If you correct the unconfigured device and allow it to reacquire a valid iPv4 address assignment does the waiting thread count decrease?
I do not have any battery operated shelly devices so I can not say much on whether that has a bearing or not as I have not been able to reproduce the run away thread count condition my self .
It maybe I do not have enough devices or the fact that I do not have battery operated devices.
As for discovery for my test system with 2 shelly devices a smart plug and a Shellyplus4i I have not been able to complete a discovery when trying to use them on 4.XX
But if added manually they seem to work fine.
however, both devices discover just fine on OH3.4XX version no manual addition was required.
Not sure how relevant that is to that you see or not.
Also, the binding doc does mention that only IPv4 is supported so any IPv6 assigned device is going to have issues I would think.
I also have IPv6 disabled throughout my network on every NIC and in the wireless access point.
I haven’t consciously activated IPv6, nor configured it. But it’s always there I guess.
I’ve never had to manually add devices.
I suspect I’m seeing enough that I could probably resolve the issue for myself by turning off IPv6 or allocating static IP addresses or some other action that could stop the ip address gap (if that’s the issue). But that won’t help anyone else - if this is a problem other people get but that is hard to diagnose, then I probably should help to get to a point where we know what it is and can fix it - I’m probably more able to help diagnose than many people are.
I’ve run a grep over the log file to see how many disconnects I’m really getting.
grep "WebSocket\|discovery" /var/log/openhab/openhab.log > websocket.log
That gives 530 lines, which represent about 53 total web socket connections. Only a handful of them have the Websocket error - most of them seem to connect fine. It’s sort of possible that this is enough to be all my excess web sockets, I have about 100 extra in that time.
Example of one that looks fine:
2023-10-14 09:27:55.262 [TRACE] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Shelly device discovered with empty IP address (service-name=[ServiceInfoImpl@28507710 name: 'shellyplus2pm-806
46fdb89e0._http._tcp.local.' address: '(null):0' status: 'DNS: raspberrypi2-planar-id-au.local. [raspberrypi2.planar.id.au/192.168.1.15] state: probing 1 task: null', has NO data
shellyplus2pm-80646fdb89e0._http._tcp.local.: ])
2023-10-14 09:27:55.264 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Shelly device discovered: IP-Adress=192.168.1.221, type=shellyplus2pm
2023-10-14 09:27:55.284 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: Connect Rpc Socket (discovery = true)
2023-10-14 09:27:55.286 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: Connect WebSocket, URI=ws://192.168.1.221/rpc
2023-10-14 09:27:55.319 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP POST for http://192.168.1.221/rpc {"id":970475598,"src":"shellyplus2pm-80646fdb89e0","method":"Shelly.GetC
onfig"}
Accept-Encoding: gzip
User-Agent: Jetty/9.4.50.v20221201
Content-Type: application/json; charset=UTF-8
2023-10-14 09:27:55.403 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: WebSocket connected /192.168.1.15:47678<-/192.168.1.221:80, Idle Timeout=2147483647
2023-10-14 09:27:55.439 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP Response 200: {"id":970475598,"src":"shellyplus2pm-80646fdb89e0","dst":"shellyplus2pm-80646fdb89e0","resul
t":{"ble":{"enable":false,"rpc":{"enable":true},"observer":{"enable":false}},"cloud":{"enable":false,"server":"shelly-78-eu.shelly.cloud:6022/jrpc"},"input:0":{"id":0,"name":null,"type":"button","invert":false,"f
actory_reset":true},"input:1":{"id":1,"name":null,"type":"button","invert":false,"factory_reset":true},"mqtt":{"enable":false,"server":null,"client_id":"shellyplus2pm-80646fdb89e0","user":null,"topic_prefix":"she
llyplus2pm-80646fdb89e0","rpc_ntf":true,"status_ntf":false,"use_client_cert":false,"enable_rpc":true,"enable_control":true},"switch:0":{"id":0, "name":null,"in_mode":"detached","initial_state":"off", "auto_on":fa
lse, "auto_on_delay":60.00, "auto_off":false, "auto_off_delay":60.00,"power_limit":2800,"voltage_limit":280,"undervoltage_limit":0,"autorecover_voltage_errors":false,"current_limit":10.000},"switch:1":{"id":1, "n
ame":null,"in_mode":"detached","initial_state":"off", "auto_on":false, "auto_on_delay":60.00, "auto_off":false, "auto_off_delay":60.00,"power_limit":2800,"voltage_limit":280,"undervoltage_limit":0,"autorecover_vo
ltage_errors":false,"current_limit":10.000},"sys":{"device":{"name":"LightsGarage","mac":"80646FDB89E0","fw_id":"20230912-081945/1.0.3-g6176478","discoverable":true,"eco_mode":true,"profile":"switch","addon_type"
:null},"location":{"tz":"Pacific/Auckland","lat":-36.845300,"lon":174.757520},"debug":{"level":2,"file_level":null,"mqtt":{"enable":false},"websocket":{"enable":false},"udp":{"addr":null}},"ui_data":null,"rpc_udp
":{"dst_addr":null,"listen_port":null},"sntp":{"server":"time.google.com"},"cfg_rev":19},"wifi":{"ap":{"ssid":"ShellyPlus2PM-80646FDB89E0","is_open":true, "enable":false, "range_extender": {"enable":false}},"sta"
:{"ssid":"OscarSlow","is_open":false, "enable":true, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"sta1":{"ssid":null,"is_open":true, "enable":false, "ipv4mode":"dhcp","ip":null,"netmas
k":null,"gw":null,"nameserver":null},"roam":{"rssi_thr":-80,"interval":60}},"ws":{"enable":false,"server":null,"ssl_ca":"ca.pem"}}}
Content-Length: 2129
Server: ShellyHTTP/1.0.0
Connection: close
2023-10-14 09:27:55.446 [TRACE] [helly.internal.api2.Shelly2ApiClient] - shellyplus2pm-80646fdb89e0: API value detached was mapped to momentary
2023-10-14 09:27:55.447 [TRACE] [helly.internal.api2.Shelly2ApiClient] - shellyplus2pm-80646fdb89e0: API value detached was mapped to momentary
2023-10-14 09:27:55.448 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP GET for http://192.168.1.221/shelly
Content-Type: application/x-www-form-urlencoded
2023-10-14 09:27:55.462 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP Response 200: {"name":"LightsGarage","id":"shellyplus2pm-80646fdb89e0","mac":"80646FDB89E0","slot":1,"model":"SNSW-102P16EU","gen":2,"fw_id":"20230912-081945/1.0.3-g6176478","ver":"1.0.3","app":"Plus2PM","auth_en":false,"auth_domain":null,"profile":"switch"}
Content-Length: 244
Pragma: no-cache
Connection: close
2023-10-14 09:27:55.463 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: Closing Rpc API (socket is connected, discovery=true)
