The onewire bus with my temperature sensors works. I am litte bit stuck with getting my DS2438 working, as I do not understand the documentation. They used to work on my old OH1 instance.
I am at this point:
.things:
Thanks for the help. It is no option for me to use a visual editor. Config files are linux standard.
I succeeded in getting the sensors working with the above definition. I did not change anything. My guess is, that it is because only some sensors appear in /mnt/1-wire and disappear again and some others appear again. If you have an idea why this happens, it would be great.
Number OneWireGaesteBadLuftfeuchteRaw "Luftfeuchte Gästebad Raw [%.1f %%]" (GroupGaesteBad) {channel="onewire:ms-tx:mybridge:OneWireGaesteBadLuftfeuchteRaw:absolutehumidity"}
2020-01-07 17:32:23.243 [vent.ItemStateChangedEvent] - OneWireGaesteBadLuftfeuchte changed from -18.1875 to -18.4375
I tried “humidity” as well, but I do not get values at around 40%. Any ideas?
