OH3 Z-wave Hank SCN01 scene controller ignored
Yes, with the rest of the button. I updated the layout picture from the manual in previous post.
Are you getting a green led by holding it down for 3 seconds?
Yes.
Well the correct message is not showing in the debug.
Maybe it is time to exclude and try again to include. Use exclude devices on the ui for the controller . Triple click for orange light. Hank ui should show device excluded by controller. If yes delete thing.
Then inbox, zwave, scan and triple press again for blue.
Bob
Edit:Have the debug on for the reinclusion.
That doesn’t work. No orange blink. I have always done include and exclude with the z-stick disconnected from the rPi. Should the “Remove device from controller” on the Hank exclude it? I have never tried that.
Aha ! It is not recommended to include (pair) a device with the zstick out of the Rpi (and OH). I think that explains why you are not getting the sleep message (and why this device is not initializing). I wish I knew that two days ago.
Going forward; I also never use the “Remove Device from the Controller” on the device page. Especially for battery devices it is problematic (IMO).
Possibly since the device was never included properly, the exclude is not working either.
I’m a little concerned about the approach I’m going to suggest below, because I think Node 14 is going to a zombie, but that could be dealt with later (hopefully).
  1. Stop OH, remove Zstick, unpair Hank with the zstick button. Get the orange blink.
  2. Put zstick back in Rpi, start OH
  3. Then inbox, zwave binding, scan and triple press Hank & see if it pops up as device Hopefully a new node number. Have the zwave in debug during this step, so we can see if issues.
Bob
OK, now we got lots of logging. It is now called node 15. weird thing was that I didn’t get the orange blink from the Hank, but the z-stick confirmed exclusion and I was able to include with OH and z-stick connected.
2021-12-05 23:06:01.827 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Found 1 instances of COMMAND_CLASS_ZWAVEPLUS_INFO for endpoint 0
2021-12-05 23:06:01.838 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:01.839 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_ZWAVEPLUS_INFO is NOT required to be secured
2021-12-05 23:06:01.840 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:01.841 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:01.842 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_ZWAVEPLUS_INFO is NOT required to be secured
2021-12-05 23:06:01.844 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@17f725e
2021-12-05 23:06:01.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 75 priority from Config to Immediate
2021-12-05 23:06:01.848 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:01.849 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 75 to queue - size 4
2021-12-05 23:06:01.853 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 5E 01 25 35 A7
2021-12-05 23:06:01.879 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:01.882 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 75: Transaction not completed
2021-12-05 23:06:01.897 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 53, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:01.900 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 75: Transaction not completed
2021-12-05 23:06:01.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:STATIC_VALUES)
2021-12-05 23:06:01.905 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_ZWAVEPLUS_INFO, endpoint 0
2021-12-05 23:06:01.906 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:01.913 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_ZWAVEPLUS_INFO V1 ZWAVEPLUS_INFO_REPORT
2021-12-05 23:06:01.915 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:01.916 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1c9165a.
2021-12-05 23:06:01.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1c9165a.
2021-12-05 23:06:01.919 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:75 DONE
2021-12-05 23:06:01.922 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:01.932 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@96e5a9
2021-12-05 23:06:01.934 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:01.935 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_BASIC
2021-12-05 23:06:01.936 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_VERSION
2021-12-05 23:06:01.936 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_NO_OPERATION
2021-12-05 23:06:01.937 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_POWERLEVEL
2021-12-05 23:06:01.938 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_ASSOCIATION
2021-12-05 23:06:01.940 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Found 1 instances of COMMAND_CLASS_ASSOCIATION for endpoint 0
2021-12-05 23:06:01.944 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: Creating new message for application command ASSOCIATIONCMD_GROUPINGSGET
2021-12-05 23:06:01.946 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:01.947 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2021-12-05 23:06:01.948 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:01.950 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:01.951 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2021-12-05 23:06:01.952 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@447e20
2021-12-05 23:06:01.953 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 76 priority from Config to Immediate
2021-12-05 23:06:01.954 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:01.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 76 to queue - size 4
2021-12-05 23:06:01.959 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 85 05 25 36 7B
2021-12-05 23:06:01.985 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:01.988 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 76: Transaction not completed
2021-12-05 23:06:02.006 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 54, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.009 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 76: Transaction not completed
2021-12-05 23:06:02.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:STATIC_VALUES)
2021-12-05 23:06:02.015 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_ASSOCIATION, endpoint 0
2021-12-05 23:06:02.016 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.018 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_ASSOCIATION V2 ASSOCIATIONCMD_GROUPINGS_REPORT
2021-12-05 23:06:02.019 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: processGroupingsReport number of groups 3
2021-12-05 23:06:02.021 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:02.022 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b8b5dd.
2021-12-05 23:06:02.024 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b8b5dd.