2023-10-14 09:27:55.464 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: Disconnecting WebSocket (/192.168.1.15:47678 -> /192.168.1.221:80)
2023-10-14 09:27:55.465 [TRACE] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: Rpc connection closed: 1006 - Disconnected
2023-10-14 09:27:55.471 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket connection closed, status = 1006/Disconnected
2023-10-14 09:27:55.473 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Shelly settings : {"ble":{"enable":false},"cloud":{"enable":false,"server":"shelly-78-eu.shelly.cloud:6022/jrpc
"},"mqtt":{"enable":false,"rpc_ntf":"true","status_ntf":"false"},"sys":{"cfg_rev":19,"device":{"name":"LightsGarage","mac":"80646FDB89E0","fw_id":"20230912-081945/1.0.3-g6176478","profile":"switch","eco_mode":tru
e,"discoverable":true},"location":{"tz":"Pacific/Auckland","lat":-36.8453,"lon":174.75752},"sntp":{"server":"time.google.com"},"debug":{"mqtt":{"enable":false},"websocket":{"enable":false},"udp":null},"ui_data":n
ull,"rpc_udp":{}},"wifi":{"ap":{"enable":false,"ssid":"ShellyPlus2PM-80646FDB89E0","is_open":true,"range_extender":{"enable":false}},"sta":{"ssid":"OscarSlow","is_open":false,"enable":true,"ipv4mode":"dhcp"},"sta
1":{"is_open":true,"enable":false,"ipv4mode":"dhcp"},"roam":{"rssi_thr":-80,"interval":60}},"input:0":{"id":0,"type":"button","invert":false,"factory_reset":true},"input:1":{"id":1,"type":"button","invert":false,
"factory_reset":true},"switch:0":{"id":0,"in_mode":"detached","initial_state":"off","auto_on":false,"auto_on_delay":60.0,"auto_off":false,"auto_off_delay":60.0,"power_limit":2800,"voltage_limit":280,"current_limi
t":10.0},"switch:1":{"id":1,"in_mode":"detached","initial_state":"off","auto_on":false,"auto_on_delay":60.0,"auto_off":false,"auto_off_delay":60.0,"power_limit":2800,"voltage_limit":280,"current_limit":10.0}}
2023-10-14 09:27:55.474 [TRACE] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: thingType=shellyplus2pm, deviceType=SNSW-102P16EU, mode=relay, symbolic name=LightsGarage
2023-10-14 09:27:55.475 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Adding Shelly LightsGarage, UID=shelly:shellyplus2pm-relay:80646fdb89e0
2023-10-14 09:27:55.482 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Shelly device discovered: IP-Adress=192.168.1.221, type=shellyplus2pm
2023-10-14 09:27:55.570 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: Connect Rpc Socket (discovery = true)
2023-10-14 09:27:55.575 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: Connect WebSocket, URI=ws://192.168.1.221/rpc
2023-10-14 09:27:55.590 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP POST for http://192.168.1.221/rpc {"id":223212011,"src":"shellyplus2pm-80646fdb89e0","method":"Shelly.GetConfig"}
2023-10-14 09:27:55.732 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: WebSocket connected /192.168.1.15:47684<-/192.168.1.221:80, Idle Timeout=2147483647
2023-10-14 09:27:55.743 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP Response 200: {"id":223212011,"src":"shellyplus2pm-80646fdb89e0","dst":"shellyplus2pm-80646fdb89e0","result":{"ble":{"enable":false,"rpc":{"enable":true},"observer":{"enable":false}},"cloud":{"enable":false,"server":"shelly-78-eu.shelly.cloud:6022/jrpc"},"input:0":{"id":0,"name":null,"type":"button","invert":false,"factory_reset":true},"input:1":{"id":1,"name":null,"type":"button","invert":false,"factory_reset":true},"mqtt":{"enable":false,"server":null,"client_id":"shellyplus2pm-80646fdb89e0","user":null,"topic_prefix":"shellyplus2pm-80646fdb89e0","rpc_ntf":true,"status_ntf":false,"use_client_cert":false,"enable_rpc":true,"enable_control":true},"switch:0":{"id":0, "name":null,"in_mode":"detached","initial_state":"off", "auto_on":false, "auto_on_delay":60.00, "auto_off":false, "auto_off_delay":60.00,"power_limit":2800,"voltage_limit":280,"undervoltage_limit":0,"autorecover_voltage_errors":false,"current_limit":10.000},"switch:1":{"id":1, "name":null,"in_mode":"detached","initial_state":"off", "auto_on":false, "auto_on_delay":60.00, "auto_off":false, "auto_off_delay":60.00,"power_limit":2800,"voltage_limit":280,"undervoltage_limit":0,"autorecover_voltage_errors":false,"current_limit":10.000},"sys":{"device":{"name":"LightsGarage","mac":"80646FDB89E0","fw_id":"20230912-081945/1.0.3-g6176478","discoverable":true,"eco_mode":true,"profile":"switch","addon_type":null},"location":{"tz":"Pacific/Auckland","lat":-36.845300,"lon":174.757520},"debug":{"level":2,"file_level":null,"mqtt":{"enable":false},"websocket":{"enable":false},"udp":{"addr":null}},"ui_data":null,"rpc_udp":{"dst_addr":null,"listen_port":null},"sntp":{"server":"time.google.com"},"cfg_rev":19},"wifi":{"ap":{"ssid":"ShellyPlus2PM-80646FDB89E0","is_open":true, "enable":false, "range_extender": {"enable":false}},"sta":{"ssid":"OscarSlow","is_open":false, "enable":true, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"sta1":{"ssid":null,"is_open":true, "enable":false, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"roam":{"rssi_thr":-80,"interval":60}},"ws":{"enable":false,"server":null,"ssl_ca":"ca.pem"}}}
Connection: close
2023-10-14 09:27:55.749 [TRACE] [helly.internal.api2.Shelly2ApiClient] - shellyplus2pm-80646fdb89e0: API value detached was mapped to momentary
2023-10-14 09:27:55.751 [TRACE] [helly.internal.api2.Shelly2ApiClient] - shellyplus2pm-80646fdb89e0: API value detached was mapped to momentary
2023-10-14 09:27:55.752 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP GET for http://192.168.1.221/shelly
2023-10-14 09:27:55.765 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP Response 200: {"name":"LightsGarage","id":"shellyplus2pm-80646fdb89e0","mac":"80646FDB89E0","slot":1,"model":"SNSW-102P16EU","gen":2,"fw_id":"20230912-081945/1.0.3-g6176478","ver":"1.0.3","app":"Plus2PM","auth_en":false,"auth_domain":null,"profile":"switch"}
Content-Length: 244
Pragma: no-cache
Connection: close
2023-10-14 09:27:55.766 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: Closing Rpc API (socket is connected, discovery=true)
2023-10-14 09:27:55.768 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: Disconnecting WebSocket (/192.168.1.15:47684 -> /192.168.1.221:80)
2023-10-14 09:27:55.769 [TRACE] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: Rpc connection closed: 1006 - Disconnected
2023-10-14 09:27:55.773 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket connection closed, status = 1006/Disconnected
