Platform information:
Raspbian GNU/Linux 10 (buster)
Kernel -> Linux 5.4.79-v7l+
Raspberry Pi 4 Model B Rev 1.4
OpenJDK Runtime Environment Zulu11.43+100-CA (build 11.0.9.1+1-LTS)
openHAB 3.0.0.0-1
Trying to follow Yannicks presentation during the Virtual Meetup. I choose Model in the left column, click Add Location, enter values (tried Yannicks values: gGF…) and the click either on the line saying Type or Semantic Class, a popup opens and now:
regardless what I choos / click in the popup I will be thrown back to the Setting start page and no entry in Semantic Model is saved.
Am I doing something wrong? From other threads I get the impressing that this UI modelling should be working.
I copied Yannicks entries exactly; Name gGF, Label Ground Floor, click Category, type grou… select groundFloor (icon changes), click Semantic Class, choose GroundFloor - and boom: I am back at top level Settings in the left Navigation column.
Maybe the developers will give us a word how to handle this in accordance to their own priorities and plans. For the time being as a workaround: Goggle Chrome seems OK on Windows 10 and macOS.
Most of the devs are on holiday break. So this doesn’t get forgotten, I still recommend filing an issue at the openhab-webuis repo. The template of the issue will tell you how to gather a bunch of information that they will need to diagnose and fix something like this including logs from the browser’s developers console.
This is happening erratically and it’s quite irritating. I’ve never been able to pinpoint the exact problem but it seems the framework7 router gets confused does a “double back” when and you click back once, not even sure if it’s a bug we have to escalate or not. It’s usually solved with a page refresh.
