Hi all,
I’ve set up my RFXCOM receiver with my OH3 setup, I’ve added rules to avoid issues with a different USB port being picked up and I can create the thing via the UI without a problem.
I can also manually create things for each of the devices (using the config from OH2), and they work as expected.
What doesn’t appear work at all, is Auto-discovery - I’ve checked the json configs between OH2 & OH3 and they look the same, but I get nothing picked up in the logs (set to TRACE).
Cheers
James
/etc/udev/rules.d/50-usb-serial.rules:
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{product}=="RFXtrx433", ATTRS{serial}=="A1XFDNKA" SYMLINK+="USBrfxcom", GROUP="dialout", MODE="0666"
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", SYMLINK+="USBrflink"
rfxcom thing config:
UID: rfxcom:bridge:usb0
label: RFXCOM USB Transceiver
thingTypeUID: rfxcom:bridge
configuration:
enableBlindsT0: false
enableMertik: false
enableImagintronixOpus: false
enableOregonScientific: false
enableAC: false
disableDiscovery: false
enableProGuard: false
enableATI: false
enableHomeConfort: false
enableX10: false
enableMeiantech: false
enableRSL: false
enableRubicson: false
enableHomeEasyEU: false
enableARC: false
enableLaCrosse: false
enableVisonic: false
enableUndecoded: false
serialPort: /dev/USBrfxcom
enableHidekiUPM: false
enableFS20: false
enableAEBlyss: false
enableADLightwaveRF: false
enableByronSX: false
ignoreConfig: true
transceiverType: 433.92MHz
enableBlindsT1T2T3T4: false
enableLighting4: false
enableFineOffsetViking: false
enableKEELOQ: false
transmitPower: -18
Log output:
2021-01-06 20:08:09.632 [DEBUG] [internal.handler.RFXComBridgeHandler] - Message received: Raw data = 1401000102531900800E0001011C02524658434F4D, Packet type = INTERFACE_MESSAGE, Seq number = 1, Sub type = RESPONSE, Command = GET_STATUS, Transceiver type = _433_92MHZ_TRANSCEIVER, Hardware version = 0.1, Firmware type = unknown, Firmware version = 25, Output power = 0dBm, Undecoded packets = false, RFU6 packets = false, Byron SX packets packets (433.92) = false, RSL packets packets (433.92) = false, Lighting4 packets (433.92) = false, FineOffset / Viking (433.92) packets = false, Rubicson (433.92) packets = false, AE (433.92) packets = false, BlindsT1/T2/T3 (433.92) packets = true, BlindsT0 (433.92) packets = false, ProGuard (868.35 FSK) packets = false, FS20/Legrand CAD (868.35/433.92) packets = false, La Crosse (433.92/868.30) packets = false, Hideki/UPM (433.92) packets = false, AD LightwaveRF (433.92) packets = false, Mertik (433.92) packets = false, Visonic (315/868.95) packets = false, ATI (433.92) packets = false, Oregon Scientific (433.92) packets = false, Meiantech (433.92) packets = false, HomeEasy EU (433.92) packets = true, AC (433.92) packets = true, ARC (433.92) packets = true, X10 (310/433.92) packets = false, HomeConfort (433.92) packets = false, KEELOQ (433.92/868.95) packets = false
2021-01-06 20:08:09.638 [DEBUG] [internal.handler.RFXComBridgeHandler] - RFXCOM transceiver/receiver type: _433_92MHZ_TRANSCEIVER, hw version: 0.1, fw version: 25
2021-01-06 20:08:09.642 [DEBUG] [internal.handler.RFXComBridgeHandler] - Ignoring transceiver configuration
2021-01-06 20:08:09.645 [DEBUG] [internal.handler.RFXComBridgeHandler] - Start receiver
2021-01-06 20:08:09.648 [TRACE] [rnal.connector.RFXComSerialConnector] - Send data (len=14): 0D00000307000000000000000000
2021-01-06 20:08:09.933 [TRACE] [nternal.connector.RFXComStreamReader] - Message length is 20 bytes
2021-01-06 20:08:09.936 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 20 bytes from the message
2021-01-06 20:08:09.939 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.942 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 19 bytes from the message
2021-01-06 20:08:09.946 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.949 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 18 bytes from the message
2021-01-06 20:08:09.953 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.957 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 17 bytes from the message
2021-01-06 20:08:09.960 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.963 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 16 bytes from the message
2021-01-06 20:08:09.967 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.970 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 15 bytes from the message
2021-01-06 20:08:09.974 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.977 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 14 bytes from the message
2021-01-06 20:08:09.981 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.984 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 13 bytes from the message
2021-01-06 20:08:09.987 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.990 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 12 bytes from the message
2021-01-06 20:08:09.994 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:09.997 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 11 bytes from the message
2021-01-06 20:08:10.001 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.004 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 10 bytes from the message
2021-01-06 20:08:10.009 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.013 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 9 bytes from the message
2021-01-06 20:08:10.016 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.020 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 8 bytes from the message
2021-01-06 20:08:10.023 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.028 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 7 bytes from the message
2021-01-06 20:08:10.032 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.036 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 6 bytes from the message
2021-01-06 20:08:10.039 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.043 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 5 bytes from the message
2021-01-06 20:08:10.046 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.049 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 4 bytes from the message
2021-01-06 20:08:10.053 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.056 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 3 bytes from the message
2021-01-06 20:08:10.060 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.065 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 2 bytes from the message
2021-01-06 20:08:10.069 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.072 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 1 bytes from the message
2021-01-06 20:08:10.076 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:08:10.080 [DEBUG] [internal.handler.RFXComBridgeHandler] - Message received: Raw data = 1401070307436F7079726967687420524658434F4D, Packet type = INTERFACE_MESSAGE, Seq number = 3, Sub type = START_RECEIVER, Command = START_RECEIVER, Text = Copyright RFXCOM
2021-01-06 20:08:10.085 [DEBUG] [internal.handler.RFXComBridgeHandler] - Start TX of any queued messages
2021-01-06 20:09:09.460 [TRACE] [internal.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = ONLINE
2021-01-06 20:09:40.898 [DEBUG] [internal.handler.RFXComBridgeHandler] - Handler disposed.
