Hi guys!
I have a small problem connecting OH2 and OLA. I followed the steps in the documentation for items and settings. I leave the scrips below:
ITEMS
Color RGB_LV “RGB Salón” {dmx=“CHANNEL[2,3,4:1000]”}
Color RGB_LVR “Rojo Salón” {dmx=“CHANNEL[2]”}
SITEMAP
Colorpicker item=RGB_LV label=“RGB Salón”
Slider item=RGB_LVR label=“Rojo Salón”
CONF
connection=192.168.1.137:9010
repeatMode=reduced
OLA-ARNET.CONF
always_broadcast = true
enabled = true
ip = 192.168.1.137
long_name = OLA - ArtNet node
net = 0
output_ports = 4
short_name = OLA - ArtNet node
subnet = 0
use_limited_broadcast = false
use_loopback = false
Also, in the log file I get this error:
2017-08-21 15:59:50.316 [ERROR] [ola.rpc.StreamRpcChannel ] - Error connecting to 192.168.1.137:9010. Make sure the olad daemon is running.
2017-08-21 15:59:50.317 [ERROR] [ding.dmx.internal.core.DmxController] - Error opening DMX connection.
java.lang.Exception: Error connecting to 192.168.1.137:9010. Make sure the olad daemon is running.
at ola.rpc.StreamRpcChannel.connect(StreamRpcChannel.java:76)[195:org.openhab.binding.dmx:1.10.0]
at ola.OlaClient.connect(OlaClient.java:72)[195:org.openhab.binding.dmx:1.10.0]
at org.openhab.binding.dmx.ola.OlaConnection.open(OlaConnection.java:53)[195:org.openhab.binding.dmx:1.10.0]
at org.openhab.binding.dmx.internal.core.DmxController.getConnection(DmxController.java:259)[195:org.openhab.binding.dmx:1.10.0]
at org.openhab.binding.dmx.internal.core.DmxTransmitter.run(DmxTransmitter.java:97)[195:org.openhab.binding.dmx:1.10.0]
at java.util.TimerThread.mainLoop(Timer.java:555)[:1.8.0_121]
at java.util.TimerThread.run(Timer.java:505)[:1.8.0_121]
Caused by: java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)[:1.8.0_121]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)[:1.8.0_121]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)[:1.8.0_121]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)[:1.8.0_121]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)[:1.8.0_121]
at java.net.Socket.connect(Socket.java:589)[:1.8.0_121]
at java.net.Socket.connect(Socket.java:538)[:1.8.0_121]
at java.net.Socket.(Socket.java:434)[:1.8.0_121]
at java.net.Socket.(Socket.java:211)[:1.8.0_121]
at ola.rpc.StreamRpcChannel.connect(StreamRpcChannel.java:70)[195:org.openhab.binding.dmx:1.10.0]
… 6 more
I have enabled an artnet input port at ip = 192.168.1.137 in OLA.
I’m using an Anyma USB Device. Works properly from the DMX console in OLA.
I’m using RPI 3 with Openhabian.
Where could the problem be ![]()
Thank you very much for the help!
