F4T4liS
(Florian L)
February 17, 2021, 2:50pm
1
Platform information:
Hardware: AMD64/RAM 2048Mo/DISK 6Go
OS: Debian x64
Java Runtime Environment: Zulu11.45 - 11.0.10
openHAB version: 3.0.1 Release build
Issue of the topic:
I’ve setup a my first OpenHab install with the cloud connector and the Alexa skill.
I can control all my items without any issue except my roller shutter
I use a HTTP Binding with the RollerShutter configuration.
With my item, all the controls are working perfectly (UP/DOWN/STOP) but when i use it with Alexa, controls are reversed (UP close the roller and DOWN open it)
Is there any solution for configuring Alexa with custom commands for this item ?
Thanks for your help
dirkdirk
(Dirk)
February 17, 2021, 3:28pm
2
Maybe this is what you are looking for:
I try to integrate my rollershutters into amazon alexa. In openHAB everything works fine, but when I ask alexa to open the rollershutters they close and vice versa. In openHAB 0 represents “open” and 100 represents “closed”. Alexa uses inverted values, 100 for “open” and 0 for “closed”.
I just could change the actionMappings and stateMappings:
Rollershutter FF_Office_Rollershutter_Control "Arbeitszimmer [%d %%]" <rollershutter> (FF_Office, gRollershutter, gRollershutterSouth)…
F4T4liS
(Florian L)
February 17, 2021, 3:43pm
3
Oh thanks it look like my problem.
Sorry for the “dumb” question, but i don’t understand how to use the solution (i’m new to Openhab)
Where am I supposed to use this line ?
Rollershutter Blind "Blind" {alexa="RangeController.rangeValue" [category="INTERIOR_BLIND", friendlyNames="@Setting.Opening", supportedRange="0:100:10", unitOfMeasure="Percent", actionMappings="Close=100,Open=0,Lower=(+10),Raise=(-10)", stateMappings="Closed=100,Open=0:99"]}
dirkdirk
(Dirk)
February 17, 2021, 10:32pm
4
I don’t use Alexa, but this should all be available to add via meta data in UI.
Go to your item, add meta data.
Amazon Alexa, Alexa Class RangeController.rangeValue and then add the values posted before.
F4T4liS
(Florian L)
February 17, 2021, 10:51pm
5
It works, thanks a lot for your help
