OH4: SVG Animation using shape other than circle
Hi All
I am trying to replicate an animation from an APP inside my openHAB. With help so far I have managed to get the following working:
Inverter Animation
The animation uses the following code:
                            - component: f7-row
                                preserveAspectRatio: xMidYMid slice
                                style:
                                  height: auto
                                tag: svg
                                viewBox: 0 0 80 140
                                xmlns: http://www.w3.org/2000/svg
                              slots:
                                default:
                                  - component: f7-row
                                      d: M0,10 H25 A 10 10 45 0 1 35 20 V32
                                      fill: none
                                      stroke: orange
                                      stroke-width: 2
                                      tag: path
                                      vector-effect: non-scaling-stroke
                                  - component: f7-row
                                      fill: orange
                                      r: 2
                                      style:
                                        stroke-width: 4
                                      tag: circle
                                    slots:
                                      default:
                                        - component: f7-row
                                            calcMode: linear
                                            dur: 3s
                                            keyPoints: 0;1
                                            keyPointsReverse: 1;0
                                            keyTimes: 0;1
                                            repeatCount: indefinite
                                            tag: animateMotion
                                          slots:
                                            default:
                                              - component: f7-row
                                                  tag: mpath
                                                  xlink:href: "#solarInverter"
I would like to try and get the animated circle to have “arrows” in it, so it looks something like:
circle_with_arrows
My Google Skills are not brining anything up - all the examples I can find use the circle.
I woulod appreciate any hints on how to achieve something like this?
Mark
You can animate groups as well as individual elements. To group elements together make the elements children of a g element. Then you also just make the animation tag a child of that same group element.
As a side note you’re on a recent enough version of OH that you don’t need to use the tag trick to get this svg tags to work. You can just use the tag name directly in the component line. For example:
- component: f7-row
    tag: circle
can be made just:
- component: circle
for a much more readable widget.
Sorry Justin, I am not sure I understand what you mean here?
Do you mean?
  - component: g
    slots:
     default:
      - component: circle
          fill: red
          r: 2
          strokeWidth: 10
          vectorEffect: non-scaling-stroke
      - component: arrow
          fill: red
          r: 2
          strokeWidth: 10
        slots:
          default:
            - component: f7-row
                calcMode: linear
                dur: 3s
                keyPoints: 1;0
                keyTimes: 0;1
                tag: animateMotion
              slots:
                default:
                  - component: f7-row
                      tag: mpath
                      xlink:href: "#homeInverter"
I am also not sure what the second component would be to get the >>?
So I tried with:
- component: f7-row
    d: M80,95 H55 A 10 10 45 0 1 45 90 V70
    fill: none
    stroke: orange
    stroke-width: 2
    tag: path
- component: g
  slots:
   default:
    - component: circle
        fill: red
        r: 8
        strokeWidth: 10
    - component: circle
        fill: black
        r: 2
        strokeWidth: 10
      slots:
        default:
          - component: f7-row
              calcMode: linear
              dur: 3s
              keyPoints: 1;0
              keyTimes: 0;1
              tag: animateMotion
            slots:
              default:
                - component: f7-row
                    tag: mpath
Which produces:
So the first circle is displayed at 0,0 but is not animated. The black circle is animated.
So I am not sure how to add the “>>”. I tried using a - component: text but then nothing displays.
So I am clearly still missing something.
EDIT: Managed to get a square inside a circle:
                                  - component: f7-row
                                      fill: none
                                      stroke: orange
                                      stroke-width: 2
                                      tag: path
                                  - component: g
                                    slots:
                                     default:
                                      - component: circle
                                          fill: red
                                          r: 8
                                          strokeWidth: 10
                                        slots:
                                          default:
                                            - component: f7-row
                                                calcMode: linear
                                                dur: 3s
                                                keyPoints: 1;0
                                                keyTimes: 0;1
                                                tag: animateMotion
                                              slots:
                                                default:
                                                  - component: f7-row
                                                      tag: mpath
                                      - component: rect
                                          fill: black
                                          r: 2
                                          strokeWidth: 10
                                          content: >>
                                          height: 3
                                          width: 3
                                        slots:
                                          default:
                                            - component: f7-row
                                                calcMode: linear
                                                dur: 3s
                                                keyPoints: 1;0
                                                keyTimes: 0;1
                                                tag: animateMotion
                                              slots:
                                                default:
                                                  - component: f7-row
                                                      tag: mpath
CircleSquare
Probably not the most elegant or simple…
Still can get TEXT for the “>>”.
EDIT:
So I now got the “>>”, but no idea how to get the arrows to point in the direction of the animation. Pobably above my skill set:
                                  - component: f7-row
                                      fill: none
                                      stroke: orange
                                      stroke-width: 2
                                      tag: path
                                  - component: g
                                    slots:
                                     default:
                                      - component: circle
                                          fill: red
                                          r: 4
                                          strokeWidth: 10
                                        slots:
                                          default:
                                            - component: f7-row
                                                calcMode: linear
                                                dur: 3s
                                                keyPoints: 1;0
                                                keyTimes: 0;1
                                                tag: animateMotion
                                              slots:
                                                default:
                                                  - component: f7-row
                                                      tag: mpath
                                      - component: text
                                          text-anchor: middle
                                          x: 0
                                          y: 1.5
                                          content: ">>"
                                          font-size: 5px
                                        slots:
                                          default:
                                            - component: f7-row
                                                calcMode: linear
                                                dur: 3s
                                                keyPoints: 1;0
                                                keyTimes: 0;1
                                                tag: animateMotion
                                              slots:
                                                default:
                                                  - component: f7-row
                                                      tag: mpath
Circle--
Nice work. To get the arrows to turn the corner, you’ll need a second animation. In this case you’re not trying to move the animation, you’re trying to rotate it so instead of more animateMotion, you’ll need to use animateTransform:
The only extra tricky part here is that you are going to need to tweak the timing on the transform because you only want it to run for the short period where the group is actually going around the corner, so syncing it up to the motion transform will take a little trial and error.
