I am running Openhab2 on a RPI with OWFS installed as well. I have attached a 1wire temperature sensor via a USB 1wire adapter to the RPI. The temperature can be read by access the sensor on mnt/1wire/. I have attached the Onewire binding but I do not get the temperature sensor in the openhab2 inbox. In the binding configuration I have tried to use different options for the OWserver IP adress (localhost/127.0.0.1/actual IP) but I never get the sensor in the inbox. I have tried to use the 4304 port and to omit the port number as well. How do I get openhab2 to access the 1wire temperature sensor?
The onewire binding is an openhab 1.x binding and doesnât support the inbox or auto-discovery. Youâll have to manually add it to your items file. For example:
Number Temp_BR_Nightstand "Nightstand Temp [%.1f °F]" <temperature> (Temp_Bedroom) { onewire="deviceId=28.A8DFBD030000;propertyName=temperature;refreshinterval=600" }
Number Temp_BR_Window "BR Window Temp [%.1f °F]" <temperature> (Temp_Bedroom) { onewire="deviceId=28.23756B020000;propertyName=temperature;refreshinterval=600" }
Number Lux_LR_Server_Raw "Light RAW [%.2f V]" { onewire="deviceId=26.1C84E1010000;propertyName=VAD;refreshinterval=300" }
If the binding is throwing errors about the hostname being null, you might need to grab the latest snapshot from cloudbees. https://openhab.ci.cloudbees.com/job/openHAB1-Addons/lastSuccessfulBuild/artifact/bundles/binding/org.openhab.binding.onewire/target/org.openhab.binding.onewire-1.10.0-SNAPSHOT.jar
I have created an âonewire.itemsâ file in etc/openhab2/items/ with the tempsensor as in your example. I can not find the item in the PAPER UI. Where should the onewire sensor appear? Have I located the item file in the wrong loacation? How is the link established to the sensors at mnt/1wire/? Sorry for all the questions but I have just started to use Openhab and Linux.
OH talks to owserver, not OneWire filesystem.
- install owserver (you should have it already)
- install onewire1 binding
- edit services/onewire.cfg and put the address of the host running owserver like
ip=127.0.0.1
- configure your item(s) as shown earlier
check the log (I have owserver running on another host):
[INFO ] [nternal.connection.OneWireConnection] - Connected to owserver [IP ârpi.lanâ Port â4304â]
I have now installed the owserver (it was never installed, just owfs). I can now see that the temperature is updated in the events.log. But how do I access the sensor in Openhab2? I can not find it in the Paper UI. Do I have to add it manually some how?
yes, as it was suggested earlier:
Thank you Andrew!
I did not realise that I need to use the BasicUI to access the onewire devices. When I manually created a sitemap for the Basic UI (not Paper UI) the onewire devices appeared.
Where do i have to create those files ?
My directory is openhabian@openHABianPi:~$.
In the Manual is written : Through text .items files located in the $OPENHAB_CONF/items folder.
This folder doesânt exist.
What is wrong ?
