After updating from OH 3.x to OH 4.1 the existing things work well, but if I press the “+” button on the things page then my bindings are not shown.
I put the required addon.xml to OH-INF/addon and deleted the binding.xml.
The binding is accepted and works as feature, but not recognized as addon.
Did I miss something or is there a hook for debugging?
Probably this binding was not yet ported to OH4. You need to contact the devoloper of that binding.
Meanwhile you can try to add new things through developer sidebar in MainUI.
Did you also manually build the folder structure for the addons.xml ? NM I looked at your source code it is correctly structured.
Did you confirm the POM file is correct? NM that same with POM it looks ok too.
When you do list from CLI does it show your binding active? NM loaded your binding see it is active.
I also do not see it show up when clcik + to add new.
I kinda recall there was some script that was supposed to address some of this, but I thought it ran during build in eclipse.
However that was a while back like 6 or 7 months maybe even a year ago it was discussed.
You should be able to turn debug logging on for any of what you want in Openhab as well as what ever you put in your binding for debug statements that will tell the story I am sure.
Because based a very very quick peek at your code base nothing screams out as an issue.
If it still does not work, try to start the bundle in the Karaf console and it usually tells what dependencies cannot be resolved.
If you add Karaf feature verification to your build you will see errors at compile time instead of runtime when feature dependencies cannot be resolved.
I thought that as well when I looked at OP’s code but I DL’d his kar and loaded it on a clean build and
what is crazy here is all the bundles started and went active.
272 │ Active │ 80 │ 3.0.0 │ JNHW :: Common
273 │ Active │ 80 │ 3.0.0 │ JNHW :: Native Lib Loader
274 │ Active │ 80 │ 3.0.0 │ JNHW :: Posix
275 │ Active │ 80 │ 3.0.0 │ JNHW :: Win API
276 │ Active │ 80 │ 3.2.0.202312271328 │ SPSW :: API
277 │ Active │ 80 │ 3.2.0.202312271328 │ SPSW :: JNHW Provider
278 │ Active │ 80 │ 2.1.1.202312271330 │ FHZ4J :: Adapter CUL
279 │ Active │ 80 │ 4.1.0.3-202312271335 │ OH IbAPl :: FHZ4J Binding
280 │ Active │ 80 │ 1.1.1.202312271333 │ OneWire4J :: API/SPI
281 │ Active │ 80 │ 4.1.0.3-202312271335 │ OH IbAPl :: OneWire4J Binding
And stopped and restarted all of them even a pure debug of all did not show any errors.
OK, I created a binding in the openhab-addons from github - tested it - OK.
Then I replaced the OH-INF with the one from the fhz4j binding (…some cleanup has to be done).
With this jar the things of fhz4j could be created - without the backing code obviously.
So I copied the content of OH-INF back deleted the jar in the OH-instance and tried out the kar - with no success.
In the debug logs I could not find any hint if the content of OH-INF was recognized or thrown out due to errors - just no info at all.
Sorry to revive this topic after 8 months os silence. I’m a developer as well and some users of my binding confirmed the same behavior: after upgrade to 4.2.X version, the binding is working as a feature (loaded by the karaf) but is not recognized by the UI, so you can’t add new Things based on it.
I found a solution that is to include the addon.xml content (from my binding) in the openhab-sys/runtime/etc/addons.xml in the OH installation and restart OH.
The question is: this file didn’t exist before 4.2 and to install an alien binding (not related to the distribution) you only needed to put it inside addons folder, but now, this is not enough. Is it a bug ? Is this a new procedure to install alien binding beginning at 4.2 ? Should this file (addons.xml) be auto managed by OH to include new entries as soon as new bindings are added ?
@aploese … do you had some solution for this case since your last post ?
OS seems to only pickup binding feature prefixed with “openhab-binding-”.
So rename your feature in feature.xml to .
Then OH loads the feature. I don’t know if this the intended way of adding 3rd party bindings - but at least it works for now. @wborn can you confirm this or is there an working example for bindings (with arbitary feature name) in a *.kar file?
If the binding is not in the marketplace I must use the " openhab-binding-",
otherwise the binding will be ignored by openhab(tested on 4.1.?), even with an addon.xml.
If it helps I can verify this with an actual openhab (4.2.?).
Maybe this is an bug - I don’t know.
I think your observation is valid, I saw similar issue. While things can be created via files UI and rest api does not list third party addons if they do not align to naming convention
