OHv2: Machine running OHv2 hangs w/o warning after 4 to 6 weeks
Have a look at this command in the karaf console, it will give some memory and garbage collection info which over time may show a trend…
shell:info
It may be a binding causing it so first step would be to remove half the bindings and test, then if it still happens remove the other half until you narrow down the cause.
Perhaps read this post, it may be the same..