2021-12-05 23:06:02.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:76 DONE
2021-12-05 23:06:02.027 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.028 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@18679d4
2021-12-05 23:06:02.030 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.031 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_CONFIGURATION
2021-12-05 23:06:02.032 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to ASSOCIATIONS
2021-12-05 23:06:02.033 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:06:02.042 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: ASSOCIATIONS request group 1
2021-12-05 23:06:02.043 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: Creating new message for application command ASSOCIATIONCMD_GET group 1
2021-12-05 23:06:02.044 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.045 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.046 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2021-12-05 23:06:02.047 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@15d0ab8
2021-12-05 23:06:02.049 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 77 priority from Config to Immediate
2021-12-05 23:06:02.050 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.051 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 77 to queue - size 4
2021-12-05 23:06:02.055 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 85 02 01 25 37 7E
2021-12-05 23:06:02.074 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.075 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 77: Transaction not completed
2021-12-05 23:06:02.095 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 55, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.097 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 77: Transaction not completed
2021-12-05 23:06:02.100 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:ASSOCIATIONS)
2021-12-05 23:06:02.101 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_ASSOCIATION, endpoint 0
2021-12-05 23:06:02.102 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.103 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_ASSOCIATION V2 ASSOCIATIONCMD_REPORT
2021-12-05 23:06:02.105 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: association group 1 has max associations 5
2021-12-05 23:06:02.106 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: association group 1 includes the following nodes:
2021-12-05 23:06:02.108 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveAssociationEvent
2021-12-05 23:06:02.110 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
2021-12-05 23:06:02.111 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:02.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d5521f.
2021-12-05 23:06:02.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d5521f.
2021-12-05 23:06:02.114 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:77 DONE
2021-12-05 23:06:02.116 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.118 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@6b06d7
2021-12-05 23:06:02.119 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.120 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: ASSOCIATIONS request group 2
2021-12-05 23:06:02.121 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: Creating new message for application command ASSOCIATIONCMD_GET group 2
2021-12-05 23:06:02.122 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.125 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.126 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2021-12-05 23:06:02.127 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1cbc644
2021-12-05 23:06:02.128 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 78 priority from Config to Immediate
2021-12-05 23:06:02.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.130 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 78 to queue - size 4
2021-12-05 23:06:02.134 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 85 02 02 25 38 72
2021-12-05 23:06:02.153 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.155 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 78: Transaction not completed
2021-12-05 23:06:02.173 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 56, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 78: Transaction not completed
2021-12-05 23:06:02.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:ASSOCIATIONS)
2021-12-05 23:06:02.180 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_ASSOCIATION, endpoint 0
2021-12-05 23:06:02.181 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.182 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_ASSOCIATION V2 ASSOCIATIONCMD_REPORT
2021-12-05 23:06:02.183 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: association group 2 has max associations 5
2021-12-05 23:06:02.184 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: association group 2 includes the following nodes:
2021-12-05 23:06:02.185 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveAssociationEvent
2021-12-05 23:06:02.186 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
2021-12-05 23:06:02.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:02.188 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@abfc39.
2021-12-05 23:06:02.189 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@abfc39.
2021-12-05 23:06:02.190 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:78 DONE
2021-12-05 23:06:02.191 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.193 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1555e30
2021-12-05 23:06:02.195 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.196 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: ASSOCIATIONS request group 3
2021-12-05 23:06:02.197 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: Creating new message for application command ASSOCIATIONCMD_GET group 3
2021-12-05 23:06:02.199 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.201 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.203 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_ASSOCIATION is NOT required to be secured
2021-12-05 23:06:02.205 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@668fe8
2021-12-05 23:06:02.206 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 79 priority from Config to Immediate
2021-12-05 23:06:02.207 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.208 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 79 to queue - size 4
2021-12-05 23:06:02.212 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 85 02 03 25 39 72
2021-12-05 23:06:02.231 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.233 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 79: Transaction not completed
2021-12-05 23:06:02.251 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 57, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.253 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 79: Transaction not completed
2021-12-05 23:06:02.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:ASSOCIATIONS)
2021-12-05 23:06:02.266 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_ASSOCIATION, endpoint 0
2021-12-05 23:06:02.267 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.268 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_ASSOCIATION V2 ASSOCIATIONCMD_REPORT
2021-12-05 23:06:02.269 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: association group 3 has max associations 5
2021-12-05 23:06:02.270 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 15: association group 3 includes the following nodes:
2021-12-05 23:06:02.271 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveAssociationEvent
2021-12-05 23:06:02.273 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
2021-12-05 23:06:02.274 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:02.276 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bda4ac.
2021-12-05 23:06:02.277 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bda4ac.
2021-12-05 23:06:02.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:79 DONE
2021-12-05 23:06:02.281 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.283 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@3d784d
2021-12-05 23:06:02.284 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.286 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to SET_WAKEUP
2021-12-05 23:06:02.288 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:06:02.291 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: SET_WAKEUP - Interval is currently 0. Set to 3600
2021-12-05 23:06:02.293 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: SET_WAKEUP - Set wakeup node to controller (23), period 3600
2021-12-05 23:06:02.296 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for command WAKE_UP_INTERVAL_SET to 3600s, node 23
2021-12-05 23:06:02.298 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.301 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.304 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:06:02.306 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1d173e8
2021-12-05 23:06:02.308 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 80 priority from Config to Immediate
2021-12-05 23:06:02.309 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 80 to queue - size 4
2021-12-05 23:06:02.316 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0D 00 13 0F 06 84 04 00 0E 10 17 25 3A 7E
2021-12-05 23:06:02.338 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.341 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 80: Transaction not completed
2021-12-05 23:06:02.359 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 58, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.362 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Response processed after 42ms
2021-12-05 23:06:02.363 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 80: Transaction completed
2021-12-05 23:06:02.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:80 DONE
2021-12-05 23:06:02.366 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.368 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@421fbc
2021-12-05 23:06:02.370 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.371 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_INTERVAL_GET
2021-12-05 23:06:02.372 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.375 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.378 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:06:02.380 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@c9d9d3
2021-12-05 23:06:02.382 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 81 priority from Config to Immediate
2021-12-05 23:06:02.384 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.385 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 81 to queue - size 4
2021-12-05 23:06:02.390 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 05 25 3B 77
2021-12-05 23:06:02.412 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.414 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 81: Transaction not completed
2021-12-05 23:06:02.432 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 59, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.435 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 81: Transaction not completed
2021-12-05 23:06:02.439 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:SET_WAKEUP)
2021-12-05 23:06:02.441 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_WAKE_UP, endpoint 0
2021-12-05 23:06:02.442 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.444 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_WAKE_UP V2 WAKE_UP_INTERVAL_REPORT
2021-12-05 23:06:02.445 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Wake up interval report, value = 0 seconds, targetNodeId = 23
2021-12-05 23:06:02.447 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveWakeUpEvent
2021-12-05 23:06:02.456 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:02.464 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1648dd3.
