- Platform information:
- Hardware: amd64
- OS: Windows 10/10.0 (amd64)
- Java Runtime Environment: 11.0.14.1 (Zulu11.54+25-CA)
- openHAB version: openHAB 3.4.0.M1
I have noticed that whenever I restart openHAB via the Service Wrapper I have an additional log file folder created:
This folder contains an openhab.log file, but this never gets updated (only created).
If I start openHAB via the c:\openHAB\start.bat the additional folder is not created.
I have recreated the service using the latest version of the documentation with a C:\openHAB\userdata\etc\openHAB-wrapper.conf as follows from the docs:
# openHAB-wrapper.conf for Windows Service Installation
# openHAB installation dir (Adapt this first setting to your system)
set.default.OPENHAB_HOME=C:\openHAB
# Wrapper Properties
set.default.OPENHAB_CONF=%OPENHAB_HOME%\conf
set.default.OPENHAB_RUNTIME=%OPENHAB_HOME%\runtime
set.default.OPENHAB_USERDATA=%OPENHAB_HOME%\userdata
set.default.OPENHAB_LOGDIR=%OPENHAB_USERDATA%\logs
set.default.KARAF_HOME=%OPENHAB_RUNTIME%
set.default.KARAF_BASE=%OPENHAB_USERDATA%
set.default.KARAF_DATA=%OPENHAB_USERDATA%
set.default.KARAF_ETC=%OPENHAB_USERDATA%\etc
set.default.PATH=%PATH%;%KARAF_BASE%\lib;%KARAF_HOME%\lib
# Java Application
wrapper.working.dir=%KARAF_BASE%
wrapper.java.command=%JAVA_HOME%\bin\java
wrapper.java.mainclass=org.apache.karaf.wrapper.internal.service.Main
wrapper.java.classpath.1=%KARAF_HOME%\lib\boot\*.jar
wrapper.java.classpath.2=%KARAF_DATA%\lib\wrapper\*.jar
wrapper.java.classpath.3=%KARAF_HOME%\lib\jdk9plus\*.jar
wrapper.java.classpath.4=%KARAF_HOME%\lib\endorsed\*.jar
wrapper.java.library.path.1=%KARAF_DATA%\lib\wrapper\
# Java Parameters
wrapper.java.additional.1=-Dkaraf.home="%KARAF_HOME%"
wrapper.java.additional.2=-Dkaraf.base="%KARAF_BASE%"
wrapper.java.additional.3=-Dkaraf.data="%KARAF_DATA%"
wrapper.java.additional.4=-Dkaraf.etc="%KARAF_ETC%"
wrapper.java.additional.5=-Dcom.sun.management.jmxremote
wrapper.java.additional.6=-Dkaraf.startLocalConsole=false
wrapper.java.additional.7=-Dkaraf.startRemoteShell=true
wrapper.java.additional.8=-Dopenhab.home="%OPENHAB_HOME%"
wrapper.java.additional.9=-Dopenhab.conf="%OPENHAB_HOME%\conf"
wrapper.java.additional.10=-Dopenhab.runtime="%OPENHAB_HOME%\runtime"
wrapper.java.additional.11=-Dopenhab.userdata="%OPENHAB_HOME%\userdata"
wrapper.java.additional.12=-Dopenhab.logdir="%OPENHAB_USERDATA%\logs"
wrapper.java.additional.13=-Dfelix.cm.dir="%OPENHAB_HOME%\userdata\config"
wrapper.java.additional.14=-Dorg.osgi.service.http.port=8080
wrapper.java.additional.15=-Dorg.osgi.service.http.port.secure=8443
wrapper.java.additional.16=-Djava.util.logging.config.file="%KARAF_ETC%\java.util.logging.properties"
wrapper.java.additional.17=-Dkaraf.logs="%OPENHAB_LOGDIR%"
wrapper.java.additional.18=-Dfile.encoding=UTF-8
wrapper.java.maxmemory=512
# Wrapper Logging Properties
wrapper.console.format=PM
wrapper.console.loglevel=INFO
wrapper.logfile=%OPENHAB_USERDATA%\logs\wrapper.log
wrapper.logfile.format=LPTM
wrapper.logfile.loglevel=INFO
wrapper.logfile.maxsize=10m
wrapper.logfile.maxfiles=5
wrapper.syslog.loglevel=NONE
# Wrapper Windows Properties
wrapper.console.title=openHAB
wrapper.ntservice.name=openHAB
wrapper.ntservice.displayname=openHAB
wrapper.ntservice.description=openHAB Service
wrapper.ntservice.dependency.1=
wrapper.ntservice.starttype=AUTO_START
wrapper.ntservice.interactive=false
I also noticed that the “incorrect” folder log with no “s” is created a while before the correct folder.
Any suggestions on where this issue may be coming from?
Mark
