Hello I am having a connection problem in “WAN” mode with the Android app, I use the “token” as login and in “LAN” it works very well, if I switch to “WAN” on the other hand I have a error message “http 401” httpClient $ HttpExeption / UNAUTHORIZED, I nevertheless have access to my “myopenhab” and see my UI in http but not through the Android App, I also tried the “login mode” “+” pwd "but that doesn’t change anything. Where does my problem come from?
ps: I have correctly installed the binding with used “UUID” and “Secret” and I can connect online via Chrome or other, thank you in advance, because I am lost
in fact with OH2 I have no problem, now I created a new myopenhab account to use OH3
, to connect via the android app I use the token and locally it’s going very well, in “wan” impossible, even if I remove the token and that I use my login and password “myopenhab”
I tried to get the remote connection with the token again ( unsuccessful!), when setting it back I had to completely close the app in order to get a connection.