2021-12-05 23:06:02.466 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1648dd3.
2021-12-05 23:06:02.467 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:81 DONE
2021-12-05 23:06:02.469 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.471 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@17d3497
2021-12-05 23:06:02.472 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.474 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to SET_ASSOCIATION
2021-12-05 23:06:02.475 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:06:02.488 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: SET_ASSOCIATION - ASSOCIATION node_23 set for group 1
2021-12-05 23:06:02.490 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to SET_LIFELINE
2021-12-05 23:06:02.492 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:06:02.499 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: SET_LIFELINE - Checking group 1
2021-12-05 23:06:02.501 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: SET_LIFELINE - Checking group 2
2021-12-05 23:06:02.503 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: SET_LIFELINE - Checking group 3
2021-12-05 23:06:02.505 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to GET_CONFIGURATION
2021-12-05 23:06:02.507 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:06:02.516 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: GET_CONFIGURATION - checking config_42_1 - config
2021-12-05 23:06:02.519 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: GET_CONFIGURATION - checking config_42_1 - index 42
2021-12-05 23:06:02.521 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 15: Creating new message for application command CONFIGURATIONCMD_GET
2021-12-05 23:06:02.524 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.527 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.530 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-12-05 23:06:02.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@10d4223
2021-12-05 23:06:02.538 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 82 priority from Config to Immediate
2021-12-05 23:06:02.540 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.541 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 82 to queue - size 4
2021-12-05 23:06:02.547 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 2A 25 3C AC
2021-12-05 23:06:02.568 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.570 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 82: Transaction not completed
2021-12-05 23:06:02.589 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 60, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.592 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 82: Transaction not completed
2021-12-05 23:06:02.597 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-12-05 23:06:02.599 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2021-12-05 23:06:02.600 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.602 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2021-12-05 23:06:02.603 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 15: Node configuration report, parameter = 42, value = -1, size = 1
2021-12-05 23:06:02.605 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2021-12-05 23:06:02.607 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@16780a
2021-12-05 23:06:02.609 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Update CONFIGURATION 42/1 to -1
2021-12-05 23:06:02.611 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:02.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19b1a85.
2021-12-05 23:06:02.614 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@19b1a85.
continued:
2021-12-05 23:06:02.615 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:82 DONE
2021-12-05 23:06:02.617 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.620 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1200ec1
2021-12-05 23:06:02.621 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.623 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: GET_CONFIGURATION - checking config_254_1 - config
2021-12-05 23:06:02.624 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: GET_CONFIGURATION - checking config_254_1 - index 254
2021-12-05 23:06:02.626 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 15: Creating new message for application command CONFIGURATIONCMD_GET
2021-12-05 23:06:02.628 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.631 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.632 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-12-05 23:06:02.635 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@17956b7
2021-12-05 23:06:02.637 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 83 priority from Config to Immediate
2021-12-05 23:06:02.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.641 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 83 to queue - size 4
2021-12-05 23:06:02.647 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FE 25 3D 79
2021-12-05 23:06:02.675 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 83: Transaction not completed
2021-12-05 23:06:02.698 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 61, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 83: Transaction not completed
2021-12-05 23:06:02.706 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-12-05 23:06:02.708 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2021-12-05 23:06:02.710 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.712 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2021-12-05 23:06:02.714 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 15: Node configuration report, parameter = 254, value = 0, size = 1
2021-12-05 23:06:02.716 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2021-12-05 23:06:02.717 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@76429e
2021-12-05 23:06:02.719 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Update CONFIGURATION 254/1 to 0
2021-12-05 23:06:02.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:02.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18b5796.
2021-12-05 23:06:02.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18b5796.
2021-12-05 23:06:02.726 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:83 DONE
2021-12-05 23:06:02.729 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:02.734 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1121683
2021-12-05 23:06:02.735 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:06:02.737 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: GET_CONFIGURATION - checking config_255_4 - config
2021-12-05 23:06:02.739 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: GET_CONFIGURATION - checking config_255_4 - index 255
2021-12-05 23:06:02.740 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 15: Creating new message for application command CONFIGURATIONCMD_GET
2021-12-05 23:06:02.753 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:02.754 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:02.756 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-12-05 23:06:02.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@15398
2021-12-05 23:06:02.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 84 priority from Config to Immediate
2021-12-05 23:06:02.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:02.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 84 to queue - size 4
2021-12-05 23:06:02.771 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 3E 7B
2021-12-05 23:06:02.821 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:02.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 84: Transaction not completed
2021-12-05 23:06:02.860 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 62, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:02.863 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 84: Transaction not completed
2021-12-05 23:06:04.286 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:06:04.287 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: No more messages, go back to sleep
2021-12-05 23:06:04.288 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-12-05 23:06:04.289 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:04.290 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:06:04.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@34ad15
2021-12-05 23:06:04.293 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 85 priority from Immediate to Immediate
2021-12-05 23:06:04.295 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:04.296 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 85 to queue - size 4
2021-12-05 23:06:07.863 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 84: Timeout at state WAIT_DATA. 3 retries remaining.
