openHAB is NOT diverging from the path to use textual configuration. There are no plans for such.
Not having a possibility to configure pages via text files just means, nobody has developed this feature. So if you have such a strong demand for it, feel free to contribute.
On the other hand, BasicUI is still there and will remain, so like in openHAB 2.5.x, you can define a UI via text config.
As you see, nobody took away key features/options, but new possibilities have been added, which will evolve in the future.
I can confirm that statement. I have been migrating from 2.5 to ver. 3 recently and I can develop Basic UI over the web interface in text form. However…
I still do not know how to tell openhabian he should take the .sitemap file from sitemaps folder.
I did not find explanation in the documentation on that.
Any suggestion?
I have created new sitemap within OH3 official interface. This sitemap is not being located in /sitemaps folder → this i understood. Can debate on the forum about concept but it makes no sense. OpenHab developers had to really think about the concept and I trust them in this what they do.
Nevertheless, me as probably many other older users have habits. We definitely need more time to switch
From some reasons my sitemap does not support dynamic parameters like visibility or valuecolors (see my recent question in already closed post)
So naturally, to solve my problem I was trying the “old way” and created new sitemap I could test and check if it is working as in 2.5 or not.
This is the reason I am looking for possibility to tell OH3 to use another sitemap page, defined in the file and located in sitemap folder.
In 2.5 it was possible with Paer UI → Configuration …to attach the .sitemap file.
PaperUI never used sitemaps, only BasiUI and deprecated ClassicUI.
As I wrote, you can select the sitemap within openHABs official apps, or you can call BasicUI within your browser giving the correct sitemap as parameter :
It means there is no possibility to link to the file based sitemap in the \openhabian\openHAB-conf\sitemaps folder, right?
Just for me to be sure I understood. In this case I will have to write separate post asking for help on how to run dynamic parameters because it does not work for me at all.
Secondly, if this is not going to work why we have the same folder structures like in OH2?
Yes. I have only these sitemaps visible, they were created with official pages creation.
Trying to type the name of the sitemap from the file does not work.
It definitely works, tried it here before posting.
Please show us one of your textual sitemaps.
Please note that it can lead to issues if using both, GUI and textual sitemaps at the same time. This had already been mentioned with items and things.