2023-10-14 09:27:55.776 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Shelly settings : {"ble":{"enable":false},"cloud":{"enable":false,"server":"shelly-78-eu.shelly.cloud:6022/jrpc"},"mqtt":{"enable":false,"rpc_ntf":"true","status_ntf":"false"},"sys":{"cfg_rev":19,"device":{"name":"LightsGarage","mac":"80646FDB89E0","fw_id":"20230912-081945/1.0.3-g6176478","profile":"switch","eco_mode":true,"discoverable":true},"location":{"tz":"Pacific/Auckland","lat":-36.8453,"lon":174.75752},"sntp":{"server":"time.google.com"},"debug":{"mqtt":{"enable":false},"websocket":{"enable":false},"udp":null},"ui_data":null,"rpc_udp":{}},"wifi":{"ap":{"enable":false,"ssid":"ShellyPlus2PM-80646FDB89E0","is_open":true,"range_extender":{"enable":false}},"sta":{"ssid":"OscarSlow","is_open":false,"enable":true,"ipv4mode":"dhcp"},"sta1":{"is_open":true,"enable":false,"ipv4mode":"dhcp"},"roam":{"rssi_thr":-80,"interval":60}},"input:0":{"id":0,"type":"button","invert":false,"factory_reset":true},"input:1":{"id":1,"type":"button","invert":false,"factory_reset":true},"switch:0":{"id":0,"in_mode":"detached","initial_state":"off","auto_on":false,"auto_on_delay":60.0,"auto_off":false,"auto_off_delay":60.0,"power_limit":2800,"voltage_limit":280,"current_limit":10.0},"switch:1":{"id":1,"in_mode":"detached","initial_state":"off","auto_on":false,"auto_on_delay":60.0,"auto_off":false,"auto_off_delay":60.0,"power_limit":2800,"voltage_limit":280,"current_limit":10.0}}
2023-10-14 09:27:55.777 [TRACE] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: thingType=shellyplus2pm, deviceType=SNSW-102P16EU, mode=relay, symbolic name=LightsGarage
2023-10-14 09:27:55.778 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Adding Shelly LightsGarage, UID=shelly:shellyplus2pm-relay:80646fdb89e0
2023-10-14 09:27:59.041 [TRACE] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-LightsMaster: Inbound Rpc message: {"src":"shellyplus2pm-80646fdbe00c","dst":"shellyplus2pm-80646fdbe00c","method":"NotifyStatus","params":{"ts":1697228880.59,"switch:0":{"id":0,"aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1697228879,"total":99.718}}}}
2023-10-14 09:27:59.046 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdbe00c: NotifyStatus update received: {"src":"shellyplus2pm-80646fdbe00c","dst":"shellyplus2pm-80646fdbe00c","method":"NotifyStatus","params":{"ts":1.69722888059E9,"switch:0":{"id":0,"aenergy":{"total":99.718,"by_minute":[0.0,0.0,0.0],"minute_ts":1697228879}}}}
2023-10-14 09:27:59.048 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus2pm-80646fdbe00c: Watchdog restarted (expires in 70 sec)
20
Example of one that doesn’t look fine:
2023-10-14 09:29:29.659 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-083af2028610: Shelly device discovered: IP-Adress=[fe80:0:0:0:a3a:f2ff:fe02:8610], type=shellyplus1
2023-10-14 09:29:29.677 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: Connect Rpc Socket (discovery = true)
2023-10-14 09:29:29.678 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus1-083af2028610: Connect WebSocket, URI=ws://[fe80:0:0:0:a3a:f2ff:fe02:8610]/rpc
2023-10-14 09:29:29.703 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2028610: HTTP POST for http://[fe80:0:0:0:a3a:f2ff:fe02:8610]/rpc {"id":2069135274,"src":"shellyplus1-083af2028610","metho
2023-10-14 09:29:29.707 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: WebSocket error
2023-10-14 09:29:29.708 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-083af2028610: Device discovery of device with address [fe80:0:0:0:a3a:f2ff:fe02:8610] failed: SocketException: Could not connect to /[fe80:0:0:0:a3a:f2ff:fe02:8610]:80
2023-10-14 09:29:29.709 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@32229825 name: 'shellyplus1-083af2028610._http._tcp.local.' address: '(null):0' status: 'DNS: raspberrypi2-planar-id-au.local. [raspberrypi2.planar.id.au/192.168.1.15] state: probing 1 task: null', has NO data
shellyplus1-083af2028610._http._tcp.local.: ]
2023-10-14 09:29:34.239 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793a94fe8: HTTP POST for http://192.168.1.232/rpc {"id":1556476533,"src":"shellyplus1-441793a94fe8","method":"Shelly.GetStatus"}
2023-10-14 09:29:34.381 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793a94fe8: HTTP Response 200: {"id":1556476533,"src":"shellyplus1-441793a94fe8","dst":"shellyplus1-441793a94fe8","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":29.0, "tF":84.2}},"sys":{"mac":"441793A94FE8","restart_required":false,"time":"09:29","unixtime":1697228975,"uptime":2352238,"ram_size":244884,"ram_free":146300,"fs_size":458752,"fs_free":159744,"cfg_rev":14,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.232","status":"got ip","ssid":"OscarSlow","rssi":-59},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 09:29:34.383 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-441793a94fe8: Watchdog restarted (expires in 70 sec)
2023-10-14 09:29:34.384 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-441793a94fe8: Updating 1 relay(s)
2023-10-14 09:29:34.738 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2029730: HTTP POST for http://192.168.1.225/rpc {"id":1887434093,"src":"shellyplus1-083af2029730","method":"Shelly.GetStatus"}
I think the difference between those two is the IPv6 address. Having said that, it doesn’t look frequent enough to be causing the thread growth I’m getting.
OK. Doing a more systematic analysis. I’ve restarted openhab from scratch and let it stabilise, I have full trace log of that restart.
At 10:47am I had 125 threads that were WebSocket related. Between 10:48:42 and 10:48:48 I got 8 more threads, and that stayed static for a while. (I got very lucky hitting the exact time it jumped) Whatever it is, it’s more than 5 minutes apart:
pi@raspberrypi2:~ $ sudo jstack 24195 | grep WebSocket | wc -l
125
pi@raspberrypi2:~ $ date; sudo jstack 24195 | grep WebSocket | wc -l
Sat 14 Oct 2023 10:47:47 NZDT
125
Sat 14 Oct 2023 10:48:42 NZDT
125
Sat 14 Oct 2023 10:48:48 NZDT
133
Sat 14 Oct 2023 10:49:41 NZDT
133
Sat 14 Oct 2023 10:50:34 NZDT
133
Sat 14 Oct 2023 10:52:08 NZDT
133
Sat 14 Oct 2023 10:52:26 NZDT
133
Sat 14 Oct 2023 10:53:12 NZDT
133
Sat 14 Oct 2023 10:53:42 NZDT
133
Sat 14 Oct 2023 10:53:51 NZDT
133
In the log in that time slice there are two interesting things:
- Exactly 8 HTTP post commands. And 8 new threads. Problem is there’s heaps of HTTP posts everywhere else and the thread counts aren’t increasing
- Exactly a single WebSocket error. Perhaps that error causes 8 threads?