2021-12-05 23:06:07.866 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:07.867 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:84 CANCELLED
2021-12-05 23:06:07.871 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1a001df
2021-12-05 23:06:07.873 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: No data from device, but it was ACK'd. Possibly not supported? (Try 0)
2021-12-05 23:06:07.874 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 08 25 3F 7E
2021-12-05 23:06:07.894 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:07.896 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 85: Transaction not completed
2021-12-05 23:06:08.659 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:08.660 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:08.661 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-12-05 23:06:08.662 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@15398
2021-12-05 23:06:08.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 86 priority from Config to Immediate
2021-12-05 23:06:08.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:08.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 86 to queue - size 4
2021-12-05 23:06:12.896 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 85: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:06:16.110 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 63, Status = Transmission complete, no ACK received(1)
2021-12-05 23:06:16.112 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2021-12-05 23:06:16.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 85: Transaction not completed
2021-12-05 23:06:24.900 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 85: Timeout at state ABORTED. 3 retries remaining.
2021-12-05 23:06:24.904 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:24.905 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:85 CANCELLED
2021-12-05 23:06:24.908 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Went to sleep COMPLETE
2021-12-05 23:06:24.909 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 40 05
2021-12-05 23:06:24.932 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:24.934 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 86: Transaction not completed
2021-12-05 23:06:29.934 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 86: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:06:33.188 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 64, Status = Transmission complete, no ACK received(1)
2021-12-05 23:06:33.190 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:33.191 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: CANCEL while sending message. Requeueing - 2 attempts left!
2021-12-05 23:06:33.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:33.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 86 to queue - size 4
2021-12-05 23:06:33.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 86: Transaction not completed
2021-12-05 23:06:33.669 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update request. Node information received. Transaction null
2021-12-05 23:06:33.670 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update - no transaction.
2021-12-05 23:06:33.922 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Is awake with 1 messages in the queue
2021-12-05 23:06:33.923 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Start sleep timer at 5000ms
2021-12-05 23:06:33.925 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2021-12-05 23:06:33.933 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 15: Node Status event - Node is AWAKE
2021-12-05 23:06:35.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-12-05 23:06:35.651 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2021-12-05 23:06:35.652 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:35.653 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2021-12-05 23:06:35.654 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 15: Battery report value = 60
2021-12-05 23:06:35.655 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-05 23:06:35.656 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=60
2021-12-05 23:06:35.657 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:battery-level to 60 [DecimalType]
2021-12-05 23:06:35.658 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:06:35.659 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@abd85.
2021-12-05 23:06:35.666 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 41 04
2021-12-05 23:06:35.685 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:35.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 86: Transaction not completed
2021-12-05 23:06:35.704 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 65, Status = Transmission complete and ACK received(0)
2021-12-05 23:06:35.706 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 86: Transaction not completed
2021-12-05 23:06:36.425 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:06:38.925 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:06:38.927 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: No more messages, go back to sleep
2021-12-05 23:06:38.928 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-12-05 23:06:38.929 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:38.930 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:06:38.931 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1913a5a
2021-12-05 23:06:38.932 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 87 priority from Immediate to Immediate
2021-12-05 23:06:38.933 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:38.934 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 87 to queue - size 4
2021-12-05 23:06:40.706 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 86: Timeout at state WAIT_DATA. 2 retries remaining.
2021-12-05 23:06:40.709 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:40.710 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:86 CANCELLED
2021-12-05 23:06:40.713 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (1) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@f3ff2
2021-12-05 23:06:40.714 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: No data from device, but it was ACK'd. Possibly not supported? (Try 1)
2021-12-05 23:06:40.715 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 08 25 42 03
2021-12-05 23:06:40.730 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:40.731 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 87: Transaction not completed
2021-12-05 23:06:42.487 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:06:42.488 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:06:42.489 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-12-05 23:06:42.490 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@15398
2021-12-05 23:06:42.492 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 88 priority from Config to Immediate
2021-12-05 23:06:42.493 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:06:42.494 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 88 to queue - size 4
2021-12-05 23:06:45.732 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 87: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:06:49.080 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 66, Status = Transmission complete, no ACK received(1)
2021-12-05 23:06:49.081 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2021-12-05 23:06:49.082 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 87: Transaction not completed
2021-12-05 23:06:57.736 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 87: Timeout at state ABORTED. 3 retries remaining.
2021-12-05 23:06:57.739 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:06:57.740 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:87 CANCELLED
2021-12-05 23:06:57.743 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Went to sleep COMPLETE
2021-12-05 23:06:57.745 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 43 06
2021-12-05 23:06:57.765 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:06:57.766 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 88: Transaction not completed
2021-12-05 23:07:02.767 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 88: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:07:06.129 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 67, Status = Transmission complete, no ACK received(1)
2021-12-05 23:07:06.131 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:07:06.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: CANCEL while sending message. Requeueing - 2 attempts left!
