Hello all,
just out of the blue - withhout having done any changes the bundle:restart command is missing. So bascially I can not restart bundles anymore.
Just restarted openhab, but that did not help.
_ _ _ ____
___ ___ ___ ___ | | | | / \ | __ )
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
|_| 4.0.4 - Release Build
Use '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
To exit, use '<ctrl-d>' or 'logout'.
openhab> bundle:restart
Command not found: bundle:restart
Karaf
Karaf version 4.4.3
Karaf home /usr/share/openhab/runtime
Karaf base /var/lib/openhab
OSGi Framework org.eclipse.osgi-3.18.0.v20220516-2155
JVM
Java Virtual Machine OpenJDK 64-Bit Server VM version 17.0.9+8-LTS
Version 17.0.9
Vendor Azul Systems, Inc.
Pid 930700
Uptime 13 minutes
Process CPU time 6 minutes
Process CPU load 0.00
System CPU load 1.00
Open file descriptors 224
Max file descriptors 102,642
Total compile time 4 minutes
Threads
Live threads 304
Daemon threads 134
Peak 321
Total started 1311
Memory
Current heap size 300,544 kbytes
Maximum heap size 2,048,000 kbytes
Committed heap size 862,208 kbytes
Pending objects 0
Garbage collector Name = 'G1 Young Generation', Collections = 43, Time = 2.868 seconds
Garbage collector Name = 'G1 Old Generation', Collections = 0, Time = 0.000 seconds
Classes
Current classes loaded 26,285
Total classes loaded 26,432
Total classes unloaded 147
Operating system
Name Linux version 6.2.16-3-pve
Architecture amd64
Processors 2
Total physical memory 3,432,636 kbytes
Free physical memory 125,340 kbytes