2021-01-06 20:09:40.912 [DEBUG] [rnal.connector.RFXComSerialConnector] - Disconnecting
2021-01-06 20:09:43.921 [DEBUG] [rnal.connector.RFXComSerialConnector] - Serial port event listener stopped
2021-01-06 20:09:43.931 [DEBUG] [rnal.connector.RFXComSerialConnector] - Interrupt serial listener
2021-01-06 20:09:43.942 [DEBUG] [nternal.connector.RFXComStreamReader] - Data listener stopped
2021-01-06 20:09:43.946 [DEBUG] [rnal.connector.RFXComSerialConnector] - Close serial out stream
2021-01-06 20:09:43.951 [DEBUG] [rnal.connector.RFXComSerialConnector] - Close serial in stream
2021-01-06 20:09:43.956 [DEBUG] [rnal.connector.RFXComSerialConnector] - Close serial port
2021-01-06 20:09:43.980 [DEBUG] [rnal.connector.RFXComSerialConnector] - Closed
2021-01-06 20:09:43.997 [DEBUG] [internal.handler.RFXComBridgeHandler] - Initializing RFXCOM bridge handler
2021-01-06 20:09:44.005 [TRACE] [internal.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
2021-01-06 20:09:44.018 [DEBUG] [internal.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
2021-01-06 20:09:44.025 [DEBUG] [rnal.connector.RFXComSerialConnector] - Disconnecting
2021-01-06 20:09:44.029 [DEBUG] [rnal.connector.RFXComSerialConnector] - Closed
2021-01-06 20:09:44.078 [DEBUG] [rnal.connector.RFXComSerialConnector] - Serial port event listener started
2021-01-06 20:09:44.086 [DEBUG] [internal.handler.RFXComBridgeHandler] - Reset controller
2021-01-06 20:09:44.087 [DEBUG] [nternal.connector.RFXComStreamReader] - Data listener started
2021-01-06 20:09:44.094 [TRACE] [rnal.connector.RFXComSerialConnector] - Send data (len=14): 0D00000000000000000000000000
2021-01-06 20:09:44.416 [DEBUG] [internal.handler.RFXComBridgeHandler] - Get status of controller
2021-01-06 20:09:44.421 [TRACE] [rnal.connector.RFXComSerialConnector] - Send data (len=14): 0D00000102000000000000000000
2021-01-06 20:09:44.438 [TRACE] [nternal.connector.RFXComStreamReader] - Message length is 20 bytes
2021-01-06 20:09:44.440 [TRACE] [rnal.connector.RFXComSerialConnector] - RXTX library CPU load workaround, sleep forever
2021-01-06 20:09:44.452 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 20 bytes from the message
2021-01-06 20:09:44.457 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.466 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 19 bytes from the message
2021-01-06 20:09:44.469 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.474 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 18 bytes from the message
2021-01-06 20:09:44.479 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.483 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 17 bytes from the message
2021-01-06 20:09:44.487 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.492 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 16 bytes from the message
2021-01-06 20:09:44.496 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.500 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 15 bytes from the message
2021-01-06 20:09:44.503 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.508 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 14 bytes from the message
2021-01-06 20:09:44.512 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.516 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 13 bytes from the message
2021-01-06 20:09:44.521 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.525 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 12 bytes from the message
2021-01-06 20:09:44.529 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.534 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 11 bytes from the message
2021-01-06 20:09:44.539 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.544 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 10 bytes from the message
2021-01-06 20:09:44.549 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.554 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 9 bytes from the message
2021-01-06 20:09:44.560 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.564 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 8 bytes from the message
2021-01-06 20:09:44.571 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.577 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 7 bytes from the message
2021-01-06 20:09:44.583 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.589 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 6 bytes from the message
2021-01-06 20:09:44.595 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.601 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 5 bytes from the message
2021-01-06 20:09:44.607 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.613 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 4 bytes from the message
2021-01-06 20:09:44.618 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.635 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 3 bytes from the message
2021-01-06 20:09:44.644 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.650 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 2 bytes from the message
2021-01-06 20:09:44.658 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.663 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 1 bytes from the message