2021-12-05 23:07:06.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:07:06.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 88 to queue - size 4
2021-12-05 23:07:06.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 88: Transaction not completed
2021-12-05 23:07:13.538 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update request. Node information received. Transaction null
2021-12-05 23:07:13.539 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update - no transaction.
2021-12-05 23:07:13.791 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Is awake with 1 messages in the queue
2021-12-05 23:07:13.792 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Start sleep timer at 5000ms
2021-12-05 23:07:13.793 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2021-12-05 23:07:13.802 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 15: Node Status event - Node is AWAKE
2021-12-05 23:07:15.517 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-12-05 23:07:15.518 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2021-12-05 23:07:15.518 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:07:15.519 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2021-12-05 23:07:15.520 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 15: Battery report value = 59
2021-12-05 23:07:15.521 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-05 23:07:15.522 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=59
2021-12-05 23:07:15.523 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:battery-level to 59 [DecimalType]
2021-12-05 23:07:15.526 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:07:15.527 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1bedef3.
2021-12-05 23:07:15.531 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 44 01
2021-12-05 23:07:15.547 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:07:15.548 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 88: Transaction not completed
2021-12-05 23:07:15.564 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 68, Status = Transmission complete and ACK received(0)
2021-12-05 23:07:15.566 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 88: Transaction not completed
2021-12-05 23:07:16.294 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:07:18.793 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:07:18.794 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: No more messages, go back to sleep
2021-12-05 23:07:18.795 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-12-05 23:07:18.796 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:07:18.797 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:07:18.798 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@8d85fb
2021-12-05 23:07:18.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 89 priority from Immediate to Immediate
2021-12-05 23:07:18.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:07:18.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 89 to queue - size 4
2021-12-05 23:07:20.566 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 88: Timeout at state WAIT_DATA. 2 retries remaining.
and final part:
2021-12-05 23:07:20.570 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:07:20.571 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:88 CANCELLED
2021-12-05 23:07:20.574 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (2) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@122877e
2021-12-05 23:07:20.575 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: No data from device, but it was ACK'd. Possibly not supported? (Try 2)
2021-12-05 23:07:20.575 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 08 25 45 04
2021-12-05 23:07:20.595 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:07:20.597 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 89: Transaction not completed
2021-12-05 23:07:25.013 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:07:25.015 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:07:25.015 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-12-05 23:07:25.016 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@15398
2021-12-05 23:07:25.017 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 90 priority from Config to Immediate
2021-12-05 23:07:25.018 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:07:25.019 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 90 to queue - size 4
2021-12-05 23:07:25.597 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 89: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:07:28.929 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 69, Status = Transmission complete, no ACK received(1)
2021-12-05 23:07:28.930 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2021-12-05 23:07:28.930 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 89: Transaction not completed
2021-12-05 23:07:37.603 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 89: Timeout at state ABORTED. 3 retries remaining.
2021-12-05 23:07:37.606 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:07:37.607 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:89 CANCELLED
2021-12-05 23:07:37.610 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Went to sleep COMPLETE
2021-12-05 23:07:37.611 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 46 03
2021-12-05 23:07:37.630 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:07:37.631 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 90: Transaction not completed
2021-12-05 23:07:42.631 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 90: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:07:45.938 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 70, Status = Transmission complete, no ACK received(1)
2021-12-05 23:07:45.940 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:07:45.941 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: CANCEL while sending message. Requeueing - 2 attempts left!
2021-12-05 23:07:45.943 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:07:45.945 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 90 to queue - size 4
2021-12-05 23:07:45.947 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 90: Transaction not completed
2021-12-05 23:07:46.401 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update request. Node information received. Transaction null
2021-12-05 23:07:46.402 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update - no transaction.
2021-12-05 23:07:46.656 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Is awake with 1 messages in the queue
2021-12-05 23:07:46.657 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Start sleep timer at 5000ms
2021-12-05 23:07:46.658 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2021-12-05 23:07:46.667 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 15: Node Status event - Node is AWAKE
2021-12-05 23:07:48.368 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-12-05 23:07:48.369 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2021-12-05 23:07:48.370 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:07:48.370 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2021-12-05 23:07:48.371 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 15: Battery report value = 60
2021-12-05 23:07:48.372 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-05 23:07:48.373 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=60
2021-12-05 23:07:48.374 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:battery-level to 60 [DecimalType]
2021-12-05 23:07:48.375 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:07:48.376 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1380f68.
2021-12-05 23:07:48.383 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 47 02
2021-12-05 23:07:48.401 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:07:48.403 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 90: Transaction not completed
2021-12-05 23:07:48.421 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 71, Status = Transmission complete and ACK received(0)
2021-12-05 23:07:48.423 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 90: Transaction not completed
2021-12-05 23:07:49.158 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:07:51.658 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:07:51.659 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: No more messages, go back to sleep
2021-12-05 23:07:51.660 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-12-05 23:07:51.661 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:07:51.662 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:07:51.663 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1c0d4fa
2021-12-05 23:07:51.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 91 priority from Immediate to Immediate
2021-12-05 23:07:51.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:07:51.666 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 91 to queue - size 4
2021-12-05 23:07:53.423 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 90: Timeout at state WAIT_DATA. 2 retries remaining.
