- Platform information:
- Hardware: Raspberry Pi 4
- OS: openhabian 5.10.63-v7+
- Java Runtime Environment: Zulu11.52+13-CA (build 11.0.13+8-LTS)
- openHAB version: 3.2.0
- Issue of the topic: OH3: Write rule for Hank SCN01
- Please post configurations (if applicable):
None that seams to give any clues.
Now the Hank SCN01 one button scenen controller seams to be included fine with OpenHAB. Next step is to write a working rule for it.
I have tried creating a rule in the UI, but it seams not to be triggered.
I thought about trying to write a rule-file, like the one I have for Neeo forwardactions, but it relies on trigger events and I can’t see any of those for the Hank.
2021-12-22 13:46:09.372 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 0F 05 5B 03 26 00 01 85
2021-12-22 13:46:09.376 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 05 5B 03 26 00 01
2021-12-22 13:46:09.379 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 05 5B 03 26 00 01
2021-12-22 13:46:09.385 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-12-22 13:46:09.387 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DELETE_ROUTES)
2021-12-22 13:46:09.389 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2021-12-22 13:46:09.391 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-22 13:46:09.394 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_CENTRAL_SCENE V2 CENTRAL_SCENE_NOTIFICATION
2021-12-22 13:46:09.396 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 15: Received scene 1 at key 0 [Single Press]
2021-12-22 13:46:09.398 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-22 13:46:09.401 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CENTRAL_SCENE, value=1.0
2021-12-22 13:46:09.403 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:scene_number to 1.0 [DecimalType]
2021-12-22 13:46:09.407 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-22 13:46:09.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10d6740.
2021-12-22 13:46:09.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-12-22 13:46:09.414 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-12-22 13:46:09.416 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-12-22 13:46:09.418 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-12-22 13:46:09.864 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 0F 03 80 03 64 19
2021-12-22 13:46:09.868 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 03 80 03 64
2021-12-22 13:46:09.871 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=15, callback=0, payload=00 0F 03 80 03 64
2021-12-22 13:46:09.874 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-12-22 13:46:09.876 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DELETE_ROUTES)
2021-12-22 13:46:09.879 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2021-12-22 13:46:09.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-22 13:46:09.883 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2021-12-22 13:46:09.886 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 15: Battery report value = 100
2021-12-22 13:46:09.888 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-22 13:46:09.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=100
2021-12-22 13:46:09.893 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:battery-level to 100 [DecimalType]
2021-12-22 13:46:09.897 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-22 13:46:09.900 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1308638.
2021-12-22 13:46:09.902 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-12-22 13:46:09.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-12-22 13:46:09.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-12-22 13:46:09.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
I have searched this forum but found no message about Hank SCN01 and rules. How would you go about solving this?