2021-01-06 20:09:44.670 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:44.684 [DEBUG] [internal.handler.RFXComBridgeHandler] - Message received: Raw data = 1401000102531900800E0001011C02524658434F4D, Packet type = INTERFACE_MESSAGE, Seq number = 1, Sub type = RESPONSE, Command = GET_STATUS, Transceiver type = _433_92MHZ_TRANSCEIVER, Hardware version = 0.1, Firmware type = unknown, Firmware version = 25, Output power = 0dBm, Undecoded packets = false, RFU6 packets = false, Byron SX packets packets (433.92) = false, RSL packets packets (433.92) = false, Lighting4 packets (433.92) = false, FineOffset / Viking (433.92) packets = false, Rubicson (433.92) packets = false, AE (433.92) packets = false, BlindsT1/T2/T3 (433.92) packets = true, BlindsT0 (433.92) packets = false, ProGuard (868.35 FSK) packets = false, FS20/Legrand CAD (868.35/433.92) packets = false, La Crosse (433.92/868.30) packets = false, Hideki/UPM (433.92) packets = false, AD LightwaveRF (433.92) packets = false, Mertik (433.92) packets = false, Visonic (315/868.95) packets = false, ATI (433.92) packets = false, Oregon Scientific (433.92) packets = false, Meiantech (433.92) packets = false, HomeEasy EU (433.92) packets = true, AC (433.92) packets = true, ARC (433.92) packets = true, X10 (310/433.92) packets = false, HomeConfort (433.92) packets = false, KEELOQ (433.92/868.95) packets = false
2021-01-06 20:09:44.704 [DEBUG] [internal.handler.RFXComBridgeHandler] - RFXCOM transceiver/receiver type: _433_92MHZ_TRANSCEIVER, hw version: 0.1, fw version: 25
2021-01-06 20:09:44.709 [DEBUG] [internal.handler.RFXComBridgeHandler] - Ignoring transceiver configuration
2021-01-06 20:09:44.712 [DEBUG] [internal.handler.RFXComBridgeHandler] - Start receiver
2021-01-06 20:09:44.720 [TRACE] [rnal.connector.RFXComSerialConnector] - Send data (len=14): 0D00000307000000000000000000
2021-01-06 20:09:45.014 [TRACE] [nternal.connector.RFXComStreamReader] - Message length is 20 bytes
2021-01-06 20:09:45.020 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 20 bytes from the message
2021-01-06 20:09:45.028 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.032 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 19 bytes from the message
2021-01-06 20:09:45.041 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.045 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 18 bytes from the message
2021-01-06 20:09:45.051 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.057 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 17 bytes from the message
2021-01-06 20:09:45.066 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.070 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 16 bytes from the message
2021-01-06 20:09:45.073 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.076 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 15 bytes from the message
2021-01-06 20:09:45.080 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.083 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 14 bytes from the message
2021-01-06 20:09:45.087 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.091 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 13 bytes from the message
2021-01-06 20:09:45.094 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.098 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 12 bytes from the message
2021-01-06 20:09:45.102 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.106 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 11 bytes from the message
2021-01-06 20:09:45.110 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.114 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 10 bytes from the message
2021-01-06 20:09:45.118 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.122 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 9 bytes from the message
2021-01-06 20:09:45.126 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.131 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 8 bytes from the message
2021-01-06 20:09:45.136 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.140 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 7 bytes from the message
2021-01-06 20:09:45.145 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.148 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 6 bytes from the message
2021-01-06 20:09:45.153 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.157 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 5 bytes from the message
2021-01-06 20:09:45.162 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.165 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 4 bytes from the message
2021-01-06 20:09:45.169 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.172 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 3 bytes from the message
2021-01-06 20:09:45.176 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.179 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 2 bytes from the message
2021-01-06 20:09:45.182 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
2021-01-06 20:09:45.187 [TRACE] [nternal.connector.RFXComStreamReader] - Waiting remaining 1 bytes from the message
2021-01-06 20:09:45.191 [TRACE] [nternal.connector.RFXComStreamReader] - Received 1 bytes from the message
