Hi all,
is it possible to get the refresh interval of an onewire item under 1s?
I am using OH1.
In older versions of the binding it was possible to define the refreh interval in the openhab.cfg file in milliseconds. With version 1.8.0 I can set the interval in the item configuration in seconds and it seems to dont accept numbers smaller than 1.
Reason for my request:
I would like to bind all pushbutton light switches in my house via onewire to OH.
I have my reed contacts attached via onewire. Based on this, I among other things switch lights on and off for the front door. The case obviously benefits from rather short response times…
Previously it worked like this:
owserver → wiregate → KNX → OH → KNX → light. Took about ~2 seconds.
Now I hooked 1W directly to OH via the onewire binding:
owserver → OH → KNX → light. Takes about 10 seconds.
I actually was hoping to improve on response times
Any idea how I can force a much higher refresh rate?
It does not seem to be the refresh config, as I already set this to 1. And according to the code of OwBaseThingHandler. If it’s refresh method is called more often, it would just do it…
Any ideas what I could try? Where to look at?
And out of curiousity - who / what calls the OwBaseThingHandler’s refresh method?
Ok… I had the idea to look a bit into the wiregate implementation. It reads from uncached… and cache time out is 15 per default… I might be able to overcome by using a owfs-number access, I guess, but that would leave me with everything else as I only get the raw number. This I created a feature request:
A sub 1s update I guess would not be possible due to the scheduled task in OwserverBridgeHandler:
