During development there are nightly SNAPSHOT builds to test all components together.
After things look reasonably stable there will be a Milestone build to get a larger testing group. As release nears there may be Release Candidate builds in this repo.
About once a year there is a Stable release and development starts with SNAPSHOTS for the next version. Stable versions sometimes have patch releases.
3.0.x is the Stable release with 3.0.2 being the latest patch version.
3.1.0M3 is the latest 3.1.0 Milestone release
There are also nightly 3.1.0-SHAPSHOT releases.I am not sure if they are designated by build number or date.
Everything you said is correct except for the timing. The goal, and as with any goal they are not always reached are:
Version
Frequency
Current
SNAPSHOT
Daily
>Build #2336+ (I don’t know how far behind I am)
Milestones
Monthly
3.1.0 M3
Release
Every 6 months
3.0.2
So OH 3.1 release should happen sometime around late June/early July. There were apparently some problems in March that prevented M3 from being released there so I would expect M4 to be release sometime before the end of May.
The release timing got messed up in the transition from 2.5 to 3.0 but I see every indication that the devs are at least trying to follow this overall release schedule again.
The SNAPSHOTS are indeed defined by a build number which really helps when filing bugs. The SNAPSHOTS are a moving target and should only be run by people willing to do some debugging and filing issues from time to time. You can find the build number in MainUI under “Help and About”. For example I’m currently running openHAB 3.1.0 Build #2336 which is a few days behind I think.
