My setup:
Raspi 4
Openhabian (bullseye)
I have just upgraded my Openhab from version 3 to version 4. Now the start fails with the following exception:
2023-07-24 08:13:33.251 [ERROR] [af.features.internal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.felix.resolver.reason.ReasonException: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-runtime-base; type=karaf.feature; version="[4.0.0,4.0.0]"; filter:="(&(osgi.identity=openhab-runtime-base)(type=karaf.feature)(version>=4.0.0)(version<=4.0.0))" [caused by: Unable to resolve openhab-runtime-base/4.0.0: missing requirement [openhab-runtime-base/4.0.0] osgi.identity; osgi.identity=openhab-core-base; type=karaf.feature [caused by: Unable to resolve openhab-core-base/4.0.0: missing requirement [openhab-core-base/4.0.0] osgi.identity; osgi.identity=org.openhab.core.config.core; type=osgi.bundle; version="[4.0.0,4.0.0]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.config.core/4.0.0: missing requirement [org.openhab.core.config.core/4.0.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.openhab.core.common.registry)(version>=4.0.0)(!(version>=5.0.0)))" [caused by: Unable to resolve org.openhab.core/4.0.0: missing requirement [org.openhab.core/4.0.0] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"]]]]
at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.doResolve(ResolverImpl.java:433) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:420) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:374) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:256) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) ~[?:?]
at java.lang.Thread.run(Unknown Source) ~[?:?]
Looks like there’s a problem with Java 17. Tried to install Java 17 from (updated) openhabian-config, but ended with an error:
$ apt-get install --yes -o DPkg::Lock::Timeout= openjdk-17-jre-headless
+ apt-get install --yes -o DPkg::Lock::Timeout= openjdk-17-jre-headless
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
openjdk-17-jre-headless : Depends: libc6 (>= 2.29) but 2.28-10+rpt2+rpi1+deb10u2 is to be installed
Depends: libgcc-s1 (>= 3.5) but it is not installable
So I tried to install “libgcc-s1” manual but (not unexpected) failed also:
openhabian@ohab:/etc/apt/sources.list.d $ sudo apt-get install libgcc-s1
Package libgcc-s1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libgcc-s1' has no installation candidate
Now I’m a bit lost. Any hint where to look at to find (and resolve) the problem?
