openschwall
(Peter Mueller)
January 12, 2021, 9:26am
21
The contents of the file
http://client1:client1@192.168.0.167:83/api.html?part=redstats&label=smr
I want to parse is
<?xml version="1.0" encoding="UTF-8"?>
<os version="1uild r11643" revision="11643" starttime="2021-01-12T09:25:12+0100" uptime="4570" readonly="0">
<reader label="smr" status="CARDOK" cadid="123">
</reader>
</os>
I want to check whether the status of reader is CARDOK.
According to OH3 XPath - #3 by garyfree
I created in Main a thing named URL1 with base url
http://user:pw@192.168.0.167/api.html?part=redstats&label=smr
with channel
URLchannel
and State transformation
//reader/@status
as in my OH 2.5 case.
However, this generates an Error:
HANDLER_INITIALIZING_ERROR
The transformation pattern must consist of the type and the pattern separated by a colon
This is where I am stuck.
The transformation field must include the name of the transformation you’re trying to use - openHAB doesn’t try to guess, because there’s too many!
Try:
XPATH://reader/@status
though be warned that I don’t use this transform so don’t know the proper syntax.
openschwall
(Peter Mueller)
January 12, 2021, 10:02am
23
Thank you. For clarity, I have described my problem in a more detailed manner.
I will check your proposal this eveneing. Thanks!
openschwall
(Peter Mueller)
January 15, 2021, 8:24am
24
@hafniumzinc : Success. Thank you very much for your valuable hint!!!
I had to delete user:pw from base url and transfer this information to the advanced options of the thing. I use basic authentication.
In linked item, I used profile XPATH and Xpath expression //reader/@status . This seems to be equivalent to your proposal “XPATH://reader/@status ”.
Thanks!!
openschwall
(Peter Mueller)
January 15, 2021, 9:30am
25
It is fine for me to achieve this by using the new main ui.
Can I achieve this as well using the textual way? Formerly, one line of code was sufficient like this
String MyStatus “Status [%s]” {http=“<[http://user:pw@192.168.0.167/api.html?part=redstats&label=smr:30000:XPATH(//reader/@status) ]”}
Yes. Show us the YAML for your Thing and we can help convert. But bear in mind that you will have to edit two files: an Items file and a Things file. It’s not all in a single Item line anymore!
openschwall
(Peter Mueller)
January 15, 2021, 7:38pm
27
This is thing’s code:
UID: http:url:011692df79
label: URL_Easy
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: http://192.168.0.167:83/api.html?part=redstats&label=em1
password: client1
refresh: 30
commandMethod: GET
timeout: 3000
username: client1
bufferSize: 2048
channels:
channelTypeUID: http:string
label: URL Easy
description: “”
configuration:
stateTransformation: XPATH://reader/@status
Something like the following might work:
Thing http:url:URL_Easy "URL_Easy" [
baseURL = "http://192.168.0.167:83/api.html?part=redstats&label=em1",
refresh = "30",
ignoreSSLErrors = "false",
username = "client1",
password = "client1"
Channels:
Type string : URLEasy "URL Easy" [
mode = "READONLY",
stateTransformation = "XPATH://reader/@status"
Your Item then becomes:
String MyStatus "Status [%s]" { channel="http:url:URL_Easy:URLEasy" }
First, to double check did you install the Xpath Transformation Service?
