I’m having some trouble with the new onewire 2.0 binding. The binding only seems to support specific predefined sensor combinations. (e.g. temperature and humidity or temperature and light) But I also have a onewire sensor that measures temperature, humidity and light. I also have a sensor with only temperature and light and if I configure this sensor as MS-TL I don’t get any values for the light sensor. (In this case the light value is under /S3-R1-A/illuminance**)
In OpenHab 1 I could simply configure the path of every sensor value in the item itself. With OpenHab 2.0 I cannot specify the channels manually to add such custom sensors.
I tried every device type for my sensors, but only the Multisensor type is recognized by the binding. Is there a way to completley define the onewire sensors manually in OpenHab 2.0 or is this planned for a future release?
