- Platform information:
- Hardware: Raspberry Pi 4 Model B Rev 1.1 ; 4GB memory
- Host: Linux openhabian 5.15.76-v7l+ #1597 SMP Fri Nov 4 12:14:58 GMT 2022 armv7l GNU/Linux
- Distro: Raspbian GNU/Linux 11 (bullseye)
- openjdk version “11.0.18” 2023-01-17
- OpenJDK Runtime Environment (build 11.0.18+10-post-Raspbian-1deb11u1)
- OpenJDK Server VM (build 11.0.18+10-post-Raspbian-1deb11u1, mixed mode)
- OH Version: 3.4.3 (Build)
- Installation method: openhabian
I have Zigbee running for a while w/o any problems. I have got some 15 devices, which work as desired.
Today I added a RGB bulb, the second of its kind (#2). The first (#1) is online for a few months.
The discovery failed with an error:
2023-08-13 08:12:33.724 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - A4C138280DBE8B76: Starting ZigBee device discovery
2023-08-13 08:12:41.843 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - A4C1383B857093B9: Starting ZigBee device discovery
2023-08-13 08:13:02.648 [ERROR] [.converter.ZigBeeConverterColorColor] - A4C138280DBE8B76: Error 0xffff setting server binding
2023-08-13 08:13:02.649 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - A4C138280DBE8B76: Channel zigbee:device:42b78e1deb:a4c138280dbe8b76:A4C138280DBE8B76_1_color failed to initialise device
Another scan resulted in the same error.
Well, I have another bulb(#3), let’s try it…
Another error:
2023-08-13 09:17:40.546 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - A4C138280DBE8B76: Starting ZigBee device discovery
2023-08-13 09:18:09.437 [ERROR] [.converter.ZigBeeConverterColorColor] - A4C138280DBE8B76: Error 0xffff setting server binding
2023-08-13 09:18:09.439 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - A4C138280DBE8B76: Channel zigbee:device:42b78e1deb:a4c138280dbe8b76:A4C138280DBE8B76_1_color failed to initialise device
Then I went on to remove the device #2.
I disabled the device and then hit Delete Thing
It changed its state to REMOVING
, and stayed there.
I went onto the forum, and read if things don’t work stop the service, clear cache, start service… I did just that, and ended up with the scariest restart… error upon error. I stopped the service and rebooted the rPi.
The reboot that followed when fine.
However, the Zigbee things still show REMOVING
I added a new Zigbee thing; not a bulb but a LED driver. It added the ting and its channels.
Therefore, the binding seems to work, but the bulbs have issues; though I suspect the binding has a problem too, as it does not remove the two bulbs I tried to add.
I enabled TRACE logging of the Zigbee binding when scanning for new devices… but I can’ make sense of the log.
20230813_SCAN_Trace.txt (767.3 KB)
The scan starts in line 1173 and ends with line 2571. Maybe someone can make sens of it.
I have no sensible idea on what to do next.
Any hints appreciated.
[edit1:] Wasn’t keen to do a force remove, as it states it could cause stability problems.
