Hello! I bought a sonoff mini relay but I can’t add in OH3.
Could you tell me how need to setup?
Thank You!
Thank You!
The thing is, the sonoff devices usually talk with the sonoff cloud service.
So interfacing with openhab is usually done by flashing tasmota to the sonoff device (but i couldn’t find an instruction for the MINIR2) and then you interface them using MQTT
It’s very new, tasmota allready have the template, but the way to flash tasmota is still a problem. Give it some time and search flash tasmota. After that you should install mqtt server (mosquito) and configure mqtt binding. You will find a lot of information for that here in the documentation and forum.
