mountbaldy
(Joseph Gill)
February 20, 2019, 6:44pm
#1
Platform information:
Hardware: RPI Zero W
OS: Raspian
Java Runtime Environment: which java platform is used and what version
openHAB version: 2.4.0
Issue of the topic: I can’t seem to get my OneWire temperature sensors to work properly. They will show up fine in the PaperUI, but when I configure a sitemap, item file and thing file for them, they fail to load the temperature data.
Items configuration related to the issue
Number:Temperature MySensor "MySensor [%.1f °C]" { channel="onewire:basic:mybridge:mysensor:temperature" }
Sitemap configuration related to the issue
sitemap home label="Gill's Guide Control Center"
Frame label="Solar Panel UI"
Switch item=channel1
Text item=MySensor
*Things File:
Bridge onewire:owserver:1074ec7a [
network-address="127.0.0.1"
Thing basic mysensor [
id="28.C14777910F02",
refresh=60
Channels:
Type temperature : temperature [
resolution="11"
Any help or guidence here is appreciated. I scoured the forum and could not find anything applicable to this. I followed this example. https://www.openhab.org/addons/bindings/onewire/
Cheers,
Joe
J-N-K
(Jan N. Klug)
February 20, 2019, 7:11pm
#2
What bundle-version are you using (please use bundle:list). The release version has a known issue that has been fixed.
mountbaldy
(Joseph Gill)
February 20, 2019, 9:58pm
#3
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.4.0
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> bundle:list
START LEVEL 100 , List Threshold: 50
ID │ State │ Lvl │ Version │ Name
20 │ Active │ 80 │ 5.3.1.201602281253 │ OSGi JAX-RS Connector
21 │ Active │ 80 │ 2.7.0.v20170129-0911 │ Gson: Google Json Library for Java
22 │ Active │ 80 │ 18.0.0 │ Guava: Google Core Libraries for Java
23 │ Active │ 80 │ 3.0.0.v201312141243 │ Google Guice (No AOP)
24 │ Active │ 80 │ 3.18.1.GA │ Javassist
26 │ Active │ 80 │ 3.5.5 │ JmDNS
28 │ Active │ 80 │ 1.0.0 │ Units of Measurement API
30 │ Active │ 80 │ 1.1.0.Final │ Bean Validation API
31 │ Active │ 80 │ 2.0.1 │ javax.ws.rs-api
32 │ Active │ 80 │ 3.2.0.v201101311130 │ ANTLR Runtime
35 │ Active │ 80 │ 3.2.1 │ Commons Collections
36 │ Active │ 80 │ 1.1 │ Commons Exec
37 │ Active │ 80 │ 2.2.0 │ Commons IO
38 │ Active │ 80 │ 2.6 │ Commons Lang
47 │ Active │ 80 │ 4.2.1 │ Apache Karaf :: OSGi Services :: Event
63 │ Active │ 80 │ 4.6.0 │ Apache XBean OSGI Bundle Utilities
64 │ Active │ 80 │ 4.6.0 │ Apache XBean :: Classpath Resource Finder
65 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF Common
66 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF Ecore
67 │ Active │ 80 │ 2.11.0.v20160420-0247 │ EMF Change Model
68 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF XML/XMI Persistence
69 │ Active │ 80 │ 3.8.0.v20160509-1230 │ Common Eclipse Runtime
70 │ Active │ 80 │ 3.6.100.v20160223-2218 │ Extension Registry Support
80 │ Active │ 80 │ 9.4.11.v20180605 │ Jetty :: Proxy
94 │ Active │ 80 │ 0.4.1.v20180515-1321 │ org.eclipse.lsp4j
95 │ Active │ 80 │ 0.4.1.v20180515-1321 │ org.eclipse.lsp4j.jsonrpc
96 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome OAuth2Client
97 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Config Core
98 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration Discovery
99 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration mDNS Discovery
100 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Config Dispatcher
101 │ Active │ 75 │ 0.10.0.oh240 │ Eclipse SmartHome Config XML
102 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core
103 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Audio
104 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Binding XML
105 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core ID
106 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Persistence
107 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Scheduler Service
108 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Semantics
109 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Thing
110 │ Active │ 75 │ 0.10.0.oh240 │ Eclipse SmartHome Core Thing XML
111 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Transformation Service
112 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core Voice
113 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Console
114 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Console for OSGi runtime Karaf
115 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome HTTP Interface Bundle
116 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome JavaSound I/O, Fragments: 183
117 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Monitor
118 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Net I/O Bundle
119 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome REST Interface Bundle
120 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Core REST API
121 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome REST mDNS Announcer
122 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome REST Interface JAX-RS optimization Bundle
