sorry maybe a stupid question. I have increased the log levels for things to TRACE and restarted OH. Now I have a quite big logfile. What should I look for?
Usually when you see an exception there will be a stack trace under it showing all the classes that called each other until they got to where the error occured. You’ll see a lot of “caused by”.
It has nothing to do with the logging level usually.
3301 2023-09-25 16:00:00.081 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching/filtering event for subscriber 'org.openhab.core.events.EventSubscriber' failed: Last segment must not be blank: [shelly, shellyplugs, ]
3302 java.lang.IllegalArgumentException: Last segment must not be blank: [shelly, shellyplugs, ]
3303 at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:79) ~[?:?]
3304 at org.openhab.core.common.AbstractUID.<init>(AbstractUID.java:59) ~[?:?]
3305 at org.openhab.core.thing.UID.<init>(UID.java:57) ~[?:?]
3306 at org.openhab.core.thing.ThingUID.<init>(ThingUID.java:139) ~[?:?]
3307 at org.openhab.core.thing.ChannelUID.getThingUID(ChannelUID.java:150) ~[?:?]
3308 at org.openhab.core.thing.internal.AutoUpdateManager.shouldAutoUpdate(AutoUpdateManager.java:205) ~[?:?]
3309 at org.openhab.core.thing.internal.AutoUpdateManager.receiveCommand(AutoUpdateManager.java:145) ~[?:?]
3310 at org.openhab.core.thing.internal.CommunicationManager.receiveCommand(CommunicationManager.java:335) ~[?:?]
3311 at org.openhab.core.thing.internal.CommunicationManager.receive(CommunicationManager.java:190) ~[?:?]
3312 at org.openhab.core.internal.events.EventHandler.lambda$2(EventHandler.java:168) ~[?:?]
3313 at java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1804) ~[?:?]
3314 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
3315 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
3316 at java.lang.Thread.run(Thread.java:833) ~[?:?]
I unlinked the thing and removed it. Deleted the item and did a scan from the shelly binding. Recreated the thing and the links. After a reboot everything looks normal but the exception is still there
2023-09-25 21:27:25.899 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.core.thing.internal.ChannelLinkNotifier@19656409" about the "ADDED" event: Last segment must not be blank: [shelly, shellyplugs, ]
at org.openhab.core.thing.internal.ChannelLinkNotifier.added(ChannelLinkNotifier.java:70) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.added(ChannelLinkNotifier.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:375) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListenersAboutAddedElement(AbstractRegistry.java:408) ~[?:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutAddedElement(ItemChannelLinkRegistry.java:181) ~[?:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutAddedElement(ItemChannelLinkRegistry.java:1) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:440) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:149) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:943) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:871) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:321) ~[osgi.core-8.0.0.jar:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:264) ~[osgi.core-8.0.0.jar:?]
at org.openhab.core.common.registry.AbstractRegistry.lambda$0(AbstractRegistry.java:111) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1768) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncSupply.exec(CompletableFuture.java:1760) ~[?:?]
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:373) ~[?:?]
at java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1182) ~[?:?]
at java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1655) ~[?:?]
at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1622) ~[?:?]
at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:165) ~[?:?]
I will raise an issue - when I discovered how to do this
