I’m trying to accomplish a widget which will show a couple of time series in a chart, basically temperatures.
What I’m failing to get is the usage of props in the charts definitions. Anyone any idea?
The props are never being picked up and the chart is left empty.
series:
- component: oh-time-series
gridIndex: 0
item: =props.Item_1
type: line
xAxisIndex: 0
yAxisIndex: 0
If I pick the item directly, all works ok.
series:
gridIndex: 0
item: Thermo_Schlafzimmer_Temperatur
type: line
xAxisIndex: 0
yAxisIndex: 0
Complete code:
uid: Test_Widget
tags: []
props:
parameters:
- context: item
description: Temperatur 1
label: Item_1
required: true
type: TEXT
- label: name_1
name: Bezeichnung Temperatur 1
required: true
type: TEXT
parameterGroups: []
timestamp: Nov 25, 2023, 12:01:53 PM
component: f7-card
style:
--font-size: 16px
--line-height: 20px
--text-color: rgba(255,255,255,1)
background-color: rgba(6,25,36)
border-radius: 20px
color: var(--text-color)
height: 360px
title: Temperaturen
slots:
default:
- component: oh-chart
options:
backgroundColor: rgb(6,25,36)
color:
- "#56a54b"
- "#e02f43"
- "#fcba03"
- "#1e5ec0"
period: M
periodVisible: false
slots:
grid:
- component: oh-chart-grid
config: {}
legend:
- component: oh-chart-legend
bottom: "8"
icon: circle
orient: horizontal
show: true
textStyle:
color: "#FFFFFF"
series:
gridIndex: 0
item: =props.Item_1
type: line
xAxisIndex: 0
yAxisIndex: 0
tooltip:
- component: oh-chart-tooltip
orient: vertical
show: true
trigger: axis
type: cross
xAxis:
- component: oh-time-axis
gridIndex: 0
yAxis:
- component: oh-value-axis
axisLabel:
formatter: "{value} °C"
gridIndex: 0
splitLine:
lineStyle:
color: "#6E7079"