2023-10-14 10:48:42.238 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP POST for http://192.168.1.221/rpc {"id":1112583018,"src":"shellyplus2pm-80646fdb89e0","method":"Shelly.Get
Status"}
2023-10-14 10:48:42.238 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793a86d40: HTTP POST for http://192.168.1.149/rpc {"id":1479566910,"src":"shellyplus1-441793a86d40","method":"Shelly.GetStat
us"}
2023-10-14 10:48:42.241 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2028610: HTTP POST for http://192.168.1.235/rpc {"id":1841861816,"src":"shellyplus1-083af2028610","method":"Shelly.GetStat
us"}
2023-10-14 10:48:42.241 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793aa6bf8: HTTP POST for http://192.168.1.120/rpc {"id":931069525,"src":"shellyplus1-441793aa6bf8","method":"Shelly.GetStatu
s"}
2023-10-14 10:48:42.242 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba16f8: HTTP POST for http://192.168.1.226/rpc {"id":1606624934,"src":"shellyplus1-a8032aba16f8","method":"Shelly.GetStat
us"}
2023-10-14 10:48:42.357 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2028610: HTTP Response 200: {"id":1841861816,"src":"shellyplus1-083af2028610","dst":"shellyplus1-083af2028610","result":{"
ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":28.8, "tF":83.8}},"sys":{"mac":"083AF202
8610","restart_required":false,"time":"10:48","unixtime":1697233723,"uptime":2357108,"ram_size":244888,"ram_free":146332,"fs_size":458752,"fs_free":159744,"cfg_rev":14,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0
,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.235","status":"got ip","ssid":"OscarSlow","rssi":-67},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 10:48:42.360 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-083af2028610: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:42.361 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-083af2028610: Updating 1 relay(s)
2023-10-14 10:48:42.369 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP Response 200: {"id":1112583018,"src":"shellyplus2pm-80646fdb89e0","dst":"shellyplus2pm-80646fdb89e0","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"input:1":{"id":1,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false, "apower":0.0, "voltage":242.8, "freq":50.0, "current":0.000, "pf":0.00, "aenergy":{"total":268.909,"by_minute":[0.000,0.000,0.000],"minute_ts":1697233721},"temperature":{"tC":22.8, "tF":73.0}},"switch:1":{"id":1, "source":"HTTP_in", "output":false, "apower":0.0, "voltage":242.9, "freq":50.0, "current":0.000, "pf":0.00, "aenergy":{"total":206.781,"by_minute":[0.000,0.000,0.000],"minute_ts":1697233721},"temperature":{"tC":22.8, "tF":73.0}},"sys":{"mac":"80646FDB89E0","restart_required":false,"time":"10:48","unixtime":1697233722,"uptime":2356741,"ram_size":243372,"ram_free":140076,"fs_size":458752,"fs_free":143360,"cfg_rev":19,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.221","status":"got ip","ssid":"OscarSlow","rssi":-56},"ws":{"connected":false}}}
Content-Length: 1122
Connection: close
2023-10-14 10:48:42.373 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus2pm-80646fdb89e0: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:42.374 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus2pm-80646fdb89e0: Updating 2 relay(s)
2023-10-14 10:48:42.419 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793aa6bf8: HTTP Response 200: {"id":931069525,"src":"shellyplus1-441793aa6bf8","dst":"shellyplus1-441793aa6bf8","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":30.0, "tF":86.1}},"sys":{"mac":"441793AA6BF8","restart_required":false,"time":"10:48","unixtime":1697233722,"uptime":1539341,"ram_size":244880,"ram_free":146912,"fs_size":458752,"fs_free":159744,"cfg_rev":17,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.120","status":"got ip","ssid":"OscarSlow","rssi":-52},"ws":{"connected":false}}}
Content-Length: 680
Connection: close
2023-10-14 10:48:42.423 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-441793aa6bf8: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:42.424 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-441793aa6bf8: Updating 1 relay(s)
2023-10-14 10:48:43.435 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793a86d40: HTTP Response 200: {"id":1479566910,"src":"shellyplus1-441793a86d40","dst":"shellyplus1-441793a86d40","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":27.6, "tF":81.6}},"sys":{"mac":"441793A86D40","restart_required":false,"time":"10:48","unixtime":1697233724,"uptime":1539532,"ram_size":244884,"ram_free":146928,"fs_size":458752,"fs_free":159744,"cfg_rev":17,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.149","status":"got ip","ssid":"OscarSlow","rssi":-65},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 10:48:43.438 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-441793a86d40: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:43.439 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-441793a86d40: Updating 1 relay(s)
2023-10-14 10:48:43.448 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba16f8: HTTP Response 200: {"id":1606624934,"src":"shellyplus1-a8032aba16f8","dst":"shellyplus1-a8032aba16f8","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":28.9, "tF":84.0}},"sys":{"mac":"A8032ABA16F8","restart_required":false,"time":"10:48","unixtime":1697233724,"uptime":1539451,"ram_size":244892,"ram_free":147116,"fs_size":458752,"fs_free":159744,"cfg_rev":14,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.226","status":"got ip","ssid":"OscarSlow","rssi":-41},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 10:48:43.451 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-a8032aba16f8: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:43.452 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-a8032aba16f8: Updating 1 relay(s)
2023-10-14 10:48:45.242 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba1704: HTTP POST for http://192.168.1.171/rpc {"id":1112383377,"src":"shellyplus1-a8032aba1704","method":"Shelly.GetStatus"}
2023-10-14 10:48:45.242 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af202a350: HTTP POST for http://192.168.1.200/rpc {"id":1015284757,"src":"shellyplus1-083af202a350","method":"Shelly.GetStatus"}
2023-10-14 10:48:45.330 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af202a350: HTTP Response 200: {"id":1015284757,"src":"shellyplus1-083af202a350","dst":"shellyplus1-083af202a350","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":27.4, "tF":81.4}},"sys":{"mac":"083AF202A350","restart_required":false,"time":"10:48","unixtime":1697233725,"uptime":2356944,"ram_size":244884,"ram_free":146256,"fs_size":458752,"fs_free":159744,"cfg_rev":19,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.200","status":"got ip","ssid":"OscarSlow","rssi":-44},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 10:48:45.335 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-083af202a350: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:45.337 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-083af202a350: Updating 1 relay(s)
2023-10-14 10:48:45.364 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba1704: HTTP Response 200: {"id":1112383377,"src":"shellyplus1-a8032aba1704","dst":"shellyplus1-a8032aba1704","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":29.3, "tF":84.7}},"sys":{"mac":"A8032ABA1704","restart_required":false,"time":"10:48","unixtime":1697233725,"uptime":1000688,"ram_size":244884,"ram_free":146292,"fs_size":458752,"fs_free":159744,"cfg_rev":15,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.171","status":"got ip","ssid":"OscarSlow","rssi":-44},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 10:48:45.369 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-a8032aba1704: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:45.371 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-a8032aba1704: Updating 1 relay(s)