edit:
Also, you don’t need both the animateMotion blocks that you have if instead of applying them to each element you just apply it to the whole group. That’s the point of using the group in the first place. So, instead of:
group
  circle
    animateMotion
  text
    animateMotion
you can just have
group
  circle
  text
  animateMotion
For the animateTransform, you can also apply it to the group (because you won’t really see it when the circle rotates) or apply it directly to the text instead.
Thanks for the pointer. Will have a look ASAP.
Thanks. I did try that. But had my indentations etc all wrong… Your explanation has made it easier, so I now have:
  - component: f7-row
      fill: none
      stroke: orange
      stroke-width: 2
      tag: path
  - component: g
    slots:
      default:
        - component: circle
            fill: red
            r: 4
            strokeWidth: 10
        - component: text
            text-anchor: middle
            x: 0
            y: 1.5
            content: ">>"
            font-size: 5px
        - component: f7-row
            calcMode: linear
            dur: 3s
            keyPoints: 1;0
            keyTimes: 0;1
            tag: animateMotion
          slots:
            default:
              - component: f7-row
                  tag: mpath
Hope your don’t mind me posting code each time - I just think it helps if anyone else stumbles on this thread and needs help. I have made lots of mistakes on the way and it helps to see working examples too :slight_smile:
Many threads would be easier if more people did this.
So I have been dong some reading and it has become apparent that I first need need to rotate the text 90 degrees so the arrows are initially pointing in the correct direction.
So from what I can see I need to use:
style:
  transform: rotate(90deg)
I guess this would need to be applied to the text component:
  - component: text
      text-anchor: middle
      x: 0
      y: 1.5
      content: ">>"
      font-size: 5px
      style:
But I am not getting this to work? Any suggestions please? I have tried with the style and without.
Probably a similar issue to what I had before with the group element.
EDIT: Yip… Indentations again. Edited in code above
Working Mostly
I managed to get the rotation transform most working. It works on teh first run but then gets out of sync.
I think the problem is that I need the rotation transform to begin 2s after the motion starts. Then its runs for 2s and shoudkl then only run when the motions starts at the beginning again (or wait 2s).
But I cannot seem to get this right?
  - component: f7-row
      d: M80,95 H55 A 10 10 45 0 1 45 85 V70
      fill: none
      stroke: orange
      stroke-width: 2
      tag: path
  - component: g
      visible: true
    slots:
      default:
        - component: circle
            fill: red
            r: 4
            strokeWidth: 10
        - component: text
            text-anchor: middle
            x: 0
            y: 2.3
            content: "»"
            font-size: 10px
            style:
        - component: f7-row
            dur: 2s
            begin: turn.begin + 2s
            to: -90 0 0
            tag: animateTransform
            type: rotate
            attributeName: transform
            attributeType: XML
            additive: sum
        - component: f7-row
            calcMode: linear
            dur: 6s
            keyPoints: 1;0
            keyTimes: 0;1
            tag: animateMotion
            additive: sum
          slots:
            default:
              - component: f7-row
                  tag: mpath
One issue I did run into was that I had to swap the order of the rotation and motion to get them to work.
I have tried combinations of begin and end. But end always seems to break the animation.
Also looking for advice on using different directions of animation. Is it best to setup two animations and just use the visible expression to show which one is shown?
This is why I said this timing was going to be the tricky part. There’s almost certainly an elegant way to do this with begin and end events, but I can’t tell you off the top of my head what that might be. I’d probably just do this the brute force way with a 6s rotation animation that has keyTimes which do the actual animation only during the middle 3rd. That just means you need a 6s duration and values and keyTimes:
keyTimes: 0;.33;.66;1
values: 0;0;-90;-90
duration: 6s
I myself would just expressions in the relevant properties but that would work too. Not sure if one is “best” or not.
Works Perfectly. Thanks so much for your patience and ongoing help.
Working
- component: f7-row
    d: M80,115 H55 A 10 10 45 0 1 45 105 V80
    fill: none
    stroke: orange
    stroke-width: 2
    tag: path
- component: g
    visible: true
  slots:
    default:
      - component: circle
          fill: orange
          r: 4
          strokeWidth: 10
      - component: text
          text-anchor: middle
          x: 0
          y: 2.3
          content: »
          font-size: 10px
          style:
      - component: f7-row
          values: 0;0;-90;-90
          dur: 6s
          to: -90 0 0
          type: rotate
          attributeType: XML
          additive: sum
      - component: f7-row
          calcMode: linear
          dur: 6s
          keyPoints: 1;0
          keyTimes: 0;1
          tag: animateMotion
          additive: sum
        slots:
          default:
            - component: f7-row
                tag: mpath
EDIT - Full Code
Test_SunSynk_Summary_Popup_V1a.txt (22.8 KB)
