Updated today from openhab 3.4.5 to openhab 4.1.1. on my unraid device. (docker installed via unraid docker app)
Both eco systems run with homematic binding connected to homegear 0.7.51.
Now I figured out that this device will not be updated on event long press or short press.
In parallel I created new items connected to HM-PB-6-WM55 channels TEST_COUNTER and SIM_COUNTER.
Both values do not change on any event - doesn’t matter if button 1,2,3,4,5 or 6 is pressed until restarting openhab server.
Connected to homegear server, each button press is recognized, checked by TEST_COUNTER and SIM_COUNTER which are counting up.
After openhab started up I can see that connected items will show identical values like homegear session.
I tried several configurations
- adding the Thing manually (scanning doesn’t work, even with OH2 and OH3), adding items manually
- adding the Thing manually, items by old config file
- adding the Thing and Items by old config file
- adding the Thing by old config file, items manually
Noone of above mentioned worked, all shows same results
Thank you for your help
