OH5.0.0 SNAPSHOT Log Viewer not working (Nothing in Test Web Socket Connection)
Hi All
I am running openHAB 5.0.0 Build #4546 with following:
Java Runtime Eclipse Adoptium 21.0.6 (Temurin-21.0.6+7)
Operating system Windows 10/10.0 (amd64)
and have realized that the Log Viewer is no longer working.
I checked the Test Web Socket Connection tool and it does not show any activity.
There is definitely log activity as I can see that from log:tail in Karaf Console
Any Suggestion please?
Mark
EDIT: It seems I am getting nothing back from the server side? And nothing in the logs?
I have updated to the latest snapshot ( openHAB 5.0.0 Build #4565) and still the same.
Is anyone else seeing anything similar and suggestions on what to look at?
I think I have the same problem. Regardless of browser or smartphone OS, the logviewer cannot be started by clicking on the play button.
But I know that it used to work. Like you, I’m also having a look at Karaf via log:tail as an alternative.
I tried a clean/fresh install with no real THINGS etc, and the LogViewer works like that.
I have tried <Logger level="TRACE" name="org.openhab.core.io.websocket "/> to try and get some logging, but nothng shows up, even when using the debug Tool for Web Socket.
I have made some progress.
If I access OH using HTTPS I get (nothing):
If I access using HTTP I get (success):
This explains why my clean (default) install worked (I was using HTTP).
So from what I can see issue is related to using LogViewer over HTTPS?
https://github.com/openhab/openhab-webui/issues/3125
Great idea to try it via http! This is a good temporary solution
Hi, i recently updated to OH 5.0.0 Build #4609 and the clipboard action is not working. Can someone please test this?
https://github.com/openhab/openhab-webui/issues/3017
I see there is a PR awaiting merge
The fix is only for OH4. In the last Milestone Build (V5.0.0 M3) the problem is still there.
