Material :
- Raspberry Pi 3 Model B Rev 1.2, boot ext HDD w/o sd
- Conbee 2, fw version 0x26680700.bin.GCF
- Lidl HG06106C Livarno Lux E27 bulb RGB (in progress)
- Lidl HG06106B Livarno Lux E14 candle RGB (in progress)
- Lidl FB20-002 Livarno Lux remote control (next job)
- Lidl HG06337 Silvercrest smart plug (next job)
- Lidl Bridge (unused, maybe useful for helping debugging original binding)
OS :
- OpenHabian 3.0.1
- Java : Zulu11, oJDK 11.0.10
- Zigbee2mqtt 1.18.1, node v 14.16.0, npm 6.14.11
- MQTT 3.0.1
Hi everybody,
First, thanks a lot to all developers, members, in fact all the community who gave me the ability to control my first RGB color LEDs without original commercial bridge. I’m a newcomer (about 1 month), and I’m really impressed and excited by your OpenHab Project!!!
Because i had some problems to render “true” colors with “hue bridge” or “deconz bridge”, and thinking mqtt is more “brut” and will let me have more integration possibilities for futures devices, I choosed this way, and i am thinking today it was not wrong… for RGB only
nobody knows what future will bring
So after burning my head reading forum topics, documentations and what else?, I decided to subscribe your community, to continue to progress and understand, maybe help someone
, hoping some help or even just little directions during i digest all, and savor some won battles, before coming back to war! ![]()
Config files :
/opt/zigbee2mqtt/date/configuration.yalm
homeassistant: false
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://localhost:1883'
user: XxXx
password: xXxX
serial:
port: /dev/ttyACM0
adapter: deconz
advanced:
log_level: error
baudrate: 38400
availability_timeout: 60
experimental:
output: json
devices:
'0xbc33acfffea9c60e':
friendly_name: E27
'0xbc33acfffe863c13':
friendly_name: Remote
'0x588e81fffed98822':
friendly_name: E14
'0x842e14fffe2008e7':
friendly_name: E141
Thing file :
//Bridge definition an parameters :
Bridge mqtt:broker:mosquitto [
host="192.168.1.24",
port="1883",
secure="false",
qos="0",
reconnectTime="60000",
keepAlive="60",
lwtQos="0",
lwtRetain="true",
username="XxXx",
password="xXxX",
certificatepin="true",
publickeypin="true"
//"Bridge Thing" for permiting join and logs : (txh @Seaside)
Thing topic zigbeeBridge "Zigbee2mqtt Bridge" @ "Salon" {
Channels:
Type switch : permitJoin [
commandTopic="zigbee2mqtt/bridge/config/permit_join",
on="true",
off="false"
Type string : state [
stateTopic="zigbee2mqtt/bridge/state"
Type string : logType [
stateTopic="zigbee2mqtt/bridge/log",
tranformationPattern="JSONPATH:$.type"
Type string : logMessage [
transformationPattern="JSONPATH:$.message"
//"Light Thing" Lidl Livarno Lux E27 bulb RGB (model HG06106C) :
Thing topic jsonE27 "JSON E27" @ "Salon" {
Channels:
Type switch : jsonSwitchE27 "JSON Switch E27" [
stateTopic="zigbee2mqtt/E27/state",
commandTopic="zigbee2mqtt/E27/set",
on="ON",
off="OFF"
Type dimmer : jsonDimmerE27 "JSON Dimmer E27" [
stateTopic="zigbee2mqtt/E27",
commandTopic="zigbee2mqtt/E27/set/brightness",
min=0,
max=254,
transformationPattern="JSONPATH:$.brightness" //seems useless or bad, return percent value
Type number : jsonLqiE27 "JSON LQI E27" [
transformationPattern="JSONPATH:$.linkquality"
Type color : jsonColorE27 "JSON Color E27" [ //may need 'send JSONE27_JSONColorE27 "100,50,100"' in karaf to enable colorpicker
colorMode="RGB",
formatBeforePublish="{\"color\":{\"rgb\":\"%s,%s,%s\"}}", //should try {\"rgb\":\"%d,%d,%d\"}}", cf mqtt doc; sends max 250 instead of 255
transformationPattern="JSONPATH:$.color" //seems useless or bad
//"Light Thing" Lidl Livarno Lux E14 candle RGB (model HG06106B) :
Thing topic jsonE141 "JSON E141" @ "Salon" {
Channels:
Type switch : jsonSwitchE141 "JSON Switch E141" [
stateTopic="zigbee2mqtt/E141/state",
commandTopic="zigbee2mqtt/E141/set",
on="ON",
off="OFF"
Type dimmer : jsonDimmerE141 "JSON Dimmer E141" [
stateTopic="zigbee2mqtt/E141",
commandTopic="zigbee2mqtt/E141/set/brightness",
min=0,
max=254,
Type number : jsonLqiE141 "JSON LQI E141" [
Type color : jsonColorE141 "JSON Color E141" [
colorMode="RGB",
Thing topic jsonE14 "JSON E14" @ "Salon" {
Channels:
Type switch : jsonSwitchE14 "JSON Switch E14" [
stateTopic="zigbee2mqtt/E14/state",
commandTopic="zigbee2mqtt/E14/set",
on="ON",
off="OFF"
Type dimmer : jsonDimmerE14 "JSON Dimmer E14" [
stateTopic="zigbee2mqtt/E14",
commandTopic="zigbee2mqtt/E14/set/brightness",
min=0,
max=254,
Type number : jsonLqiE14 "JSON LQI E14" [
Type color : jsonColorE14 "JSON Color E14" [
colorMode="RGB",
Sniffing mqtt traffic :
$ mosquitto_sub -h '192.168.1.24' -p 1883 -u openhabian -P 'Rpi01OHMqtt!44?' -v -t 'zigbee2mqtt/#'
zigbee2mqtt/E27/set {"color":{"rgb":"250,250,250"}}
zigbee2mqtt/E27 {"brightness":96.52,"color":{"x":0.3227,"y":0.329},"color_temp":165,"linkquality":208,"state":"ON"}
Note :
I choose “JSON output” (i think the default in fact), because I’m not able to set “color-x”/“color-y”, the separated “attribute output”. Maybe using both should solved some problems.
What is WORKING !
- Bridge and binding
- Switchs ON/OFF
- Brightness control
- Color control, through RGB mode
- Reading linkquality value
What I’m looking for ?
- Where an how writing “availability topic” in the thing file ? (i got it when i create thing through GUI)
- Why brightness output value is percent value ? Is “JSONPATH:$.brightness” wrong ? Or is it just the item configuration ?
And color output is wrong too! (of course if reading X,Y value)
- I defined i my model a scale 0-100 to brightness control, that’s running, but in the “auto-generated” card , it still appears as 0-255. Where am i wrong ?
- Why “sended” max color control value (“r”, “g” or “b”) is 250 ? (maybe have to try “%d,%d,%d”) (cf “sniffing traffic”)
- Can’t switch in “white color temperature” mode. (maybe have to set “colorMode”=“CT” if possible)
Hoping I respected Guidelines,
Thanks for reading, and future help,
And good continuation!
