OH3 OpenHabian Influxdb+grafana and NGNIX failing to install
Clean install of OpenHabian, upgraded to OH3 immediately. Installing influxdb+grafana fails. And installing NGINX just hangs up and can’t even get out with CTL+C. Suggestions?
2020-12-16_13:07:20_CET [openHABian] Beginning setup of InfluxDB and Grafana... OK
2020-12-16_13:07:26_CET [openHABian] Configuring InfluxDB... OK
2020-12-16_13:08:20_CET [openHABian] Configuring Grafana... OK
2020-12-16_13:08:57_CET [openHABian] Installing InfluxDB... FAILED
2020-12-16_13:10:35_CET [openHABian] Updating Linux package information... OK
2020-12-16_13:10:36_CET [openHABian] Beginning setup of InfluxDB and Grafana... OK
2020-12-16_13:10:36_CET [openHABian] Configuring InfluxDB... OK
2020-12-16_13:11:03_CET [openHABian] Configuring Grafana... OK
2020-12-16_13:11:12_CET [openHABian] Installing InfluxDB... FAILED
2020-12-16_13:14:03_CET [openHABian] Updating Linux package information... OK
2020-12-16_13:14:03_CET [openHABian] Beginning setup of nginx as reverse proxy with authentication... OK
2020-12-16_13:14:06_CET [openHABian] Configuring nginx authentication options...
OK
2020-12-16_13:14:08_CET [openHABian] Configuring nginx network options...
98.233.183.68
2020-12-16_13:14:18_CET [openHABian] Installing nginx... OK
2020-12-16_13:14:22_CET [openHABian] Setting up nginx configuration... OK
2020-12-16_13:14:22_CET [openHABian] Installing certbot... OK
2020-12-16_13:14:26_CET [openHABian] Configuring certbot... nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
Yes, even two of them:
  1. stay on topic and don’t misuse the overall thread for your issue
  2. install again with debugmode=maximum as being told in the debug guide you have read (you have, haven’t you ?)
The thread literally says “This topic can be used to discuss problems/experiences/questions on the openHAB 3.0 Release Candidates.” And that’s exactly what I’m doing.
And the thread makes absolutely no mention of a debug guide. I googled “OpenHab Debug Guide” and there is no such thing found. So no, I haven’t read this guide, whatever and wherever it is.
So instead of just rudely telling me not to do exactly what the tread said to do, and referring me to an unknown document, perhaps you or someone could say something helpful?
openHAB not openHABian. They are two different products.
No, you’re not even close. You ask for help on a specific problem of yours you have with openHABian installation. That’s a Linux.
That you haven’t read the docs for because if you had you would have seen multiple references to the debug guide I mentioned. Which tells you how to debug issues with openHABian. I’d call that “helpful”, you don’t ? It’s probably the most helpful resource to exist for this type of problem.
The thread is on openHAB 3.0RC1. That’s Java software.
And you should only post if that’s of general interest and helpful to identify issues with the software before release.
@Pedals2Paddles Please note this thread, especially 1 & 4.
How to ask a good question / Help Us Help You
