OH3 Widget Image Switch
I am trying to design a widget that looks like a real life light switch that visually toggles when switched on or off. I have two images that represent the ON and OFF states.
ON:
OFF:
So far I have an image card that displays the OFF image and actually switches the lamp on and off. However, I want the displayed image to toggle according to current state, i.e. change to the OFF-image when the is actually off.
This is my widget so far:
uid: LightSWitch
tags: []
props:
  parameters:
    - description: A text prop
      label: Prop 1
      required: false
      type: TEXT
    - context: item
      description: An item to control
      label: Item
      required: false
      type: TEXT
  parameterGroups: []
timestamp: May 1, 2021, 2:05:08 PM
component: oh-image-card
  action: toggle
  actionItem: BuroDeckenlicht_4_STATE
  actionCommand: ON
  url: /static/buttons/switch_white_square_OFF.png
  actionCommandAlt: OFF
The switching works fine, but how can I toggle the image as well?
Thanks for any assistance on this one.
Rob
Here’s one example:
Hi BiloxiGeek,
I tried that solution first, and it works, but I don’t want to see the toggle switch. So I abandoned it.
Thanks any way.
Rob
The values in the yaml can all be given as expressions. If you look through the code of most widget examples available here you will see at least one line that looks like this:
"=(test) ? some value : some other value"
This is a ternary operation which reads “If the test is true then use some value, otherwise use some other value”. You can use this in your url config. Test for the state of your switch item and return either the url for the first image or the second.
Hi Justin,
now I would have never thought about using a ternary operation for the URL. Thanks for that. But for some unknown reason to me, the test is never returning true. The light switches fine, but the image stays as the OFF image.
tags: []
props:
  parameters:
      label: Prop 1
      required: false
      type: TEXT
    - context: item
      label: Item
      required: false
      type: TEXT
  parameterGroups: []
timestamp: May 2, 2021, 5:27:14 PM
  action: toggle
  actionItem: =(props.item)
  actionCommand: ON
  url: "=(props.item === 'ON') ? '/static/buttons/switch_white_square_ON_Red.png' : '/static/buttons/switch_white_square_OFF.png'"
It’s probably something so simple as always. I’ve tried different combinations, but no success so far.
Rob
props.item is just a string containing the name of the item. It is not the state of the item. To get the state in the widget yaml you would use the items object:
items[props.item].state
Lol, I just found that out myself. But many thanks for your assistance and the explanation. Much appreciated.
Rob