2021-12-05 23:07:53.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:07:53.426 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:90 CANCELLED
2021-12-05 23:07:53.430 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (3) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1a18811
2021-12-05 23:07:53.431 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: No data from device, but it was ACK'd. Possibly not supported? (Try 3)
2021-12-05 23:07:53.432 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 08 25 48 09
2021-12-05 23:07:53.450 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:07:53.452 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 91: Transaction not completed
2021-12-05 23:07:58.452 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 91: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:08:01.891 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 72, Status = Transmission complete, no ACK received(1)
2021-12-05 23:08:01.891 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2021-12-05 23:08:01.892 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 91: Transaction not completed
2021-12-05 23:08:02.526 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:08:02.528 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:08:02.529 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-12-05 23:08:02.530 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@15398
2021-12-05 23:08:02.531 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 92 priority from Config to Immediate
2021-12-05 23:08:02.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:08:02.533 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 92 to queue - size 4
2021-12-05 23:08:10.457 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 91: Timeout at state ABORTED. 3 retries remaining.
2021-12-05 23:08:10.461 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:08:10.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:91 CANCELLED
2021-12-05 23:08:10.464 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Went to sleep COMPLETE
2021-12-05 23:08:10.466 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 49 0C
2021-12-05 23:08:10.485 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:08:10.486 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 92: Transaction not completed
2021-12-05 23:08:15.487 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 92: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:08:18.714 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 73, Status = Transmission complete, no ACK received(1)
2021-12-05 23:08:18.716 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:08:18.717 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: CANCEL while sending message. Requeueing - 2 attempts left!
2021-12-05 23:08:18.718 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:08:18.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 92 to queue - size 4
2021-12-05 23:08:18.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 92: Transaction not completed
2021-12-05 23:09:26.302 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update request. Node information received. Transaction null
2021-12-05 23:09:26.303 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update - no transaction.
2021-12-05 23:09:26.555 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Is awake with 1 messages in the queue
2021-12-05 23:09:26.557 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Start sleep timer at 5000ms
2021-12-05 23:09:26.558 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2021-12-05 23:09:26.566 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 15: Node Status event - Node is AWAKE
2021-12-05 23:09:28.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-12-05 23:09:28.284 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2021-12-05 23:09:28.285 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:09:28.286 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2021-12-05 23:09:28.287 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 15: Battery report value = 66
2021-12-05 23:09:28.288 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-05 23:09:28.289 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=66
2021-12-05 23:09:28.290 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:battery-level to 66 [DecimalType]
2021-12-05 23:09:28.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:09:28.292 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f4c23e.
2021-12-05 23:09:28.298 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 0A 00 13 0F 03 70 05 FF 25 4A 0F
2021-12-05 23:09:28.322 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:09:28.328 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 92: Transaction not completed
2021-12-05 23:09:28.340 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 74, Status = Transmission complete and ACK received(0)
2021-12-05 23:09:28.343 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 92: Transaction not completed
2021-12-05 23:09:29.059 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:09:31.558 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 1 Messages waiting, state GET_CONFIGURATION
2021-12-05 23:09:31.560 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: No more messages, go back to sleep
2021-12-05 23:09:31.561 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-12-05 23:09:31.562 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:09:31.563 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:09:31.564 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@119cab8
2021-12-05 23:09:31.566 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 93 priority from Immediate to Immediate
2021-12-05 23:09:31.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:09:31.569 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 93 to queue - size 4
2021-12-05 23:09:33.343 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 92: Timeout at state WAIT_DATA. 2 retries remaining.
2021-12-05 23:09:33.346 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:09:33.346 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:92 CANCELLED
2021-12-05 23:09:33.350 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (4) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@ecdd83
2021-12-05 23:09:33.351 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: No data from device, but it was ACK'd. Possibly not supported? (Try 4)
2021-12-05 23:09:33.352 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction retries exceeded
2021-12-05 23:09:33.353 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 08 25 4B 0A
2021-12-05 23:09:33.353 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to STATIC_END
2021-12-05 23:09:33.354 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:09:33.356 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating node properties.
2021-12-05 23:09:33.357 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating node properties. MAN=520
2021-12-05 23:09:33.358 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating node properties. MAN=520. SET. Was 520
2021-12-05 23:09:33.361 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Properties synchronised
2021-12-05 23:09:33.367 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Update ASSOCIATION group_ZWaveAssociationGroup [index=1, name=null, profile1=null, profile2=null, associations=[node_23]]: Adding Controller (node_23)
2021-12-05 23:09:33.368 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Configuration synchronised
2021-12-05 23:09:33.372 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:09:33.375 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 93: Transaction not completed
2021-12-05 23:09:33.375 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Initialising Thing Node...
2021-12-05 23:09:33.377 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Initialising cmd channel zwave:device:8fd62f8f2b:node15:scene_number for DecimalType
2021-12-05 23:09:33.380 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Initialising state channel zwave:device:8fd62f8f2b:node15:scene_number for DecimalType
2021-12-05 23:09:33.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Initialising state channel zwave:device:8fd62f8f2b:node15:scene_number for DecimalType
2021-12-05 23:09:33.385 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Initialising cmd channel zwave:device:8fd62f8f2b:node15:battery-level for PercentType
2021-12-05 23:09:33.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Initialising state channel zwave:device:8fd62f8f2b:node15:battery-level for PercentType
2021-12-05 23:09:33.388 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Polling initialised at 1800 seconds - start in 567000 milliseconds.