123 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap REST API
124 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome SSE REST API
125 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Voice REST API
126 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Bonjour/MDS Service Discovery Bundle
127 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Web Audio Support
128 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Model Core
129 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Item Model
130 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Item Model IDE
131 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Item Model Runtime
132 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Language Server
133 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Persistence Model
134 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Persistence Model IDE
135 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Persistence Runtime
136 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Rule Model
137 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Rule Model IDE
138 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Rule Runtime
139 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Script
140 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Script Model IDE
141 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Script Runtime
142 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap Model
143 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap Model IDE
144 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Sitemap Runtime
145 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Thing Model
146 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Thing Model IDE
147 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Thing Model Runtime
148 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Json Storage Service
149 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome UI
150 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome UI Icons
151 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Classic IconSet
152 │ Active │ 80 │ 2.14.0.v20180522-1629 │ Xtend Runtime Library
153 │ Active │ 80 │ 2.14.0.v20180522-1629 │ Xtend Macro Interfaces
154 │ Active │ 80 │ 2.14.0.v20180522-1821 │ Xtext
155 │ Active │ 80 │ 2.14.0.v20180522-1833 │ Xtext Common Types
156 │ Active │ 80 │ 2.14.0.v20180522-1821 │ Xtext IDE Core
157 │ Active │ 80 │ 2.14.0.v20180522-1821 │ Xtext Utility
158 │ Active │ 80 │ 2.14.0.v20180522-1833 │ Xbase Model
159 │ Active │ 80 │ 2.14.0.v20180522-1833 │ Xbase Generic IDE Services
160 │ Active │ 80 │ 2.14.0.v20180522-1629 │ Xbase Runtime Library
175 │ Active │ 80 │ 1.9.6 │ MIME streaming extension
177 │ Active │ 80 │ 6.2.0 │ org.objectweb.asm
178 │ Active │ 80 │ 6.2.0 │ org.objectweb.asm.commons
179 │ Active │ 80 │ 6.2.0 │ org.objectweb.asm.tree
180 │ Active │ 90 │ 2.4.0 │ openHAB Core
181 │ Active │ 80 │ 2.4.0 │ openHAB Karaf Integration
183 │ Resolved │ 80 │ 2.4.0 │ openHAB Sound Support, Hosts: 116
184 │ Active │ 80 │ 2.4.0 │ openHAB Dashboard UI
189 │ Active │ 80 │ 1.0.2 │ Units of Measurement Common Library
190 │ Active │ 80 │ 1.0.8 │ Units of Measurement Implementation for Java SE
191 │ Active │ 80 │ 3.14.0 │ nrjavaserial
192 │ Active │ 80 │ 3.15.0.OH2 │ nrjavaserial
193 │ Active │ 80 │ 1.6.0 │ Commons Codec
194 │ Active │ 80 │ 3.3.0 │ Commons Net
195 │ Active │ 80 │ 4.2.3 │ Apache HttpClient OSGi bundle
196 │ Active │ 80 │ 4.2.3 │ Apache HttpCore OSGi bundle
197 │ Active │ 80 │ 3.1.0.7 │ Apache ServiceMix :: Bundles :: commons-httpclient
198 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome OneWire Binding
199 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration USB-Serial Discovery
200 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Configuration USB-Serial Discovery Linux sysf Scanning
201 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Config Serial
202 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Serial Transport
203 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Serial Transport for RXTX
204 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Serial Transport extension for RXTX RFC2217
205 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Basic UI, Fragments: 211
206 │ Active │ 80 │ 0.10.0.oh240 │ Eclipse SmartHome Paper UI, Fragments: 214
207 │ Active │ 80 │ 1.13.0 │ openHAB GPIO Binding
208 │ Active │ 80 │ 2.4.0 │ Lutron Binding
209 │ Active │ 80 │ 2.4.0 │ openHAB 1.x Compatibility Layer
210 │ Active │ 80 │ 1.13.0 │ openHAB GPIO IO Module
211 │ Resolved │ 75 │ 2.4.0 │ openHAB Basic UI Fragment, Hosts: 205
212 │ Active │ 80 │ 2.4.0 │ HABPanel User Interface
213 │ Active │ 80 │ 2.4.0 │ HomeBuilder User Interface
214 │ Resolved │ 75 │ 2.4.0 │ openHAB Paper UI Theme Fragment, Hosts: 206
mountbaldy
(Joseph Gill)
February 21, 2019, 12:02am
#4
I updated to the latest test version of OpenHab… I still have the same issue.
