Since starting with OH3 I’ve struggled to find a way to create an item with mutliple options (mappings). In OH2 I did it like it’s described here:
And in my sitemap I had things like:
I’d looked through all the docs but couldn’t see how to do this in OH3 but when I finally worked it out it looks really cool and I figured it was worth sharing a guide incase any one else is struggling or if anyone can suggest how I could improve further.
So this is how I did it: To start I create an item ‘HDMI 1’ as a number and pop that as a point in a piece of equipment in the semantic model:
Then I added metadata to the those item and add ‘Command Options’ in this list. From the screen shot you can see how I map some states to labels:
Now when you click that item from a widget you get a pop up list from which you can select the labels and that gives the item that state:
The last bit is just to create a rule that does something when the item ‘HDMI 1’ in this case is updated. Mine just posts from Http requests:
Note there’s 6 outputs to 6 ‘ifs’ however i only have four bits of kit connected at the moment so only 4 command options. It’s great how to add kit I just need to add a few lines in there.
The only part I’d like some advice on is as my ‘selection’ is state-less i.e. mine fires an IR code I reset to the state to NULL as don’t know if it’s been changed in another way, so I’d like to hide the number in the widget:
Is there a way to do that?
Anyway hopefully this will be helpful to other people.
