OH4 - Invalid CEN header (invalid zip64 extra data field size) during startup
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage
    • OS: Windows 10 Pro
    • Java Runtime Environment: openjdk version “17.0.8” 2023-07-18 LTS
      OpenJDK Runtime Environment Zulu17.44+15-CA (build 17.0.8+7-LTS)
      OpenJDK 64-Bit Server VM Zulu17.44+15-CA (build 17.0.8+7-LTS, mixed mode, sharing)
    • openHAB version: openHAB 4.0.0 Release Build
  • Issue of the topic:
    After a fresh install of OH4.0 I found similar error messages as mentioned in Issue 1559 whats included in latest OH3.4.5 release.
    Not sure if this is also known for OH4.0, hence this post.
Error in shell when using start.bat script:
Launching the openHAB runtime...
22:00:36.270 [Framework Event Dispatcher: Equinox Container: d4352e90-0e6a-4aaf-8d9b-0d5a186269f6] ERROR Events.Framework - FrameworkEvent ERROR
java.util.zip.ZipException: Exception in opening zip file: C:\xxx\openhab-4.0.0\userdata\cache\org.eclipse.osgi\62\0\.cp\lib\geronimo-osgi-locator.jar
        at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:356) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.doOpen(ZipBundleFile.java:51) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.internalOpen(CloseableBundleFile.java:140) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.lockOpen(CloseableBundleFile.java:78) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.getEntry(CloseableBundleFile.java:274) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.loadManifest(ClasspathEntry.java:230) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.<init>(ClasspathEntry.java:77) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.createClassPathEntry(ModuleClassLoader.java:267) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.createClassPathEntry(ClasspathManager.java:343) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.getClasspath(ClasspathManager.java:295) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.addStandardClassPathEntry(ClasspathManager.java:213) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.addClassPathEntry(ClasspathManager.java:205) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:188) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:166) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:94) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:54) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:262) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle$1.run(EquinoxBundle.java:653) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle$1.run(EquinoxBundle.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
        at java.security.AccessController.doPrivileged(AccessController.java:318) ~[?:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.getModuleClassLoader(EquinoxBundle.java:646) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.getResource(EquinoxBundle.java:588) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.apache.servicemix.specs.activation.Activator.register(Activator.java:58) ~[org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:1.2.1_3]
        at org.apache.servicemix.specs.locator.Activator.start(Activator.java:70) ~[org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:1.2.1_3]
        at org.apache.servicemix.specs.activation.Activator.start(Activator.java:46) ~[org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:1.2.1_3]
        at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:818) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
        at java.security.AccessController.doPrivileged(AccessController.java:569) ~[?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:810) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:767) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1032) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:371) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.Module.doStart(Module.java:605) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.Module.start(Module.java:468) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
Caused by: java.util.zip.ZipException: Invalid CEN header (invalid zip64 extra data field size)
        at java.util.zip.ZipFile$Source.zerror(ZipFile.java:1728) ~[?:?]
        at java.util.zip.ZipFile$Source.checkExtraFields(ZipFile.java:1261) ~[?:?]
        at java.util.zip.ZipFile$Source.checkAndAddEntry(ZipFile.java:1212) ~[?:?]
        at java.util.zip.ZipFile$Source.initCEN(ZipFile.java:1667) ~[?:?]
        at java.util.zip.ZipFile$Source.<init>(ZipFile.java:1445) ~[?:?]
        at java.util.zip.ZipFile$Source.get(ZipFile.java:1407) ~[?:?]
        at java.util.zip.ZipFile$CleanableResource.<init>(ZipFile.java:716) ~[?:?]
        at java.util.zip.ZipFile.<init>(ZipFile.java:250) ~[?:?]
        at java.util.zip.ZipFile.<init>(ZipFile.java:179) ~[?:?]
        at java.util.zip.ZipFile.<init>(ZipFile.java:193) ~[?:?]
        at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:342) ~[org.eclipse.osgi-3.18.0.jar:?]
        ... 43 more
22:00:36.297 [Framework Event Dispatcher: Equinox Container: d4352e90-0e6a-4aaf-8d9b-0d5a186269f6] ERROR Events.Framework - FrameworkEvent ERROR
        at org.eclipse.osgi.storage.bundlefile.BundleFile.getResourceURL(BundleFile.java:142) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.findResource(ClasspathEntry.java:213) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalResourceImpl(ClasspathManager.java:421) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalResourceImpl(ClasspathManager.java:401) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalResource(ClasspathManager.java:372) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalResource(ModuleClassLoader.java:327) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.BundleLoader.findLocalResource(BundleLoader.java:911) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.BundleLoader.findResource(BundleLoader.java:693) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.getResource(ModuleClassLoader.java:205) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.getResource(EquinoxBundle.java:590) ~[org.eclipse.osgi-3.18.0.jar:?]
        ... 35 more
openhab.log, not sure if thats related
2023-07-27 22:00:40.379 [INFO ] [org.openhab.core.Activator          ] - Starting openHAB 4.0.0 (build Release Build)
2023-07-27 22:00:40.696 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2023-07-27 22:00:40.712 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to 'XXXX'.
2023-07-27 22:00:40.712 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2023-07-27 22:00:52.357 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2023-07-27 22:00:54.787 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager gestartet und erreichbar unter http(s)://xxx:8080/shelly/manager
2023-07-27 22:00:55.080 [WARN ] [ce.jetty.internal.JettyServerWrapper] - Can't create temporary directory for OsgiContextModel{HS,id=OCM-35,name='context:1670476183',path='/',bundle=org.jupnp,context=WebContainerContextWrapper{bundle=org.jupnp_2.7.0 [245],contextId='context:1670476183',delegate=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@63917197}}: C:\XXX\OPENHA~1.0\userdata\tmp\ROOT\context:1670476183
There will be a 4.0.1 release soon that also has this fix.
You can upgrade to 4.0.1 now: openHAB 4.0 - a new major release is here! - #2 by Kai
