OH3: querying thing in REST results in UID must have at least 3 segments
  • openHABian 3.4.3 on rPi4 with 4GB
I thought I have a look at the REST API.
Using it via the UI on the openHABian machine or via SSH terminal and curl, I get the same error:
curl -X GET --header "Accept: application/json" "http://192.168.1.5:8080/rest/things/smart_plug_12" -u openhab:openhab
"{\"error\":{\"message\":\"UID must have at least 3 segments: [smart_plug_12]\",\"http-code\":500,\"exception\":{\"class\":\"java.lang.IllegalArgumentException\",\"message\":\"UID must have at least 3 segments: [smart_plug_12]\",\"localized-message\":\"UID must have at least 3 segments: [smart_plug_12]\"}}}"
Copying the UI curl command and using it in a terminal shows the same error.
The thing exists and is online:
The API seem to work when issuing:
curl -X GET --header "Accept: application/json" "http://192.168.1.5:8080/rest/sitemaps"
… returning the sitemaps I have.
I also tried:
curl -X GET --header "Accept: application/json" "http://192.168.1.5:8080/items/SmartPlug_012_Voltage"
… which results in no response (as in, the cursor in the terminal comes back, indicating no reply whatsoever).
What am I missing?
You are missing the word rest.
http://192.168.1.5:8080/rest/items/SmartPlug_012_Voltage
:smiley: well spotted, thanks, but not so fast…
This is correct for the …
OK, having corrected that, I get the proper result:
# [2024-07-09 10:19] maxg@x570 ~ $
curl -X GET --header "Accept: application/json" "http://192.168.1.5:8080/rest/items/SmartPlug_012_Voltage"
{"link":"http://192.168.1.5:8080/rest/items/SmartPlug_012_Voltage","state":"243","stateDescription":{"minimum":0.0,"maximum":270.0,"step":1,"pattern":"%s","readOnly":true,"options":[]},"editable":true,"type":"Number","name":"SmartPlug_012_Voltage","label":"SP12 Voltage","category":"","tags":[],"groupNames":["grp_Smart_Plug_012"]}
However, the main problem still exists (and that has the correct syntax). :slight_smile:
OK, I figured it out…
The reference to UID must have at least 3 segments is as simple as this:
mqtt:topic:mosquitto:smart_plug_12
In my case there are four:
  1. mqtt:
  2. topic:
  3. mosquitto:
  4. smart_plug_12
… as it says “at least 3”.
Thanks in case you pondered over this.
Can you paste the command that worked so others can use it?
Sure :slight_smile:
What I posted (in O.P. #1):
What it should have been:
http://192.168.1.5:8080/rest/things/mqtt:topic:mosquitto:smart_plug_1
The full command in a terminal:
curl -X GET --header "Accept: application/json" "http://192.168.1.5:8080/rest/things/mqtt:topic:mosquitto:smart_plug_12" -u username:password
Just to provide some elaboration, the UID of a Thing has at a minimum of 4 segments. Things that work with a bridge have four. The segments are separated by :.
For a stand alone Thing the UID follows <binding_id>:<type_id>:<thing_id>. For a Thing that is under a Bridge the UID follows <binding_id>:<type_id>:<thinkg_id_from_bridge>:<thing_id>. Given mqtt:broker:mosquitto as the Thing UID for the MQTT Broker Thing (i.e. the Bridge), mqtt:topic:mosquitto:smart_plug_12 would be a UID.
All three/four+ segements make up the UID. You can’t just use the last part.
