I am using " org.openhab.binding.tinkerforge-2.5.0-14-SNAPSHOT.jar " addons as binding for my Tinkerforge sensors with version OH2. It is working fine.
I installed a new test OH3 on a raspberry PI on a fresh SD card and it is working fine (still learning !!).
But did not find the OH3 binding for Tinkerforge in the binding list.
Try to add the “org.openhab.binding.tinkerforge-2.5.0-14-SNAPSHOT. jar” file to the addons folder (/usr/share/openhab/addons) without success: access denied. Cannot change the permissions on this folder.
Hi Thank you for the info.
But how do I add the “org.openhab.binding.tinkerforge-2.5.0-14-SNAPSHOT.jar” to the addons folder?
I receive an access denied if i try to add the file to the folder…
how did you try to change the permission ? How did you try to add it to the folder ?
Latest doing that with sudo or using a root shell you have to be able to do so.
I have the jar file on my pc and having some problems with the sudo commands (still learning) to transfer the jar file from the pc to the addons folder on the raspberry.
When login via ssh is enabled on your Pi then you can use winscp ( using scp resp. sftp protocol ) to copy the file from PC to e.g. /tmp folder using any user that has a login account.
In case have you have a login account for openhab you can use this way to copy the file directly to the target directory.
In case you cannot create new directories / files via samba try to login as user that owns the directory on the Pi. In case there is no login available for the target user:group you can add
force user = openhab
force group = openhab
to the related section in the samba configuration. This will force all the activities ( create directory, created file, write … ) to user openhab:openhab.
Thanks,
I could add the tinkerforge 2.5 jar file to the addons folder.
But after rebooting the openhab PI , the binding is not listed.
Did i forgot something or is the 2.5 binding not compatible with the OH3 bindings?
Do i have to wait until someone makes a OH3 Tinkerforge binding?
Patrick
