I’m using OH3 (on Docker) for a while. and today I wanted to remove one device from the network, I entered the ZWave binding thing in the UI and clicked “Exclude devices”.
since then all the devices changed to OFFLINE and the aeotec USB stick changed to OFFLINE.
I tried to remove it and add the thing again. nothing helped.
try to install again in karaf feature:install openhab-transport-serial and restart to zwave binding - but still the same thing…
permissions to stick are okay, container running in high priority, controller react to cat /dev/ttyACM0, but still nothing in OH3 UI.
Any suggestions?
Thanks.
Log:
2021-04-19 22:54:25.537 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:Zwave' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2021-04-19 22:54:25.546 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Deactivate zwave:serial_zstick:Zwave
2021-04-19 22:54:25.549 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:Zwave' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2021-04-19 22:56:04.405 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Creating ZWave discovery service for zwave:serial_zstick:Zwave with scan time of 60
2021-04-19 22:56:04.407 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Active zwave:serial_zstick:Zwave
2021-04-19 22:56:04.544 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:Zwave' changed from UNINITIALIZED to INITIALIZING
2021-04-19 22:56:04.560 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:Zwave.
2021-04-19 22:56:04.565 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:Zwave' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline```
