Hi all,
Here’s the code for a custom temperature list item widget that supports different rendering of indoor and outdoor temperatures, with the option to display a badge.
By default the widget will render outdoor temperatures and will use “outdoor grade” temperature intervals. You can change the temperature intervals by setting the “Indoor” parameter to true
The temperatures have been defined in centigrade (°C):
Temperature range name | Outdoor | Indoor | Color |
hot | >30°C | >25°C | red |
warm | 25 - 30°C | 22 - 25°C | orange |
normal | 15 - 25°C | 18 - 22°C | green |
cool | 10 - 15°C | 16 - 18°C | blue |
cold | 0-10°C | 0 - 16°C | blue |
freezing | <0°C | <0°C | purple |
Code
uid: temperature_list
tags:
- list
- temperature
props:
parameters:
- description: Widget title
label: Title
required: false
type: TEXT
- context: item
description: Temperature item to display
label: Item
required: true
type: TEXT
- defaultValue: 'false'
description: Indoor temperature
label: Indoor
required: false
type: BOOLEAN
- description: Show badge instead of temperature
label: Show badge
required: false
type: BOOLEAN
parameterGroups: []
timestamp: 'Jun 12, 2021, 10:09:30 AM'
component: oh-label-item
icon: 'f7:thermometer'
iconColor: >-
=(!Number.isFinite(Number.parseFloat(items[props.item].state))) ? "gray" :
(Number.parseFloat(items[props.item].state) > (props.indoor ? 25 : 30)) ?
"red" : (Number.parseFloat(items[props.item].state) > (props.indoor ? 22 :
25)) ? "orange" : (Number.parseFloat(items[props.item].state) >
(props.indoor ? 18 : 15)) ? "green" :
(Number.parseFloat(items[props.item].state) > 0) ? "blue" : "purple"
title: =props.title
item: =props.item
action: analyzer
actionAnalyzerCoordSystem: time
actionAnalyzerItems: '=[props.item]'
badgeColor: >-
badge: >-
=(!showBadge) ? "" :
(!Number.isFinite(Number.parseFloat(items[props.item].state))) ? "error" :
"hot" : (Number.parseFloat(items[props.item].state) > (props.indoor ? 22 :
25)) ? "warm" : (Number.parseFloat(items[props.item].state) > (props.indoor
? 18 : 15)) ? "normal" : (Number.parseFloat(items[props.item].state) >
(props.indoor ? 16 : 10)) ? "cool" :
(Number.parseFloat(items[props.item].state) > 0) ? "cold" : "freezing"
Unfortunately there’s no support yet for defaultValue
parameter settings in openHAB3.0.2. By default both BOOLEAN
parameters have been defined so that they read false
when undefined.
It appears that defaultValue
for widget parameters might be supported soon:
Have fun!