__ _____ ____
/_/ 2.5.0.M1
Milestone Build
47 │ Active │ 80 │ 4.2.2 │ Apache Karaf :: OSGi Services :: Event
80 │ Active │ 80 │ 9.4.12.v20180830 │ Jetty :: Proxy
96 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome OAuth2Client
97 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Config Core
98 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Configuration Discovery
99 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Configuration mDNS Discovery
100 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Config Dispatcher
101 │ Active │ 75 │ 0.11.0.oh250M1 │ Eclipse SmartHome Config XML
102 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core
103 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core Audio
104 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core Binding XML
105 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core ID
106 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core Persistence
107 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Scheduler Service
108 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core Semantics
109 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core Thing
110 │ Active │ 75 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core Thing XML
111 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Transformation Service
112 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core Voice
113 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Console
114 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Console for OSGi runtime Karaf
115 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome HTTP Interface Bundle
116 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome JavaSound I/O, Fragments: 183
117 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Monitor
118 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Net I/O Bundle
119 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome REST Interface Bundle
120 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Core REST API
121 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome REST mDNS Announcer
122 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome REST Interface JAX-RS optimization Bundle
123 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Sitemap REST API
124 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome SSE REST API
125 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Voice REST API
126 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Bonjour/MDS Service Discovery Bundle
127 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Web Audio Support
128 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Model Core
129 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Item Model
130 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Item Model IDE
131 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Item Model Runtime
132 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Language Server
133 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Persistence Model
134 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Persistence Model IDE
135 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Persistence Runtime
136 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Rule Model
137 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Rule Model IDE
138 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Rule Runtime
139 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Script
140 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Script Model IDE
141 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Script Runtime
142 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Sitemap Model
143 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Sitemap Model IDE
144 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Sitemap Runtime
145 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Thing Model
146 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Thing Model IDE
147 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Thing Model Runtime
148 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Json Storage Service
149 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome UI
150 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome UI Icons
151 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Classic IconSet
180 │ Active │ 90 │ 2.5.0.M1 │ openHAB Core
181 │ Active │ 80 │ 2.5.0.M1 │ openHAB Karaf Integration
183 │ Resolved │ 80 │ 2.5.0.M1 │ openHAB Sound Support, Hosts: 116
184 │ Active │ 80 │ 2.5.0.M1 │ openHAB Dashboard UI
198 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Configuration USB-Serial Discovery
199 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Configuration USB-Serial Discovery Linux sysf Scanning
200 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Config Serial
201 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Serial Transport
202 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Serial Transport for RXTX
203 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Serial Transport extension for RXTX RFC2217
204 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Basic UI, Fragments: 210
205 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome Paper UI, Fragments: 213
206 │ Active │ 80 │ 1.14.0.M1 │ openHAB GPIO Binding
207 │ Active │ 80 │ 2.5.0.M1 │ Lutron Binding
208 │ Active │ 80 │ 2.5.0.M1 │ openHAB 1.x Compatibility Layer
209 │ Active │ 80 │ 1.14.0.M1 │ openHAB GPIO IO Module
210 │ Resolved │ 75 │ 2.5.0.M1 │ openHAB Basic UI Fragment, Hosts: 204
211 │ Active │ 80 │ 2.5.0.M1 │ HABPanel User Interface
212 │ Active │ 80 │ 2.5.0.M1 │ HomeBuilder User Interface
213 │ Resolved │ 75 │ 2.5.0.M1 │ openHAB Paper UI Theme Fragment, Hosts: 205
214 │ Active │ 80 │ 0.11.0.oh250M1 │ Eclipse SmartHome OneWire Binding
J-N-K
(Jan N. Klug)
February 21, 2019, 12:45am
#5
In your things-file the bridge is named
1074ec7a, in your items-file you reference a Bridge named mybridge.
mountbaldy
(Joseph Gill)
February 21, 2019, 12:57am
#6
OK. So changing those to match should fix it?
mountbaldy
(Joseph Gill)
February 21, 2019, 1:28am
#7
I updated the Bridge name in the item file to reflect that named in the things file. Still no go. I have cleared the cache and restarted openhab…
Any ideas would be helpful.
Thanks!
J-N-K
(Jan N. Klug)
February 21, 2019, 6:51am
#8
Please „log:set DEBUG org.openhab.binding.onewire“ and post the log. Thanks.
mountbaldy
(Joseph Gill)
February 21, 2019, 3:41pm
#9
Well, I have decided to re-image my SD card with openhabian. I will post back when I get things situated.
Thanks!
mountbaldy
(Joseph Gill)
February 28, 2019, 8:53pm
#10
I tried re-imaging my SD card. This time I put Openhabian on it with the latest Milestone install. I can’t seem to get the latest version of the OneWire binding to work at all. I have struggled now for a week trying things. Any help here would be helpful!
I posted logs here.
Hardware: Rasperry Pi Zero W
OS: OpenHabian [master]v1.4.1-453(1380125)
openHAB version: openHAB 2.5.0.M1 Milestone Build
Issue of the topic:
I installed openHABian to try and resolve some issues communicating with my Onewire bus and now I am having issues seeing anything mounted to /mnt/1wire. I followed https://www.abelectronics.co.uk/kb/article/3/owfs-with-i2c-support-on-raspberry-pi for instruction on how to set up the onewire devices. I also ran 1wire config in …
Thanks!
mountbaldy
(Joseph Gill)
March 4, 2019, 4:51am
#11
I wanted to post a resolution to this…
I ended up re-installing Raspian and re-installing the Onewire protocol entirely. I followed this post again very closely… https://www.abelectronics.co.uk/kb/article/9/1-wire-with-ds18s20-digital-thermometer
After I did that, I installed OpenHab2.5.? unstable. I re-installed the Onewire binding.
I still had the same issue. I would get intermittent readings from my sensors. I isolated the issue by eliminating a length of CAT 6 cable and hooking them directly to my OneWire device. That resolved my issue. I had a problem with my cable some place.
If you have intermitant problems, check your cable first. Replace it or shorten it. Once you get Openhab going, lengthen your cable. Lesson learned!
