run on a windows machine at the same time it shouldn’t be a problem to find the right one. What you also can do is to use tasklist ( I am not sure if it can be filtered by name ). But latest using powershell in a batch file it should be possible to filter the resulting output of tasks.
In case the script does not fit into the GUI create a windows batch file and call it via executeCommandLine from within the rule.
My system runs under cubietruck resp. Pi. Everthing I cannot do from within the UI I try to delegate to run from a shell that is triggered from within a rule.