2023-10-14 10:48:45.376 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793a94fe8: HTTP POST for http://192.168.1.232/rpc {"id":1407649818,"src":"shellyplus1-441793a94fe8","method":"Shelly.GetStatus"}
2023-10-14 10:48:45.379 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2029730: HTTP POST for http://192.168.1.225/rpc {"id":1087308892,"src":"shellyplus1-083af2029730","method":"Shelly.GetStatus"}
2023-10-14 10:48:45.536 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2029730: HTTP Response 200: {"id":1087308892,"src":"shellyplus1-083af2029730","dst":"shellyplus1-083af2029730","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":29.9, "tF":85.8}},"sys":{"mac":"083AF2029730","restart_required":false,"time":"10:48","unixtime":1697233726,"uptime":2357121,"ram_size":244888,"ram_free":146488,"fs_size":458752,"fs_free":159744,"cfg_rev":22,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.225","status":"got ip","ssid":"OscarSlow","rssi":-55},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 10:48:45.538 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793a94fe8: HTTP Response 200: {"id":1407649818,"src":"shellyplus1-441793a94fe8","dst":"shellyplus1-441793a94fe8","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":29.6, "tF":85.4}},"sys":{"mac":"441793A94FE8","restart_required":false,"time":"10:48","unixtime":1697233726,"uptime":2356994,"ram_size":244884,"ram_free":146288,"fs_size":458752,"fs_free":159744,"cfg_rev":14,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.232","status":"got ip","ssid":"OscarSlow","rssi":-55},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
2023-10-14 10:48:45.541 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-083af2029730: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:45.542 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-083af2029730: Updating 1 relay(s)
2023-10-14 10:48:45.543 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellyplus1-441793a94fe8: Watchdog restarted (expires in 70 sec)
2023-10-14 10:48:45.545 [TRACE] [.internal.handler.ShellyRelayHandler] - shellyplus1-441793a94fe8: Updating 1 relay(s)
2023-10-14 10:48:45.737 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-a8032aba1704: Shelly device discovered: IP-Adress=[fe80:0:0:0:aa03:2aff:feba:1704], type=shellyplus1
2023-10-14 10:48:45.784 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: Connect Rpc Socket (discovery = true)
2023-10-14 10:48:45.787 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus1-a8032aba1704: Connect WebSocket, URI=ws://[fe80:0:0:0:aa03:2aff:feba:1704]/rpc
2023-10-14 10:48:45.819 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba1704: HTTP POST for http://[fe80:0:0:0:aa03:2aff:feba:1704]/rpc {"id":1386121328,"src":"shellyplus1-a8032aba1704","method":"Shelly.GetConfig"}
2023-10-14 10:48:45.821 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: WebSocket error
2023-10-14 10:48:45.824 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-a8032aba1704: Device discovery of device with address [fe80:0:0:0:aa03:2aff:feba:1704] failed: SocketException: Could not connect to /[fe80:0:0:0:aa03:2aff:feba:1704]:80
2023-10-14 10:48:45.826 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@12166329 name: 'shellyplus1-a8032aba1704._http._tcp.local.' address: '(null):0' status: 'DNS: raspberrypi2-planar-id-au.local. [raspberrypi2.planar.id.au/192.168.1.15] state: probing 1 task: null', has NO data
shellyplus1-a8032aba1704._http._tcp.local.: ]
2023-10-14 10:48:59.879 [TRACE] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-LightsMaster: Inbound Rpc message: {"src":"shellyplus2pm-80646fdbe00c","dst":"shellyplus2pm-80646fdbe00c","method":"NotifyStatus","params":{"ts":1697233740.90,"switch:0":{"id":0,"aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1697233739,"total":99.718}}}}
There are three WebSocket errors in the log in total. The first two are before the count. The third one coincides with the thread growth.
Since that point I’ve had no more thread growth, and no more errors of that form.
pi@raspberrypi2:~ $ while true; do date; sudo jstack 24195 | grep WebSocket | wc -l; sleep 60; done > threadcount.txt & tail -f threadcount.txt
[1] 30478
Sat 14 Oct 2023 11:37:56 NZDT
133
I’ll leave the monitoring running, and see if I can correlate any future growth in threads to web socket errors.
Addendum. More thread growth - 24 threads in total:
Sat 14 Oct 2023 11:54:17 NZDT
133
Sat 14 Oct 2023 11:55:18 NZDT
157
In the openhab log there are three instances of WebSocket error in that time period. No other instances of that error since the previous report. So, at 8 threads per socket error, that’s pretty indicative.
2023-10-14 11:54:55.796 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Shelly device discovered: IP-Adress=[fe80:0:0:0:8264:6fff:fedb:89e0], type=shellyplus2pm
2023-10-14 11:54:55.816 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: Connect Rpc Socket (discovery = true)
2023-10-14 11:54:55.818 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus2pm-80646fdb89e0: Connect WebSocket, URI=ws://[fe80:0:0:0:8264:6fff:fedb:89e0]/rpc
2023-10-14 11:54:55.863 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus2pm-80646fdb89e0: HTTP POST for http://[fe80:0:0:0:8264:6fff:fedb:89e0]/rpc {"id":1582461854,"src":"shellyplus2pm-80646fdb89e0","
2023-10-14 11:54:55.866 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket error
2023-10-14 11:54:55.868 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus2pm-80646fdb89e0: Device discovery of device with address [fe80:0:0:0:8264:6fff:fedb:89e0] failed: SocketException: Could not connect to /[fe80:0:0:0:8264:6fff:fedb:89e0]:80
2023-10-14 11:54:55.870 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-083af2028610: Shelly device discovered: IP-Adress=[fe80:0:0:0:a3a:f2ff:fe02:8610], type=shellyplus1
2023-10-14 11:54:55.888 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: Connect Rpc Socket (discovery = true)
2023-10-14 11:54:55.890 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus1-083af2028610: Connect WebSocket, URI=ws://[fe80:0:0:0:a3a:f2ff:fe02:8610]/rpc
2023-10-14 11:54:55.918 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2028610: HTTP POST for http://[fe80:0:0:0:a3a:f2ff:fe02:8610]/rpc {"id":1487149131,"src":"shellyplus1-083af2028610","method":"Shelly.GetConfig"}
2023-10-14 11:54:55.921 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: WebSocket error
2023-10-14 11:54:55.923 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-083af2028610: Device discovery of device with address [fe80:0:0:0:a3a:f2ff:fe02:8610] failed: SocketException: Could not connect to /[fe80:0:0:0:a3a:f2ff:fe02:8610]:80
2023-10-14 11:54:55.925 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@24504214 name: 'shellyplus2pm-80646fdb89e0._http._tcp.local.' address: '(null):80' status: 'DNS: raspberrypi2-planar-id-au.local. [raspberrypi2.planar.id.au/192.168.1.15] state: probing 1 task: null', has NO data, empty]
2023-10-14 11:54:55.927 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-a8032aba1704: Shelly device discovered: IP-Adress=[fe80:0:0:0:aa03:2aff:feba:1704], type=shellyplus1
2023-10-14 11:54:55.943 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: Connect Rpc Socket (discovery = true)
