Hi folks,
I really like the new openhab 3 main-ui but I also want to keep all my configruation in filebased form in the “conf” directory for backup and other personal reasons.
Is there a way to configure the new main-ui’s pages and not only sitemaps in a filebased way?
e.g. to add separators or set a fix cardOrder
I am not sure because I don’t use filebased MainUI pages, but everything should go into the jsondb database files (which are textfiles by the way).
The default page “Overview” (the only one I have) can be found in
There was no real textual config for PaperUI, just options for inbox behavior and some more, which are still valid in oh3, only syntax changed from org.eclipse… to org.openhab…
I will give my vote for additional support to configure the “pages” in text files. I can accept when new users prefer the UI way, but I am also belong to the group of users which have the whole openHAB system in text-files. So with the look back to the switch from openHAB 2.5.10 to openHAB 3.0.0 it was really easy to get the system in a complete new installation up.
The last two days I edited my item files to integrated the semantic structure and I works good.
Also editing in Visual Studio Code with the openHAB extension makes me a lot of fun.
So, summary: When I will spent time into pages, I have the wish to back them easy with copying the openhab-conf folder to another location up.
The paperUI did not have the kind of visualization the new main UI is offering.
And I did not know that if something was not possible in OH2 that this will never be possible even with a new major version and a new concept.
So nothing changed for new introduced UIs (from OH1 to OH2 and now to OH3) they cannot be configured via textual configuration. So the only solution is using sitemaps which are not nearly as nice as the new UI
This must be not correct. When I edit my file with Visual Studio Code and the openHAB extension (and I also use the openHAB Alignment Tool Extension) I got checks about my Syntax, it got the actual values of items and sometimes groups, if defined, I get different colors for the parts of an item definition and it is very easy to make bulk changes (like today when I reorganize my whole group structure).
Like above said, I can accept when new users will use the UI, but I had learned to love the supposed old configuration over text files.
Yes, because somebody wrote this extension. I don‘t see the new feature implemented in the near future, cause the possibilities framework7 is giving are too huge…
universal, “Lowest Common Denominator” format (plain text)
not having to touch mouse
etc.
By all accounts, your work on the new GUI is remarkable, Hans. And thank you for that by the way. My understanding is you put quite some effort into that for quite a long time. So I am not replying about your work specifically which seems wonderful.
Rather I try and push back (in a general way) on this “GUI first” mentality that I am afraid to become prevalent in the project.
I realize my influence is limited as I am at best an occasional forum contributor here, much less any code. But forums are for discussion. All I can do is voice my opinion.
