No, there is no wildcard for rule trigger, try out the group approach. You have to use Item MyGroup received update as trigger if the items are diverging, the downside is, the rule will be triggered two times for one update, maybe you have to care about this - depends on what the rule should do.
Thanks Udo - is there a way to have the rule trigger for all items, but then inspect the name conditionally? That might be a lot of processing overhead, however. I’m still sorting out the rule language options…
There is a hack you can use if you have persistence set up.
put all your sign items into a group
make sure all the items in the group are persisted at least every change, probably want every update
trigger your rule on the group as @Udo_Hartmann recommends (be aware the rule will trigger more than once per item event)
rule "Signage rule"
Item gSignage received update
Thread::sleep(100) // give persistence time to catch up
val triggeringItem = gSignage.members.sortBy[lastUpdate].last
