- Platform information:
- Hardware: _CPUArchitecture/RAM/storage
R-Pi 4, 4GB; Linux 5.15.84-v8+ #1613 SMP PREEMPT aarch64 GNU/Linux - OS: what OS is used and which version
Raspberry Pi OS - Java Runtime Environment: which java platform is used and what version
openjdk 11.0.18 2023-01-17 LTS
OpenJDK Runtime Environment Zulu11.62+17-CA (build 11.0.18+10-LTS)
OpenJDK 64-Bit Server VM Zulu11.62+17-CA (build 11.0.18+10-LTS, mixed mode) - openHAB version: 3.4.1
I have about a dozen z-wave devices installed and running and set up as thing within a model… I can turn lights on and off with openhab. However, when I try to get the network map all I get is a the title bar, the rest of the page is blank. If I refresh the page, I get:
Sorry
Requested content not found.
Debug information
- Url: /settings/things/zwave:device:1b10bf339c:node2/zwave-network/
- Path: /settings/things/zwave:device:1b10bf339c:node2/zwave-network/
- Hash:
- Params:
- Query:
- Route: (.*)
There is no settings directory in any of the openhab directories on my system. The configuration directories in /etc/openhab only have readme files
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
No log was produced as a result of attempting to display the network map.
Update - I don’t seem to have an overview page either.