2023-10-14 11:54:55.943 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus1-a8032aba1704: Connect WebSocket, URI=ws://[fe80:0:0:0:aa03:2aff:feba:1704]/rpc
2023-10-14 11:54:55.964 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba1704: HTTP POST for http://[fe80:0:0:0:aa03:2aff:feba:1704]/rpc {"id":748622270,"src":"shellyplus1-a8032aba1704","method":"Shelly.GetConfig"}
2023-10-14 11:54:55.964 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: WebSocket error
2023-10-14 11:54:55.967 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-a8032aba1704: Device discovery of device with address [fe80:0:0:0:aa03:2aff:feba:1704] failed: SocketException: Could not connect to /[fe80:0:0:0:aa03:2aff:feba:1704]:80
2023-10-14 11:54:55.968 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@1287577 name: 'shellyplus1-441793a94fe8._http._tcp.local.' address: '(null):80' status: 'DNS: raspberrypi2-planar-id-au.local. [raspberrypi2.planar.id.au/192.168.1.15] state: probing 1 task: null', has NO data, empty]
2023-10-14 11:54:55.969 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@28777544 name: 'shellyplus1-083af2028610._http._tcp.local.' address: '(null):0' status: 'DNS: raspberrypi2-planar-id-au.local. [raspberrypi2.planar.id.au/192.168.1.15] state: probing 1 task: null', has NO data
2023-10-14 11:54:55.971 [DEBUG] [discovery.ShellyDiscoveryParticipant] - ServiceInfo [ServiceInfoImpl@22705168 name: 'shellyplus1-a8032aba1704._http._tcp.local.' address: '(null):0' status: 'DNS: raspberrypi2-planar-id-au.local. [raspberrypi2.planar.id.au/192.168.1.15] state: probing 1 task: null', has NO data
2023-10-14 11:54:56.359 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba1704: HTTP POST for http://192.168.1.171/rpc {"id":1738018206,"src":"shellyplus1-a8032aba1704","method":"Shelly.GetStatus"}
2023-10-14 11:54:56.526 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-a8032aba1704: HTTP Response 200: {"id":1738018206,"src":"shellyplus1-a8032aba1704","dst":"shellyplus1-a8032aba1704","result":{"ble":null,"cloud":{"connected":false},"input:0":{"id":0,"state":null},"mqtt":{"connected":false},"switch:0":{"id":0, "source":"HTTP_in", "output":false,"temperature":{"tC":28.7, "tF":83.7}},"sys":{"mac":"A8032ABA1704","restart_required":false,"time":"11:54","unixtime":1697237697,"uptime":1004663,"ram_size":244884,"ram_free":146292,"fs_size":458752,"fs_free":159744,"cfg_rev":15,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"available_updates":{"beta":{"version":"1.0.7-beta1"}}},"wifi":{"sta_ip":"192.168.1.171","status":"got ip","ssid":"OscarSlow","rssi":-49},"ws":{"connected":false}}}
Content-Length: 681
Connection: close
Another 24 threads in the 11:56 window:
Sat 14 Oct 2023 11:56:20 NZDT
157
Sat 14 Oct 2023 11:57:21 NZDT
181
Again three errors in the log in that 1 minute slot. They’re a bit more spaced out in the log so I won’t include them, but they look similar.
@laursen @markus7017 you guys following this?
sorry to ping you guys directly but this is getting interesting
Adding detail. I have:
- 24 threads between 11:56:20 and 11:57:21
- 16 threads between 12:01:26 and 12:02:28
- 16 threads between 12:02:28 and 12:03:29
- 16 threads between 12:11:40 and 12:12:42
- 8 threads between 12:12:42 and 12:13:43, but then a drop back again between 12:13:43 and 12:14:44
- 16 threads between 12:14:44 and 12:15:46
- 8 threads between 12:19:51 and 12:20:53
- 8 threads between 12:20:53 and 12:21:54
- 8 threads between 12:24:58 and 12:26:00
- 16 threads between 12:30:06 and 12:31:07
- 16 threads between 12:35:13 and 12:36:14
- 16 threads between 12:38:17 and 12:39:18
None since.
Running a grep over the log for “WebSocket error”, I get the following list:
2023-10-14 10:46:35.836 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket error
2023-10-14 10:46:35.916 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2029730: WebSocket error
2023-10-14 10:46:55.789 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: WebSocket error
2023-10-14 11:56:56.112 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket error
2023-10-14 11:56:56.460 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-441793aa9040: WebSocket error
2023-10-14 11:56:56.663 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2029730: WebSocket error
2023-10-14 12:02:26.128 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af202a350: WebSocket error
2023-10-14 12:02:26.333 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2029730: WebSocket error
2023-10-14 12:02:36.115 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: WebSocket error
2023-10-14 12:02:36.659 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: WebSocket error
2023-10-14 12:12:35.862 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket error
2023-10-14 12:12:35.903 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: WebSocket error
2023-10-14 12:15:16.204 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket error
2023-10-14 12:15:16.481 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-441793a94fe8: WebSocket error
2023-10-14 12:20:05.866 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: WebSocket error
2023-10-14 12:21:16.592 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2028610: WebSocket error
2023-10-14 12:25:36.105 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2029730: WebSocket error
2023-10-14 12:30:15.873 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket error
2023-10-14 12:30:35.873 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: WebSocket error
2023-10-14 12:36:06.150 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-441793aa9040: WebSocket error
2023-10-14 12:36:06.458 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus2pm-80646fdb89e0: WebSocket error
2023-10-14 12:38:26.086 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2029730: WebSocket error
2023-10-14 12:38:26.122 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-a8032aba1704: WebSocket error
This aligns in each time period:
- 3 at 11:56
- 2 at 12:02:26
- 2 at 12:02:36
- 2 at 12:12:35
- Assume the 12:12 set were just timing - the threads were there but correctly destroyed again
- 2 at 12:15:16
- 1 at 12:20:05
- 1 at 12:21:16
- 1 at 12:25:36
- 2 in the 12:30 slot (12:30:15 and 12:30:35)
- 2 at 12:36:06
- 2 at 12:38:26
In short, every instance of “Websocket error” results in 8 additional threads, no thread increase occurs other than at a time that error message appears in the log.
In each case it was looking for a device on an IPv6 address. In each case the messages are broadly similar to:
2023-10-14 12:15:16.483 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-441793a94fe8: Device discovery of device with address [fe80:0:0:0:4617:93ff:fea9:4fe8] failed: SocketException: Could not connect to /[fe80:0:0:0:4617:93ff:fea9:4fe8]:80
2023-10-14 12:15:16.484 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-441793a94fe8: Shelly device discovered: IP-Adress=192.168.1.232, type=shellyplus1
2023-10-14 12:15:16.494 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-441793a94fe8: Connect Rpc Socket (discovery = true)
2023-10-14 12:15:16.495 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus1-441793a94fe8: Connect WebSocket, URI=ws://192.168.1.232/rpc
2023-10-14 12:15:16.510 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-441793a94fe8: HTTP POST for http://192.168.1.232/rpc {"id":1961832137,"src":"shellyplus1-441793a94fe8","method":"Shelly.GetConfig"}
I note that sometimes the “Device discovery failed” message comes before the WebSocket error, sometimes afterwards. That may be a logging anomaly rather than indicating it sometimes runs out of sequence, but it’s worth noting.
