I now found some time to try again:
[19:31:11] openhabian@openhab:~$ ls /mnt/1wire/
bus.0 bus.1 settings statistics structure system uncached
[19:31:30] openhabian@openhab:~$ ls /mnt/1wire/
20.0FE101000000 26.743F1B010000 28.FF4F5DA21503 28.FF8F6BA21503 28.FFDA55001602 settings
26.49D984000003 26.B8A915020000 28.FF7259A21503 28.FF916DA21503 28.FFDF6CA21503 simultaneous
26.54D984000003 28.4AD984000003 28.FF7362001601 28.FF9624A21503 81.275535000000 statistics
26.55D984000003 28.FF0D64001601 28.FF81A5921501 28.FF9972021603 alarm structure
26.655A38020000 28.FF465CA21503 28.FF8957A21503 28.FFA67D021603 bus.0 system
26.6F5A38020000 28.FF4A76001602 28.FF8F5BA21503 28.FFD56CA21503 bus.1 uncached
services/onewire.cfg:
ip=127.0.0.1
services/addons.cfg:
binding =knx,network,homekit,denonmarantz,onewire
things/onewire.things:
Bridge onewire:owserver:mybridge [network-address=âlocalhostâ, port=4304 ] {
Thing basic OneWireKuehlschrank [
id=â28.FFDA55001602â,
refresh=60
Channels:
Type temperature-por-res : temperature [
resolution=â11â
http://192.168.178.47:9001:
2019-12-27 19:38:49.871 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model âonewire.thingsâ
2019-12-27 19:38:49.899 [hingStatusInfoChangedEvent] - âonewire:owserver:bridgeâ changed from UNINITIALIZED to INITIALIZING
2019-12-27 19:38:49.903 [hingStatusInfoChangedEvent] - âonewire:owserver:bridgeâ changed from INITIALIZING to UNKNOWN
2019-12-27 19:38:49.909 [hingStatusInfoChangedEvent] - âonewire:owserver:bridgeâ changed from UNKNOWN to ONLINE
2019-12-27 19:38:50.987 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model âonewire.thingsâ
/items/onewire.items:
Number:Temperature OneWireKuehlschrank "KĂŒhlschrank [%.1f °C]" <smoke> (GroupKueche, Kuehli,GroupTemperaturAlle) {channel="onewire:basic:owserver:mybridge:OneWireKuehlschrank:temperature"}
2019-12-27 19:40:47.559 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model âonewire.itemsâ
2019-12-27 19:40:47.587 [.ItemChannelLinkAddedEvent] - Link âOneWireKuehlschrank-onewire:basic:owserver:mybridge:OneWireKuehlschrank:temperatureâ has been added.
2019-12-27 19:40:48.613 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model âonewire.itemsâ
in the sitemap I have:
Text item=OneWireKuehlschrank
I do not use paperUi, but there it says that the onewire bindung is installed.
Under configuration->Things it says âOW Serverâ online. But if I click on it, there are no Channels listed. At the KNX Thing, there are all my thingsâŠ
If I click on inbox -> â+â -> Onewire Binding, nothing happens, it searches forever.
If I add it manually, it appears at Configuration->Things and Stays at âinitializingâ. If I add it to the items/onewire.items:
Number:Temperature OneWireKuehlschrank "KĂŒhlschrank [%.1f °C]" <smoke> (GroupKueche, Kuehli,GroupTemperaturAlle) {channel="onewire:temperature:c7135fa0"}
it does not work.
2019-12-27 20:01:28.575 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'channel' of item 'OneWireKuehlschrankPaperUi' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: UID must have at least 4 segments.
Any ideas on debugging?
