OH3 persistence freeze
I have issue with persitence that causes OH freeze after some time.
[ERROR] [d4j.internal.RRD4jPersistenceService] - Could not create rrd4j database file '/var/lib/openhab/persistence/rrd4j/pcpSalonTV_CurrentPlayingTime.rrd': /var/lib/openhab/persistence/rrd4j/pcpSalonTV_CurrentPlayingTime.rrd (Permission denied)
I’ve checked permissions and I’ve got:
[10:48:51] root@openHABianDevice:/var/lib/openhab# ls -ld /var/lib/openhab/
drwxrwxr-x 9 openhab openhab 4096 Jan  3 19:51 /var/lib/openhab/
[10:54:02] root@openHABianDevice:/var/lib/openhab# ls -ld /var/lib/openhab/persistence/
drwxrwxr-x 1 openhabian openhabian 4096 Jan  3 19:55 /var/lib/openhab/persistence/
I’m not sure what is the root cause, but I presume that the owenrship should be ‘openhab’ instead ‘openhabian’ so I’ve changed it manually, however it went back by itself to ‘openhabian’ anyway.
Tried “fix permissions” from openhabian-config, but I’ve got error
2021-01-04_10:58:59_CET [openHABian] Applying file permissions recommendations... FAILED (openhab folders)
Manually it worked, but after running OH3 again, the problem went back:
[10:59:37] root@openHABianDevice:/var/lib/openhab# sudo chown -R openhab:openhab /var/lib/openhab
[11:00:57] root@openHABianDevice:/var/lib/openhab# ls -ld /var/lib/openhab/persistence/
drwxrwxr-x 1 openhab openhab 4096 Jan  3 19:55 /var/lib/openhab/persistence/
after restart:
[11:11:51] root@openHABianDevice:/home/openhabian# ls -ld /var/lib/openhab/persistence/
drwxrwxr-x 1 openhabian openhabian 4096 Jan  4 11:07 /var/lib/openhab/persistence/
[11:11:56] root@openHABianDevice:/home/openhabian# ls -ld /var/lib/openhab/
drwxrwxr-x 9 openhab openhab 4096 Jan  4 11:05 /var/lib/openhab/
How to fix it?
Do you use ZRAM ?
In case you do then shutdown the ZRAM service before applying the directory permissions.
BINGO. I’ve uninstalled ZRAM and fixed permissions manually. After OH restart it worked without issue. For the record, “fix permissions” from openhabian still ends up with error.
Thanks @Wolfgang_S.
Now, I wonder if I should turn on ZRAM back again or leave it as it is.
It should work with ZRAM enabled.
My suggestion would be to turn ZRAM on again; check it out and in case it does not work report back.
I’ve turned ZRAM on and it worked fine in terms of the original issue I had with persistence folder permissions.
However for some reason, probably because of my ignorance about handling ZRAM, I was facing issues like crashes (restarts) of OH resulting in neverending loop while loading modules, items, rules etc.
So, I left ZRAM off for now.