The log is a bit large to upload (5.1MB), I can load any excerpts that are useful.
Edit: I’ve continued monitoring for another 3-4 hours. There are plenty of times it’s stable for an hour or more, also periods where it’s creating new threads. All those instances still correlate with this error in the log. Current total @ 16:04 is 565 threads.
If I was guessing, I’d say around line 145 of ShellyDiscoveryParticipant.java, where we fail discovery but don’t terminate the connection:
try {
ShellyApiInterface api = gen2 ? new Shelly2ApiRpc(name, config, httpClient)
: new Shelly1HttpApi(name, config, httpClient);
api.initialize();
profile = api.getDeviceProfile(thingType);
api.close();
logger.debug("{}: Shelly settings : {}", name, profile.settingsJson);
deviceName = profile.name;
model = profile.deviceType;
mode = profile.mode;
properties = ShellyBaseHandler.fillDeviceProperties(profile);
logger.trace("{}: thingType={}, deviceType={}, mode={}, symbolic name={}", name, thingType,
profile.deviceType, mode.isEmpty() ? "<standard>" : mode, deviceName);
// get thing type from device name
thingUID = ShellyThingCreator.getThingUID(name, model, mode, false);
} catch (ShellyApiException e) {
ShellyApiResult result = e.getApiResult();
if (result.isHttpAccessUnauthorized()) {
logger.info("{}: {}", name, messages.get("discovery.protected", address));
// create shellyunknown thing - will be changed during thing initialization with valid credentials
thingUID = ShellyThingCreator.getThingUID(name, model, mode, true);
} else {
logger.debug("{}: {}", name, messages.get("discovery.failed", address, e.toString()));
} catch (IllegalArgumentException e) { // maybe some format description was buggy
logger.debug("{}: Discovery failed!", name, e);
Arguably line 169 could be where we put a WebSocket close.
Alternatively, it might be better handled in api2/Shelly2ApiRpc.java around line 723, perhaps we should be closing the web socket when we get a throwable error. Not sure what other errors would turn up in here, and whether some of them assume you don’t close the web socket.
public void onError(Throwable cause) {
logger.debug("{}: WebSocket error", thingName);
if (thing != null && thing.getProfile().alwaysOn) {
thingOffline("WebSocket error");
Meantime, I have disabled IPv6 on my RaspberryPi and restarted. If that solves my issue it also provides a pointer, although I’d suggest that while IPv6 discovery may be the proximate cause, the real cause is that the generic error handler isn’t closing the WebSocket. My particular errors relate to IPv6, but other people may have other errors that are occurring.
I think this stack exchange discussion may provide more clues and be relevant to the behavior you are seeing and why some devices are resolving to ipv6 address since ipv6 when enabled resolution is tried first by default.(debian seems to have enabled it for both by default) at least in my debian 12 clean build that line in nsswitch.conf is this .hosts: files mdns4_minimal [NOTFOUND-return] dns mylocalhostname
and of course, this wikipedia also adds to the understanding of the behaviors being seen.
This link talks about unix socket waiting behaviors as well.
All of which is true.
The main point here is that I didn’t deliberately enable IPv6, and had no expectation that my devices would communicate on IPv6. They all have IPv4 addresses. For whatever reason the discovery routines are finding them in IPv6, not noticing they’re an existing device that we already know on IPv4, attempting to communicate with them on IPv6, failing, then leaking the socket.
We can probably agree that it’d be better in my case if it wasn’t trying to use IPv6. I can control that myself. But for other people that may be beyond their experience or what they want to do. And ultimately, irrespective of the cause, when the discovery fails for whatever reason it should tidy up after itself.
Interestingly, I turned off IPv6 on my Raspberry Pi. And I’m still getting the leak, but for a different reason:
2023-10-14 16:43:31.071 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-083af2029730: Shelly device discovered: IP-Adress=[fe80:0:0:0:a3a:f2ff:fe02:9730], type=shellyplus1
2023-10-14 16:43:31.086 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2029730: Connect Rpc Socket (discovery = true)
2023-10-14 16:43:31.087 [DEBUG] [helly.internal.api2.Shelly2RpcSocket] - shellyplus1-083af2029730: Connect WebSocket, URI=ws://[fe80:0:0:0:a3a:f2ff:fe02:9730]/rpc
2023-10-14 16:43:31.103 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2029730: HTTP POST for http://[fe80:0:0:0:a3a:f2ff:fe02:9730]/rpc {"id":787696111,"src":"shellyplus1-083af2029730","method
2023-10-14 16:43:31.104 [DEBUG] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplus1-083af2029730: WebSocket error
2023-10-14 16:43:31.105 [TRACE] [shelly.internal.api.ShellyHttpClient] - shellyplus1-083af2029730: API call returned exception
org.openhab.binding.shelly.internal.api.ShellyApiException: java.util.concurrent.ExecutionException: java.nio.channels.UnsupportedAddressTypeException
at org.openhab.binding.shelly.internal.api.ShellyHttpClient.innerRequest(ShellyHttpClient.java:213) ~[?:?]
at org.openhab.binding.shelly.internal.api.ShellyHttpClient.httpPost(ShellyHttpClient.java:144) ~[?:?]
at org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc.rpcPost(Shelly2ApiRpc.java:1209) ~[?:?]
at org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc.apiRequest(Shelly2ApiRpc.java:1153) ~[?:?]
at org.openhab.binding.shelly.internal.api2.Shelly2ApiRpc.getDeviceProfile(Shelly2ApiRpc.java:169) ~[?:?]
at org.openhab.binding.shelly.internal.discovery.ShellyDiscoveryParticipant.createResult(ShellyDiscoveryParticipant.java:149) ~[?:?]
at org.openhab.core.config.discovery.mdns.internal.MDNSDiscoveryService.createDiscoveryResult(MDNSDiscoveryService.java:222) ~[?:?]
at org.openhab.core.config.discovery.mdns.internal.MDNSDiscoveryService.considerService(MDNSDiscoveryService.java:214) ~[?:?]
at org.openhab.core.config.discovery.mdns.internal.MDNSDiscoveryService.serviceResolved(MDNSDiscoveryService.java:207) ~[?:?]
at javax.jmdns.impl.ListenerStatus$ServiceListenerStatus.serviceResolved(ListenerStatus.java:106) ~[?:?]
at javax.jmdns.impl.JmDNSImpl$1.run(JmDNSImpl.java:911) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
Caused by: java.util.concurrent.ExecutionException: java.nio.channels.UnsupportedAddressTypeException
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:732) ~[?:?]
at org.openhab.binding.shelly.internal.api.ShellyHttpClient.innerRequest(ShellyHttpClient.java:180) ~[?:?]
