yaya
(yaya)
April 2, 2024, 6:44am
1
Platform information:
Hardware: x86 vCPU / 4GB RAM / 32GB Storage
OS: debian 12.5
Java Runtime Environment: openJDK 17.0.9
openHAB version: 4.1.2
Issue of the topic: Spotify Widget
actually there are a lot of widgets for OH3 - I managed to take a note of some.
The prework is also working fine - i can see the information within the spotify plugin:
but once I am turning over to the widget, the given information is not available.
Using this widget: Spotify_Widget_by_Andi
anyone managed to run this on OH4?
JustinG
(JustinG)
April 2, 2024, 2:54pm
2
Your items do not all follow the naming scheme used by this widget. For example, the widget expects the Active Devices item to be the bridge name + _ActiveDevices
, but your item is the bridge name + _Active_Devices
Widgets do not really have the ability to detect items automatically. The method this widget uses of expecting all relevant item names to follow a specific pattern is the most common method in publically shared widget. So when you use a widget like this you have to have a match between your naming pattern and the widget’s pattern.
You will either need to recreate your items to have names that match the names used by the widget, or you will have to modify the widget code to use the item names you have.
yaya
(yaya)
April 2, 2024, 3:28pm
3
thank you @JustinG - I already had the same idea.
but I am really new into this and did not really understand the syntax…
Let me show an example:
uid: Spotify
tags: []
props:
parameters:
- description: Spotify
label: Static Title
required: false
type: TEXT
- context: item
label: Select a 'Spotify_Player_Bridge' (Spotify_Player_Bridge)
required: false
type: TEXT
parameterGroups: []
timestamp: Apr 1, 2024, 8:34:54 PM
component: f7-card
title: =props.title
style:
min-width: 270px
slots:
default:
- component: f7-row
class: = (items[props.prefix+"_Active_Device_Name"].state !== "NULL")?"display-none":"display-flex justify-content-center"
slots:
default:
- component: Label
text: This Spotify Bridge is Unavailable
- component: f7-row
class: = (items[props.prefix+"_Active_Device_Name"].state === "NULL")?"display-none":"display-flex justify-content-left"
slots:
default:
- component: Label
text: "KĂĽnstler:"
style:
font-size: 10px
with this config this should apply - doesn’t it?
props.prefix → Spotify_Player_Bridge
Name of my Active Device → _Active_Device_Name or _AlbumName
still I got no results with this
EDIT:
I replaced now every “props.prefix+” with Spotify_Player_Bridge - the information is now showing up
Will try to edit the Items Names in the script to make this work
rlkoshak
(Rich Koshak)
April 2, 2024, 3:42pm
4
This is something that is likely to trip a lot of users of older widgets. At some point (I’m not sure when) the automatic naming of Items in “add equipment to model” et. al. changed from camel case to underscores. I had to update a couple of my widgets for this too.
yaya
(yaya)
April 2, 2024, 4:18pm
5
all right - for all beginners out there (like me) - this works for me, can play/pause/shuffle/next/…
Happy to share the widget:
uid: Spotify
tags: []
props:
parameters:
label: Static Title
required: false
type: TEXT
- context: item
required: false
type: TEXT
parameterGroups: []
timestamp: Apr 2, 2024, 5:59:29 PM
component: f7-card
title: =props.title
style:
min-width: 270px
slots:
default:
- component: f7-row
class: = (items["Spotify_Player_Bridge_Active_Device_Name"].state !== "NULL")?"display-none":"display-flex justify-content-center"
slots:
default:
- component: Label
- component: f7-row
class: = (items["Spotify_Player_Bridge_Active_Device_Name"].state === "NULL")?"display-none":"display-flex justify-content-left"
slots:
default:
- component: Label
# text: "KĂĽnstler:"
style:
font-size: 10px
- component: f7-row
style:
position: relative
top: 0px
class: = (items["Spotify_Player_Bridge_Active_Device_Name"].state === "NULL")?"display-none":"display-flex justify-content-center"
slots:
default:
- component: Label
text: =(items["Spotify_Player_Bridge_Kunstler"].state || "-") +" (" +(items["Spotify_Player_Bridge_Album_Name"].state || "-")+")"
style:
white-space: nowrap
overflow: hidden
font-size: 18px
font-weight: bold
font-style: normal
- component: f7-row
height: 11px
slots:
default:
- component: Label
# text: "Titel:"
style:
font-size: 10px
- component: f7-row
style:
position: relative
top: 0px
slots:
default:
- component: Label
text: =items["Spotify_Player_Bridge_Titel"].state || "-"
style:
white-space: nowrap
overflow: hidden
font-size: 26px
font-weight: bold
- component: f7-row
slots:
default:
- component: Label
# text: "Album:"
style:
font-size: 10px
- component: f7-row
style:
position: relative
top: -10px
slots:
default:
- component: Label
# text: =items["Spotify_Player_Bridge_Album_Name"].state || "-"
style:
white-space: nowrap
overflow: hidden
font-size: normal
font-style: italic
- component: f7-row
class: '=(items["Spotify_Player_Bridge_AlbumImage"].state === "NULL")?"display-none" : "- margin-vertical - justify-content-center"'
slots:
default:
- component: oh-image
item: ="Spotify_Player_Bridge_AlbumImage"
style:
width: 70%
- component: f7-row
style:
position: relative
top: -10px
