dear all
In the latest OH5, latest snapshot, I had this widget
uid: Keypad_TEST
tags: []
props:
parameters:
- context: item
description: Item Disinserimento
label: Item Disinserimento
required: false
type: TEXT
- context: item
description: Item Totale
label: Item Totale
required: false
type: TEXT
- context: item
description: Item Volumetrico
label: Item Volumetrico
required: false
type: TEXT
- context: item
description: Item Perimetrale
label: Item Perimetrale
required: false
type: TEXT
- description: Replace pincode characters with this string, leave blank to show it as-is
label: Mask character
required: false
type: TEXT
- description: If this widget is shown in a popup, close it after pressing Send
label: Close Popup on Send
required: false
type: BOOLEAN
parameterGroups: []
timestamp: Feb 21, 2025, 1:54:16 PM
component: f7-block
class:
- padding
label: Please Input Pin
style:
--f7-button-bg-color: var(--f7-card-bg-color)
--f7-button-text-color: var(--f7-text-color)
--f7-theme-color-rgb: var(--f7-color-blue-rgb)
slots:
default:
- component: oh-label-card
class:
- margin-bottom
label: "=(props.mask && vars.pincode) ? props.mask.repeat(vars.pincode.length ||
0) : vars.pincode"
outline: true
- component: f7-row
class:
- margin
slots:
default:
- component: oh-repeater
for: digit
fragment: true
in:
- "1"
- "2"
- "3"
- "4"
- "5"
- "6"
- "7"
- "8"
- "9"
- "0"
slots:
default:
- component: f7-col
class:
- margin-vertical-half
width: "33"
slots:
default:
- component: oh-button
action: variable
actionVariable: pincode
actionVariableValue: "=(vars.pincode) ? vars.pincode + loop.digit : loop.digit"
large: true
raised: true
text: =loop.digit
- component: f7-row
class:
- margin
style:
--f7-button-bg-color: transparent
--f7-theme-color: var(--f7-color-blue)
slots:
default:
- component: f7-col
slots:
default:
action: variable
actionVariableValue: ""
large: true
text: Clear
- component: f7-col
slots:
default:
action: variable
actionVariableValue: '=(vars.pincode) ? vars.pincode.substring(0,
vars.pincode.length - 1) : ""'
large: true
text: Back
- component: f7-row
class:
- margin
style:
slots:
default:
- component: f7-col
slots:
default:
action: command
actionCommand: =vars.pincode
actionItem: =(props.itemTotale) || 'TestString'
class: "=(props.closePopup) ? ['popup-close'] : []"
clearVariable: pincode
closePopup: =props.closePopup
disabled: =!vars.pincode
fill: true
large: true
style:
--f7-button-hover-bg-color: var(--f7-color-blue-tint)
--f7-button-pressed-bg-color: var(--f7-color-blue-tint)
text: Totale
- component: f7-col
slots:
default:
action: command
actionItem: =(props.itemVolumetrico) || 'TestString'
fill: true
large: true
style:
text: Volumetrico
- component: f7-col
slots:
default:
action: command
actionItem: =(props.itemPerimetrale) || 'TestString'
fill: true
large: true
style:
text: Perimetrale
- component: f7-row
class:
- margin
style:
slots:
default:
- component: f7-col
slots:
default:
action: command
actionItem: =(props.itemDisinserimento) || 'TestString'
fill: true
large: true
style:
text: Disinserimento
but the result is a blank square and not the keys
In the last stable version it works perfectly.
How can I solve it?
thanks in advance.