... 15 more
Caused by: java.nio.channels.UnsupportedAddressTypeException
at sun.nio.ch.Net.checkAddress(Net.java:161) ~[?:?]
at sun.nio.ch.SocketChannelImpl.checkRemote(SocketChannelImpl.java:816) ~[?:?]
at sun.nio.ch.SocketChannelImpl.connect(SocketChannelImpl.java:839) ~[?:?]
at org.eclipse.jetty.client.AbstractConnectorHttpClientTransport.connect(AbstractConnectorHttpClientTransport.java:100) ~[?:?]
at org.eclipse.jetty.client.HttpClient$1.connect(HttpClient.java:665) ~[?:?]
at org.eclipse.jetty.client.HttpClient$1.succeeded(HttpClient.java:642) ~[?:?]
at org.eclipse.jetty.client.HttpClient$1.succeeded(HttpClient.java:634) ~[?:?]
at org.eclipse.jetty.util.SocketAddressResolver$Async.lambda$resolve$1(SocketAddressResolver.java:186) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
... 1 more
2023-10-14 16:43:31.121 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellyplus1-083af2029730: Device discovery of device with address [fe80:0:0:0:a3a:f2ff:fe02:9730] failed: java.nio.channels.UnsupportedAddressTypeException(class java.nio.channels.UnsupportedAddressTypeException)
It’s still finding the device on IPv6, but now the network stack gives an exception and refuses to attempt to connect. Which appears to still be leaking the WebSocket.
Yes, I agree the bindings behavior has changed. Without knowing what changed (if any thing) in your specific environment we can only guess as to why it suddenly started leaving web sockets open. I have been trying to repro this condition since the original post from the other user and reviewing his heap dump and other data also as an additional data point his issues also seemed to point back to discovery related problems.
I do not use shelly devices in my production home automation solution I use ZigBee and Zwave.
That was why I previously mentioned that discovery did not work for me in 4.x version but worked fine in 3.4x version. Since I had never had shelly devices in my environment, I found it even more interesting that it auto discovered fine on 3.4x and not at all on any 4.0 version using same hardware again another data point to look at since the transition from 3.4x to 4.0x included an application change as well as a java version change.
However, the issue was interesting enough to me to go out on amazon and purchase 2 shelly devices and add them to my test environment just to see if I could repro the problem. I still suspect this is a larger issue then just shelly devices. But until I could repro that I cannot say for sure if that is true. The point I am making here is the timed wait on the sockets is a known issue that occurs in other situations and can have more then 1 cause as the last link I pointed out discusses network packet drops such as what a weak Wi-Fi induces with random packet drops or network saturation interference from other wireless transmitters and so on. Those scenarios are all possible causes of web sockets hanging around for extended periods of time. Improving the error handling on this binding is definitely needed and the binding maintainer has a few updated versions in the pipeline based on what I read so perhaps this web socket clean-up is another one that will get implemented.
Agree in general.
I’ve reverted my IPv6 disabling, as it makes my MQTT unhappy (it’s trying to bind to an IPv6 address for some reason, which I could probably also disable, but since it doesn’t fix the leak anyway not much point).
I think the key, which started this overall thread I think, is to make sure all exception handlers clean up the Web sockets, otherwise we get leaks. And I think this particular one is traceable to an exception that didn’t clean up the Web socket.
I have no real ability to build and test, and Java isn’t a language I’ve spent any time with. I could probably have a go at a pull request, but in reality I’d just be chucking stuff at a wall that someone who knows what they’re doing could do way better.
All of which is fine. I can put in a daily/overnight restart of openhab and it will probably work adequately for the interim period.
Did one of you test the most recent binding change which is about web socket closing?
This change was merged 4 days ago.
OK. Working on that. It triggers a dependency on Gson, so working through how to resolve that.
Resolved Gson. But now have an unresolved dependency on slf4j. It looks to me like slf4j should be always included already, so I’m suspecting I’m breaking my installation. I can’t find just org.slf4j.jar, only things like org.slf4j-api.jar.
I think I’m out of my depth here unfortunately. I’m not sure I want to just randomly pull in additional modules until it works.
I’ve also downloaded the entire snapshot build, and unpacked it. There’s no slf4j jar in there, so I’m dubious that it’s required. Can anyone provide a hint as to what I may be missing?
OK, looks like I can install an entire snapshot version using apt. That seems safer in terms of it working, less safe in terms of upgrading my whole installation. Ah well.
I’m completely out of my depth and amazed by your debug attempts.
The only thing I can add is that there was a change with slf4j, although if you are on a later snapshot it was reported as fixed. openHAB 4.1 Milestone discussion - Setup, Configuration and Use / News & Important Changes - openHAB Community
I will wait to see what Paul’s results are as well but for me using the fresh snapshot install on a freshly built Debian 12 fully updated image with zulu17jdk installed via apt and install of Openhab snapshot version Build 3675 latest installed via apt added the shelly binding during initial setup console reports binding as version 4.1.0.202310130405 . I see no change in discovery working manually adding a new shelly thing works ok. Still unable to repro a leak no orphan socket…
On a separate note using Openhab 3.4 and java 11 discovery works fine. using open 3.4 and java 17(yes I know it was not a supported configuration) discovery does not find any device.
As far as I have been able do from a testing perspective.
Openhab 3.4 using recommended dependency’s normal build seems to work and discover shelly devices fine
any version of Openhab 4.x I have tested (using the exact set of instructions in the documentation) does not work with discovery on a freshly built clean load of Openhab (not a upgrade).
regardless of the underlying OS .
Saw same behavior on Linux as well as windows.
Same hardware for all tests.
Heap dump review does not indicate any anomaly’s
and 168 threads counted.
On a side note I really like the new 4.1 it is sweet being able to toggle the logging via the GUI.
For me, same behaviour with the snapshot build. I have openHAB 4.1.0 (build Build #3675).
The Shelly binding reports being 202310130405:
openhab> list -s |grep shelly
280 x Active x 80 x 4.1.0.202310130405 x org.openhab.binding.shelly
I’m seeing thread growth in bites of 8, and same symptom - associated with failed discovery and “WebSocket error” in the log at the time where the threads grow.
I think it makes sense to do some sort of WebSocket destroy as I noted in the above comment OH4 runs out of memory - #79 by PaulL1
Sorry guys, I was traveling and therefore couldn’t participate in debugging, but a great community made already progress
That’s a good finding and matches the symptoms with the Shelly Wall Display, which is not active as a thing, but causes the problem → because it sends mDNS discovery packets
I need to place the api.close() in a finally block so it gets called when request was processed, but also when it failed.
try {
api.initialize();
} else {
} finally |
api.close();
and also this is a good catch
The binding is currently not supporting IPv6 handling. Therefore I need to check the address family on discovery requests and refuse IPv6
I’ll look into that at the weekend.
That’s awesome thanks @markus7017. Let me know when it’s built through into snapshot for testing and I can try it out.
I try to work on this at the weekend
Please try this build, it’s based on the latest merge fixing one issue + 2 changes mentioned above, but doesn’t not include my pending PR changes. If the fix works,I’ll merge this with the latest changes. So use this build as a temporary trial (save the old jar, then remove from adding folder and check with bundle::list).
https://github.com/markus7017/myfiles/blob/master/shelly/org.openhab.binding.shelly-4.1.0-SNAPSHOToom.jar?raw=true