2021-12-05 23:09:33.390 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 15: Serialise aborted as static stages not complete
2021-12-05 23:09:33.393 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to DYNAMIC_VALUES
2021-12-05 23:09:33.394 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:09:33.396 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_WAKE_UP
2021-12-05 23:09:33.398 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_MANUFACTURER_SPECIFIC
2021-12-05 23:09:33.402 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_FIRMWARE_UPDATE_MD
2021-12-05 23:09:33.403 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_BATTERY
2021-12-05 23:09:33.404 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Found 1 instances of COMMAND_CLASS_BATTERY for endpoint 0
2021-12-05 23:09:33.406 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:09:33.407 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
2021-12-05 23:09:33.408 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:09:33.409 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:09:33.410 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_BATTERY is NOT required to be secured
2021-12-05 23:09:33.411 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@e3f3f6
2021-12-05 23:09:33.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 94 priority from Get to Immediate
2021-12-05 23:09:33.413 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:09:33.414 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 94 to queue - size 4
2021-12-05 23:09:38.376 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 93: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:09:41.739 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 75, Status = Transmission complete, no ACK received(1)
2021-12-05 23:09:41.740 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2021-12-05 23:09:41.741 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 93: Transaction not completed
2021-12-05 23:09:50.379 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 93: Timeout at state ABORTED. 3 retries remaining.
2021-12-05 23:09:50.383 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:09:50.384 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:93 CANCELLED
2021-12-05 23:09:50.387 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Went to sleep COMPLETE
2021-12-05 23:09:50.389 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 80 02 25 4C 03
2021-12-05 23:09:50.408 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:09:50.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 94: Transaction not completed
2021-12-05 23:09:55.409 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 15: TID 94: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-12-05 23:09:58.626 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 76, Status = Transmission complete, no ACK received(1)
2021-12-05 23:09:58.628 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:09:58.629 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: CANCEL while sending message. Requeueing - 2 attempts left!
2021-12-05 23:09:58.630 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:09:58.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 94 to queue - size 4
2021-12-05 23:09:58.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 94: Transaction not completed
2021-12-05 23:10:50.718 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Channel zwave:device:8fd62f8f2b:node15:battery-level linked - polling started.
2021-12-05 23:10:50.718 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Channel zwave:device:8fd62f8f2b:node15:scene_number linked - polling started.
2021-12-05 23:11:06.828 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update request. Node information received. Transaction null
2021-12-05 23:11:06.829 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 15: Application update - no transaction.
2021-12-05 23:11:07.080 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Is awake with 1 messages in the queue
2021-12-05 23:11:07.082 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Start sleep timer at 5000ms
2021-12-05 23:11:07.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2021-12-05 23:11:07.092 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 15: Node Status event - Node is AWAKE
2021-12-05 23:11:08.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DYNAMIC_VALUES)
2021-12-05 23:11:08.811 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2021-12-05 23:11:08.812 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:11:08.814 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2021-12-05 23:11:08.815 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 15: Battery report value = 70
2021-12-05 23:11:08.816 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-05 23:11:08.817 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=70
2021-12-05 23:11:08.819 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:battery-level to 70 [DecimalType]
2021-12-05 23:11:08.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:11:08.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1b1b370.
2021-12-05 23:11:08.836 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 80 02 25 4D 02
2021-12-05 23:11:08.856 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:11:08.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 94: Transaction not completed
2021-12-05 23:11:08.875 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 77, Status = Transmission complete and ACK received(0)
2021-12-05 23:11:08.877 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 94: Transaction not completed
2021-12-05 23:11:09.349 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DYNAMIC_VALUES)
2021-12-05 23:11:09.350 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2021-12-05 23:11:09.351 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:11:09.352 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2021-12-05 23:11:09.353 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 15: Battery report value = 66
2021-12-05 23:11:09.354 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-12-05 23:11:09.355 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=66
2021-12-05 23:11:09.357 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Updating channel state zwave:device:8fd62f8f2b:node15:battery-level to 66 [DecimalType]
2021-12-05 23:11:09.358 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:11:09.359 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3aaf3.
2021-12-05 23:11:09.360 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3aaf3.