height: 20px
class:
slots:
default:
- component: f7-card
noShadow: true
class: margin display-flex align-items-center
style:
fontSize: 12px
width: calc(100% - 80px)
slots:
default:
- component: Label
text: = items["Spotify_Player_Bridge_Track_Progress_mss"].state
- component: f7-progressbar
color: teal
style:
height: +2px
item: Spotify_Player_Bridge_Track_Progress_mss
progress: = 100 * items["Spotify_Player_Bridge_Track_Progress_mss"].state / items["Spotify_Player_Bridge_TrackDurationms"].state
- component: Label
text: = items["Spotify_Player_Bridge_Track_Duration_mss"].state
- component: f7-row
class:
- justify-content-space-around
- display-flex
- align-items-center
- align-content-stretch
- margin-top
style:
position: relative
top: -0px
slots:
default:
- component: f7-icon
f7: '=("Spotify_Player_Bridge_Active_Device_Shuffle") ? "shuffle" : ""'
color: '=(items["Spotify_Player_Bridge_Active_Device_Shuffle"].state === "ON") ? "green" : ""'
style:
position: relative
left: +7%
slots:
default:
- component: oh-button
action: command
actionItem: = "Spotify_Player_Bridge_Active_Device_Shuffle"
actionCommand: '=(items["Spotify_Player_Bridge_Active_Device_Shuffle"].state !== "ON") ? "ON" : "OFF"'
style:
position: absolute
width: 100%
height: 100%
top: 0px
- component: oh-player-item
style:
width: 150px
item: Spotify_Player_Bridge_Fernbedienung
class:
- display-flex
- margin-
f7: '=("Spotify_Player_Bridge_Repeat_Mode") ? (items["Spotify_Player_Bridge_Repeat_Mode"].state === "context") ? "repeat" : (items["Spotify_Player_Bridge_Repeat_Mode"].state === "track") ? "repeat_1" : "repeat" : ""'
color: '=(items["Spotify_Player_Bridge_Repeat_Mode"].state === "context") ? "green" : (items["Spotify_Player_Bridge_Repeat_Mode"].state === "track") ? "green" : ""'
style:
position: relative
left: -8%
slots:
default:
action: command
actionItem: = "Spotify_Player_Bridge_Repeat_Mode"
actionCommand: '=(items["Spotify_Player_Bridge_Repeat_Mode"].state === "context") ? "track" : (items["Spotify_Player_Bridge_Repeat_Mode"].state === "track") ? "off": "context"'
style:
position: absolute
width: 100%
height: 100%
top: 0px
- component: f7-row
style:
position: relative
top: 0px
class:
- display-flex
- margin-top
slots:
default:
noShadow: true
style:
height: 20px
fontSize: 20px
slots:
default:
f7: speaker_3
class: margin-horizontal margin
- component: oh-slider
label: true
style:
width: calc(100% - 30px)
min: 0
item: ="Spotify_Player_Bridge_Lautstarke"
- component: f7-row
class: -justify-content-space-around -align-items-center -align-content-stretch
style:
position: relative
top: -20px
slots:
default:
- component: f7-col
noShadow: true
class: resizable
style:
fontSize: 20px
overflow: hidden
slots:
default:
- component: oh-label-card
background: "#3333"
icon: f7:hifispeaker
iconSize: 25
action: options
actionItem: ="Spotify_Player_Bridge_Active_Devices"
item: ="Spotify_Player_Bridge_Active_Devices"
style:
height: 100%
top: -10px
fontSize: medium
- component: f7-col
noShadow: true
class: resizable
medium: 50
style:
fontSize: 25px
overflow: hidden
slots:
default:
background: "#3333"
icon: f7:music_note_list
iconSize: 25
action: options
actionItem: ="Spotify_Player_Bridge_Playlists"
item: ="Spotify_Player_Bridge_Playlists"
style:
height: 100%
fontSize: medium
Result:
Now trying to find a solution to select my sonos devices within the device list (they do not appear for now)
JustinG
(JustinG)
April 2, 2024, 6:20pm
6
I suggest you take a look at this recent thread about widgets and how to use their props
The top of the widget you are looking at (and, in deed, the top of 99.99999% of widgets) contains a list of the widget properties, or props.
uid: SMA_widget
tags: []
props:
parameters:
- context: item
label: Netzeinspeisung
required: true
type: TEXT
- context: item
label: Netzbezug
required: true
type: TEXT
+ many more
These can call be configured to whatever values you like. In the widget editor …
yaya
(yaya)
April 2, 2024, 7:55pm
7
thank you @JustinG - this is more clear now.
one more point I was not really able to solve:
I can not select my sonos devices from the devices:
anyone managed to solve this already?
yaya
(yaya)
April 16, 2024, 5:22pm
8
no idea guys?
nobody is using this?
JustinG
(JustinG)
April 16, 2024, 7:11pm
9
I know nothing about the spotify binding. That button expects your active devices to have a set of options that list these devices. I don’t know if this list is automatically populated by the binding or if you are expected to create it yourself.
If you do not see a list of options when you click on the button then one of two things is wrong:
The button is not configured to use the correct item either due to improper configuration or some modification to the code
That item does not have the correct options list set. This is related to the binding and item configuration not the widget.
yaya
(yaya)
April 16, 2024, 7:16pm
10
the List is automatically generated, I did not add the soundbar.
Burt unhappily my sonos is not showing up here - trying to fix this…
anyone else managed to work with sonos?
brianlay
(Brian G Lay)
April 16, 2024, 11:12pm
11
Spotify binding has a mem leak when I tried it a while back. Took it out and haven’t tried since
