I’ve installed openhab 2.3 on docker and rebuilding my configuration.
Therefore i use knx2 and onewire1 bindings.
It seems that the post_only_changed_values is not working coz i get status updates on each onewireread even if the value has not changed.
onewire.cfg
# only changed values are posted to the event-bus, (optional, defaults to true - values true or false)
post_only_changed_values=true
Event-Log
06:13:01.355 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
06:13:02.347 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
06:13:03.355 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
06:13:04.347 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
06:13:05.356 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
06:13:06.349 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
06:13:07.357 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
06:13:08.350 [INFO ] [smarthome.event.ItemStateEvent ] - Window_EG_Buero_Tilt updated to CLOSED
Item-Config
Contact Window_EG_Buero_Tilt "Fenster Büro (gekippt)" (Group_Window_Contact,Fenster_Tilted) { onewire="deviceId=uncached/s_buero;propertyName=sensed.B;refreshinterval=1;invert", channel="knx:device:bridge:onewire:egWindowBueroTilt" }
As u see i need to send those values to my knx bus which is currently flooded by the onewire event.
onewire DEBUG log
2018-09-19 08:25:15.181 [DEBUG] [nal.scheduler.OneWireUpdateScheduler] - Autorefresh: Adding 1 item(s) with refresh time 1 to reader queue.
2018-09-19 08:25:15.182 [DEBUG] [nal.scheduler.OneWireUpdateScheduler] - Update Task isAlive: true
2018-09-19 08:25:15.183 [DEBUG] [nal.scheduler.OneWireUpdateScheduler] - add item Window_EG_Essen_Sued_Open to updateQueue
2018-09-19 08:25:15.184 [DEBUG] [internal.scheduler.OneWireUpdateTask] - Autorefresh: got new item Window_EG_Essen_Sued_Open in update queue
2018-09-19 08:25:15.185 [DEBUG] [internal.scheduler.OneWireUpdateTask] - Autorefresh: Trying to update Item: Window_EG_Essen_Sued_Open
2018-09-19 08:25:15.186 [DEBUG] [ding.onewire.internal.OneWireBinding] - Item Window_EG_Essen_Sued_Open wants update!
2018-09-19 08:25:15.187 [DEBUG] [nternal.connection.OneWireConnection] - trying to read from 'uncached/s_essen/sensed.A', read attempt=1
2018-09-19 08:25:15.193 [DEBUG] [nternal.connection.OneWireConnection] - check if device exists 'uncached':
2018-09-19 08:25:15.373 [DEBUG] [nternal.connection.OneWireConnection] - Read value '1' from uncached/s_essen/sensed.A, read attempt=1
2018-09-19 08:25:15.374 [DEBUG] [ctOneWireDevicePropertyBindingConfig] - type of uncached/s_essen/sensed.A before modifier:Invert OpenCloseType modifier for OnOffType type=OPEN
2018-09-19 08:25:15.375 [DEBUG] [ctOneWireDevicePropertyBindingConfig] - type of uncached/s_essen/sensed.A after modifier:Invert OpenCloseType modifier for OnOffType type=CLOSED
2018-09-19 08:25:15.378 [DEBUG] [internal.scheduler.OneWireUpdateTask] - Autorefresh: Waiting for new item in update queue
Any suggestions?
