stefan13
(Stefan)
March 7, 2021, 8:50am
#1
Hello - I need some help
I defined a simple widget to display the window open state, using a switch item.
I have 2 problems which I’m stuck now:
I defined a MAP transformation in StateDescription, which is working well with the default Label List item.
The items states ‘ON/OFF’ is properly mapped to ‘Offen/Geschlossen’.
However, with my custom widget only ON/OFF is shown, seems the mapping is not applied, as in below screen shot.
The f7-chip should be shown on the right end of the widget.
However, this not working in run mode. ( see previous screenshot)
In the Widget Designer it looks as expected however:
Any idea what I did wrong?
uid: widget_WindowState
tags: []
props:
parameters:
- description: Label of the Item
label: Label
required: false
type: TEXT
- description: 'Use oh:iconName (openHAB icon), f7:iconName (Framework7 icon) or material:iconName (Material icon)'
label: Icon
required: false
type: TEXT
- context: item
description: An item to control
label: Item Name
required: false
type: TEXT
parameterGroups: []
timestamp: Mar 6, 2021, 8:57:58 PM
component: oh-list
style:
font-size: min(max(14px, 4vw), 15px)
--f7-list-inset-border-radius: 5px
box-shadow: 2px 2px 2px grey
position: relative
slots:
default:
- component: oh-list-item
title: =props.propLabel
icon: =props.propIcon
style:
margin-top: 0px
margin-bottom: 0px
--f7-list-item-border-color: transparent
slots:
after:
- component: f7-chip
text: =(items[props.item].state)
style:
--f7-chip-bg-color: "=(items[props.item].state === 'ON' ? '#4cd964' : 'red')"
--f7-chip-text-color: white
Vradatta
(Eric Zenz-Matzl)
March 7, 2021, 9:13am
#2
Try items[props.item].displayState
stefan13
(Stefan)
March 7, 2021, 9:24am
#3
Thanks a lot That solved the mapping problem.
Any idea what is causing the alignment issue?
hubsif
(Hubsi)
March 7, 2021, 10:15am
#4
Hi Stefan,
I think the issue is, that the “List Item Widget” setting expects a “list item ”, but your widget is a “(oh-)list ”. Simply removing the base oh-list
component and making the oh-list-item
the basic component should fix it, I think.
stefan13
(Stefan)
March 7, 2021, 11:35am
#5
Hi Hubsi - I replaced the oh-list
by a oh-list-item
, but then the widget disappears and I have 2 oh-list-items components cascaded.
I removed the 2nd oh-list-item
but this still doen’t work - I don’t see any widget in the Widget Designer anymore.
Seems I’m doing something wrong
hubsif
(Hubsi)
March 7, 2021, 1:29pm
#6
I shortly tried below and you’re right, it doesn’t show any preview in editmode. But it shows just fine in the list item widget selection screen.
uid: custom_listitem
tags: []
props:
parameters:
label: Label
required: false
type: TEXT
- description: Use oh:iconName (openHAB icon), f7:iconName (Framework7 icon) or material:iconName (Material icon)
label: Icon
required: false
type: TEXT
- context: item
label: Item Name
required: false
type: TEXT
parameterGroups: []
timestamp: Mar 7, 2021, 11:10:50 AM
style:
margin-top: 0px
margin-bottom: 0px
slots:
after:
style:
stefan13
(Stefan)
March 7, 2021, 3:31pm
#7
I confirm, it works in the selection screen.
Just wondering why the preview in edit mode doesn’t work. Without it its difficult to modify it
hubsif
(Hubsi)
March 7, 2021, 4:18pm
#8
Even if something would be displayed in the preview, its styling wouldn’t be reliable, since without an actual list component around it, a lot of css stylings would be missing/not applied.
So, I think for modifications you’d have to put it in a list again and remove (or comment) that list afterwards.
Edit:
For reference: Just stumbled across an open bug report about exactly this.
system
(system)
closed
April 18, 2021, 8:18am
#9