2021-12-05 23:11:09.361 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:94 DONE
2021-12-05 23:11:09.363 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:11:09.364 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@11b10fb
2021-12-05 23:11:09.365 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:11:09.366 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ASSOCIATION_GRP_INFO
2021-12-05 23:11:09.367 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_CENTRAL_SCENE
2021-12-05 23:11:09.368 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_DEVICE_RESET_LOCALLY
2021-12-05 23:11:09.369 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ZWAVEPLUS_INFO
2021-12-05 23:11:09.370 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_BASIC
2021-12-05 23:11:09.371 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_VERSION
2021-12-05 23:11:09.371 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_NO_OPERATION
2021-12-05 23:11:09.372 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_POWERLEVEL
2021-12-05 23:11:09.372 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Found 1 instances of COMMAND_CLASS_POWERLEVEL for endpoint 0
2021-12-05 23:11:09.373 [DEBUG] [andclass.ZWavePowerLevelCommandClass] - NODE 15: Creating new message for application command POWERLEVEL_GET
2021-12-05 23:11:09.373 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:11:09.374 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_POWERLEVEL is NOT required to be secured
2021-12-05 23:11:09.374 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: ZWaveCommandClassTransactionPayload - send to node
2021-12-05 23:11:09.375 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:11:09.375 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_POWERLEVEL is NOT required to be secured
2021-12-05 23:11:09.375 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@18bd49e
2021-12-05 23:11:09.376 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 95 priority from Config to Immediate
2021-12-05 23:11:09.377 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:11:09.377 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 95 to queue - size 4
2021-12-05 23:11:09.379 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 73 02 25 4E F2
2021-12-05 23:11:09.401 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:11:09.405 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 95: Transaction not completed
2021-12-05 23:11:09.422 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 78, Status = Transmission complete and ACK received(0)
2021-12-05 23:11:09.425 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 95: Transaction not completed
2021-12-05 23:11:09.428 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Application Command Request (ALIVE:DYNAMIC_VALUES)
2021-12-05 23:11:09.429 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Incoming command class COMMAND_CLASS_POWERLEVEL, endpoint 0
2021-12-05 23:11:09.430 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:11:09.431 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 15: Received COMMAND_CLASS_POWERLEVEL V1 POWERLEVEL_REPORT
2021-12-05 23:11:09.432 [DEBUG] [andclass.ZWavePowerLevelCommandClass] - NODE 15: Received POWERLEVEL report -0dB with 0 second timeout
2021-12-05 23:11:09.433 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWavePowerLevelCommandClassChangeEvent
2021-12-05 23:11:09.434 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_POWERLEVEL, value=0
2021-12-05 23:11:09.435 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Commands processed 1.
2021-12-05 23:11:09.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@169af94.
2021-12-05 23:11:09.437 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@169af94.
2021-12-05 23:11:09.438 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:95 DONE
2021-12-05 23:11:09.439 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:11:09.441 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@ad4628
2021-12-05 23:11:09.443 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node Init transaction completed with response COMPLETE
2021-12-05 23:11:09.444 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ASSOCIATION
2021-12-05 23:11:09.445 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_CONFIGURATION
2021-12-05 23:11:09.446 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer: Initialisation complete!
2021-12-05 23:11:09.447 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to DYNAMIC_END
2021-12-05 23:11:09.448 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:11:09.449 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 15: Serializing to file /var/lib/openhab/zwave/network_de92cc2a__node_15.xml
2021-12-05 23:11:09.478 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 15: Node advancer - advancing to DONE
2021-12-05 23:11:09.480 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2021-12-05 23:11:09.482 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 15: Serializing to file /var/lib/openhab/zwave/network_de92cc2a__node_15.xml
2021-12-05 23:11:09.583 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 0 Messages waiting, state DONE
2021-12-05 23:11:12.083 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: WakeupTimerTask 0 Messages waiting, state DONE
2021-12-05 23:11:12.084 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: No more messages, go back to sleep
2021-12-05 23:11:12.085 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 15: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-12-05 23:11:12.086 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: SECURITY not supported
2021-12-05 23:11:12.087 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-12-05 23:11:12.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1f498a2
2021-12-05 23:11:12.089 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Bump transaction 96 priority from Immediate to Immediate
2021-12-05 23:11:12.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Adding to device queue
2021-12-05 23:11:12.091 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Added 96 to queue - size 4
2021-12-05 23:11:12.095 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 15: Sending REQUEST Message = 01 09 00 13 0F 02 84 08 25 4F 0E
2021-12-05 23:11:12.112 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: sentData successfully placed on stack.
2021-12-05 23:11:12.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 96: Transaction not completed
2021-12-05 23:11:12.127 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 15: SendData Request. CallBack ID = 79, Status = Transmission complete and ACK received(0)
2021-12-05 23:11:12.128 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: resetResendCount initComplete=true isDead=false
2021-12-05 23:11:12.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: Response processed after 33ms
2021-12-05 23:11:12.130 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: TID 96: Transaction completed
2021-12-05 23:11:12.130 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 15: notifyTransactionResponse TID:96 DONE
2021-12-05 23:11:12.131 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 15: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-12-05 23:11:12.132 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: Went to sleep COMPLETE
Based on a quick review, I think everything is configured.
Now that you are a hardened veteran. There is a tool to view Debug files (It is very hard to read what you have posted. Also (in the future) just post the file and not the snippets
I extracted the last section (notice the DONE)
Hank
Congrats,
Bob
On further review, what is unusual. It seems to have set node 23 as the lifeline. What is that? There seems to be a lot of “wakes”. That was good for initialization but is going to drain the battery if that continues. Also the polling interval is going to drain the battery. Can that be set? Anyway the channels should work.
Bob
Thank for all the work Bob! One thing that I don’t understand is that now I have two nodes for one device, and both are online:
Screen Shot 2021-12-07 at 08.42.39
Node 23 is the z-stick controller. I guess Node 1 was taken by the Neeo.
Polling interval: Could that be one item in the configuration for the thing?
I have some concern about the set-up with Node 23 as controller. It is beyond my limited experience. What I noticed in the logs was there were none of the typical received messaged, but the binding seemed to be getting the right information. I guess if it works to your needs (using node 15 channels), then it is all good.
Try to delete Thing Node 14. Ideally it will not appear again next time you scan. If it does, you will need to use the PC controller to get rid of it. If there was a node 14 XML, delete that too.
Bob
